Question about Mitsubishi WS-65869 65" Rear Projection Television
Green blinking light following a power outage
I have the notorious green blinking light problem which follows a power outage.
  • 58 Answers
I rebuild the DM power supply in these sets with about a 50% success rate. Sometimes changing the 7 1000uf caps on the small power supply in the DM will fix it, you'll also have to solder the small 8 pin ICs as well. Do this carefully as you do not want an accidental bridge. If this does not fix your problem, replace the DM-POWER board not the DM Assembly. It's about a 300 dollar difference. You'll need a mitsubishi authorized service center to order the part for you. Goodluck.
Posted on Jul 05, 2010
My hp laserjet 1300 printer shows blinking the orange light instead of the green one and I couldn't find out what is the reason
1. Go light/button blinks twice with solid green and orange lights
2. Green light starts blinking with go light twice and then both go off
3. orange light goes off.
4. green light followed by orange light followed by go light cycle twice and a third time by the green light
5.followed by the orange light continuously blinking.
I have already tried the following trouble-shooting:
1. Put in a new cartridge
2. Made sure there is paper properly seated in the tray
3. Made sure all doors closed (I even took off left side to verify no memory cards
4. Verified all doors closed
5. Done a cold reboot by holding the Go button while turning the unit on.
6. Repeated steps 1-5 multiple times.Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For HP Support
Mar 06, 2014 | HP LaserJet 1300 Printer
I have a WS-55511 rear projection TV. We had a power outage in the area and the TV will not power at all. Could this be a blown fuse?
if the green power light just blinks that is one issue==========if the green power light does not come on at all suspect a fuse----follow the power cord (set unplugged) into the set and plug in ac fuse is right there.
If you have the blinking light that will not stop it means the DM unit in the set was damaged and that is expensive.
If you need more information or have questions let me know with a comment here.
SD TECH
Sep 17, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Had power outage and after hitting reset button green light blink
Hard to say without looking and sniffing!
But if you suspect that it is and it is likely, you may be able to get it repaired on your insurance policy. It should be covered under FUSION
Dont mention the lightning but check your policy. Then get the repair guy to write fusion problem on the receipt and submit for claim.
Sep 07, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Green light on front rapidly blinks after power outage. No picture, or can't turn on
This unit, when first plugged in or after power interuption takes 70 to 90 seconds for the digital module to boot up. During the time the LED blinks green and the set will not respond to anything. After the appropriate amount of time the blinking should stop and the set should operate normally. If the blinking never stops then you have to have the Digital Module repaired.
Apr 25, 2009 | Mitsubishi WS-55511 55" Rear Projection...
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Mitsubishi WD-52525 52 in DLP.
You most likely need the V26 DM repair kit at the following link, that usually repairs the blinking led problem.
http://servicemanuals.vstore.ca/
Nov 24, 2008 | Mitsubishi WD-52525 52" Rear Projection...
I have a 62 inch mitsubishi dlp model#wd-62525 serial#125902 , tv will not power up it has a flashing green lite below the timer button that flashes,i have try the reset button but it just starts blinking...
if the light just constantly blicks green and doesnt stop. You will need the" V26 DM repair kit " which will usually repair that issue. You can get the repair kit at the following link which includes the replacement capacitor and instructions
Sep 26, 2008 | Mitsubishi WD-62525 62" Rear Projection...
No power just blinking green light
I had this problem last year. Just the blinking green light. the tv would not turn on. It was the power module. A local electronics tech fixed it for me for $300.00. It was a circuit in the panel that needed to be changed.
Aug 29, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Set does not turn on. Green lights continually blink.
you need the DM repair kit to rep[lace the bad capacitors on the DM power supply. You can get the V21/V19 DM repair kit at the following link which contains the replacement capacitors and the Cd with detailed instructions for the repair with clear instructions and pictures. heres the link.
Jun 22, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi wd 62525 chassis
I was told there was a bad batch of capictors so we reaplaced all of them and still the blinking green light ,and no tv still help bagelbaker77@yahoo
Jun 04, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Open Questions:
See all Mitsubishi WS-65869 65" Rear Projection Television Questions
Mitsubishi WS-65869 65" Rear Projection Television Logo
183 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
