Question about Dometic Rooftop RV Air Conditioner
Rv roof air always ices up - Dometic Rooftop RV Air Conditioner
  • 29 Answers
Most likely a dirty filter.
Posted on Jul 06, 2010
Dometic roof top sounds like ice rattling inside and spits water drops
ice building on coils due to low freon, dirty filter, dirty coil,or fan speed to low.
Aug 14, 2015 | Dometic Rooftop RV Air Conditioner
Where are the condensing water drains?on a Coleman RV rooftop air conditioner
The condenser drains for a roof unit drain on top of the rv. There are on hoses which divert the condensation to a location other than the roof. Are you trying to keep it from dripping down at the door?
Jun 28, 2014 | Dometic Rooftop RV Air Conditioner
Water Leak from roof
possible stopped up drain or coil iceing up.
Nov 26, 2013 | Dometic Rooftop RV Air Conditioner
15,000 btu roof mount 2nd ac nonducted cycles about every 5 or so mins ice cold air for about 1 mins
Have you checked location of probe for return air? Remove filters and find probe to make sure it is about in the middle of flow of return air. Let me know what you find.
Jan 12, 2013 | Dometic Rooftop RV Air Conditioner
A/c runs fine for about 1 hour ,then cold air stops. go on roof and find that line from comp. is frozen and twice the size with ice.
Usually when the suction line frosts back to the compressor and forms ice that means you have plenty of gas in the system. So what ya do is clean the air filter and the evaporator as best you can. Make sure the fan inside is operating properly.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 22, 2012 | Dometic Rooftop RV Air Conditioner
13.5 Dometic rooftop rv ac design has changed since I purchased 2006 Monaco Camelot rv. The collection cups leading to the drain line do not fit well on the roof seal and a good seal is hard to achieve. If...
I've not run into the problem your having yet, so I will apologize up front for asking you to furnish more information. These drain cups that I assume are little round pieces attached to the base of the unit where it meets the roof, were not common on dometic, but were common on Coleman AC units. Those are the outlets for condensation to the roof anyway, are they not?
Also, as far as gasket goes, no I wouldn't recommend using 2. We were always advised by manufacturer to compress gasket to half the original thickness when installing either Dometic, or Coleman (RV Products). Coleman at one time, had tabs under gasket that when gasket was compressed, and they touched the roof surface inside, that was far enough, which was approximately half the original thickness. Believe it or not, over-tightening is more likely to cause a leak. Stick with half original thickness, or close to it.
Jun 26, 2010 | Dometic Rooftop RV Air Conditioner
15000btu roof top unit freezing up
take a garden hose to the evaperator,probably dirty.
Sep 07, 2009 | Dometic Rooftop RV Air Conditioner
My roof top RV air conditioner is dripping water inside my RV
Check run-of on roof & see if it's been reduced lately, it may just be a plugged drain at base of unit on roof.
Jul 29, 2009 | Dometic Rooftop RV Air Conditioner
Coleman tsr rv air conditioner leaks into rv when running
It probably has a clogged condensate drain. Take off the cover on top the RV and check hoses or tubes leaving unit for debris or lint. Often this water is used to help cool the condenser so look for leaves pine needles etc in the pan. There may be a cover you can remove on the evaporator section that will allow you to clean the collection pan and hose or trough. Is it possible the RV is far enough out of level that the condensate can't "run uphill"? Always power off while working on this unit unless you are electric savvy. Good luck!
Jun 28, 2009 | Coleman Mach 15 Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
90 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
