Question about Stanley Air Tools & Compressors
I have a Bostitch/ Stanley Compressor model CWH 100 WT that has no instructions. I want to mount it on a wall facing down will it be ok in this position?
koolbreezes
  • 540 Answers
SOURCE: Geckos
Use a finer mesh screen! Thank-you-very-much!
Posted on Aug 26, 2008
  • 3 Answers
SOURCE: Stanley bostitch coil nailer gun
check the safty shaft and see if something could be under trigger safty causeing it to fire.
Posted on Feb 20, 2009
smjdragonfly
  • 79 Answers
SOURCE: air coming out the trigger of a stanley air gun
Go to the Stanley Bostitch website. Click on schematics & parts. Find your model number in the drop down list. There is a list of parts and pricing. Just above the parts is a link for the schematic. Honestly, I worked on these things for years. It is best to replace the entire trigger valve. It comes as a kit with instructions grease, and a little tool to hammer your pins out. Lemme know if this helps. Please rate me
Posted on Jun 18, 2009
  • 1388 Answers
SOURCE: i have a stanley bostitch
Your nailer uses a trigger valve (part # tva6 cost about $20) and is sold at www.bostitch.com or generic valves sold on ebay . If you have a source for orings, you could try to repair the valve. Remove the roll pin that holds the trigger to expose the tva6 valve. There are roll pin/pins that hold the valve in just above the valve in the body. Remove these pins and apply air pressure to gun to pop-out the valve. Use caution when you do this. Remove nails, lower pressure to gun and use glove or rag to catch valve because it could come out with force. With tva6 valve in hand remove two pins that hold valve together and remove inner plunger. The middle oring on plunger is cause of leak. Try using an oring about same size as the broken seat. It must fit pretty tight to work. If you had a small leak it could be that the firing pin orings fit too loose or  just too worn.  Use silicone lube or oring lube on the orings and the valve port. Good Luck on your repair and email if you have other questions.
Posted on Aug 06, 2010
  • 885 Answers
SOURCE: I Have a Stanley air compressor Bostitch model
The brown liquid you are getting out of the compressor is water with rust in it from the inside the air tank. Somewhere on the bottom of your air tank there is a valve you need to open from time to time to drain the water from your tank. If you are getting rusty water from the air outlets you probably have a lot of water in the tank. If you can take the compressor outside, with pressure in the tank, where the water won't stain anything and slowly open the valve to drain the tank.
Posted on Feb 02, 2011
My bostitch 6 gal compressor keeps running , and running , even goes into a higherpitch motor noise. can i check something ? or clean something to fix it ?
is it building up any pressure on the gauge
if the pressure recorded is around 40 psi or less , replace the failed poppet/reed valves in the compressor head
if it goes to 100 psi then replace the automatic controller for the motor
Jun 15, 2016 | Stanley Bostitch CAP200P-OF 6 Gallon...
Motor switch replacement Stanley model#swk-PAC 150h air compressor
For safety reasons work on mains voltage switches must be preformed by a qualified electrician.
Aug 02, 2015 | Stanley Air Tools & Compressors
Large red pressure adjustment knob on my compressor is broken and will not screw on, compressor will not hold pressure
You may have to replace the regulator as many of them do not sell just the knob. If you go to this link and put your model number in the search box you will be able to see what is available for it. By the way, Stanley (Bostitch) merged with DeWalt so all the breakdowns for Bostitch can be found on the same site now.
DeWalt/Bostitch parts and owners manuals.
Aug 19, 2012 | Stanley Air Tools & Compressors
I have a Stanley Bostitch Oil Free Air Compressor 6.0 Gal 2.0 Hp Peak, 1.5 Hp Running 135 Psi The problem is it won't blow out air or hold the air.. How can I fix this?
Some Bostitch compessors are very unique in that they intake air from below the piston. If you cannot find an air filter, then your compessor has reed valve built into the piston that may cause problems. If you have an air filter on the head of the pump, then you have reed valves in the head. When the reed valves fail, there will be very little or no air pressure. Second problem with all compressors is the in-tank check valve. This valve allows air to enter the tank and not back-out into the compressor. Easy to check. Add air into tank with another compressor thru the quick connect and listen for air leaking around the head or pressure switch. If no leaks and pressure holds in the tank then valve ok. Examine the condition of the cylinder and piston ring by rotating the crank by hand so that the piston is at top of cylinder. Look for scratches around upper part of cylinder wall. If scratches, then replace cylinder and piston ring. If top of cylinder looks good, then suspect reed valves. Good luck
Sep 12, 2011 | Stanley Bostitch 2hp 6gal Air Compressor...
CAP 2060P air compressor won't start. How does the red on/off switch work? Ours just turns and hard to tell where it is supposed to be. Also, is there a reset button someplace? Thanks.
The pressure switch installed on your unit is of the pull / push type. Let all the air out of the tank and plug it in to wall outlet. Push red knob in firmly then pull out for desired results. The pressure switch contacts can fail but usually after many hours of hard service. No reset /thermal breaker is listed on the replacement parts list. You can view at WWW.bostitch.com click on service / parts then look for your model number from the pull-down list. Good luck with your compressor.
Apr 17, 2011 | Stanley Bostitch 2hp 6gal Air Compressor...
I need a replacement stamp pad for a Stanley Bostitch Six Wheel Numbering Machine Model 00680 Bostitch 607.
I have a Stanley Bostitch Model 00680-607 machine.If you want I can sell it to you. It is in very good condition.judyc1026@gmail.com - Judy
Feb 21, 2011 | Stanley Bostitch HP118K 23 Gauge Headless...
Owner manual
Most all manuals are available at www.bostitch.com, look for support tab, then select service parts and documents. Find your model number in the pull down list and finally select usage manual.pdf, enjoy.
Jun 18, 2010 | Stanley Bostitch Coil Framing Nailer
Looking for a piston kit stanley/bostitch model cwc200wt
http://www.mastertoolrepair.com/
Try these guys. If you can't find it listed on their site e-mail them and they should be able to help.
Good luck.
Jun 09, 2010 | Stanley NEW Bostitch 2 HP 6 Gallon...
Air coming out the trigger of a stanley air gun cylinder does not come down stanley Bostitch nail gun /T40S2
Jun 04, 2009 | Stanley Air Tools & Compressors
Air Tools & Compressors Logo
498 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
