Question about Dryers
Thick string pulled into dryer exhaust vent, now stuck & dryer shut off.
    President:
  • Dryers Master
  • 2,651 Answers
Yea sound s like the string has problably wrapped aroound the motor shaft/ blower assy. your gonna have to dissassmble and try to un bind the thing
Posted on Apr 18, 2008
Affinity aeq7000eeo e5b 006 error code
Probably a stuck button Use this SERVICE manual to locate your tech sheet and it will give you info on errors for your particula machine
Aug 30, 2012 | Electrolux Dryers
LG Tromm DLE8377NM check filter but filter is clean
You say lint hose is disconnected. Are you referring to the exhaust vent to the outside? I would suspect this vent is clogged or a vent flapper outside may be stuck shut.
Feb 14, 2012 | LG Dryers
My dryer does not heat. Clothes do not dry.
Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose. If the vent doesn't make a difference, then check the blower wheel for excessive lint build up, check that there isn't anything stuck to the air intake baffle inside the drum, (i.e. the screen on the back wall of the dryer when looking into the drum). Check the lint filter chute for blockage. Check that the heating element isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket thermometer can be used for this. It should cycle approx between 120 degrees and 160 degrees ( without clothes ). Check that the drum seals are not worn out.
Dec 06, 2010 | Kenmore Dryers
My dryer does takes ages to dry clothes and then not completely. In addition any string item like bikinis will be torn .
check to see if exhaust vent is cloged with lint, both behind dryer and outside. this should give you more air flow.
Dec 04, 2010 | Frigidaire GLEQ2152ES Electric Dryer
I have a kenmore HE2 dryer and matching washer. It is 3 years old. It works and eventually clothes do dry. It does heat up. But it doesn't heat up as hot as it used to and it takes twice as long to dry...
Make sure you check your exhaust line and where the air blows to the outside. If your exhaust vent or hose is bent or restricted it will take a very long time to dry the clothes. Sometimes the vent flap on the outside exhaust is stuck shut. Clear dryer exhaust venting is critical for proper operation. Several companies offer a vent cleaning service where they completely clean out the exhaust lines.
Feb 02, 2010 | Kenmore HE2 Plus Front Load Washer
Not drying clothes
If the unit is heating properly which it should pull around 25 amps when heating , and the unit is tumbling it is 100% an exhaust issue , either a kinked duct behind the unit , a ball of lint stuck in the duct , lint build up outside in vent , or water in under ground duct. If you find the clog it will be FIXED!
Let me know if you have any other questions.
Phil
Apr 14, 2009 | Whirlpool WED6200S Electric Dryer
My Maytag dryer won't dry clothes.
Pull the dryer out away from the wall. Unhook the vent from the dryercompletely. Do not put anything over the dryer exhaust on the back ofthe dryer. Do a normal load with the vent unhooked. If it dries betteror ok like this then the problem is in the dryer venting. Like ablocked vent pipe or a smashed or restricted vent hose.
If the vent doesn't make a difference,then check the blower wheel for excessive lint build up, check thatthere isn't anything stuck to the air intake baffle inside the drum,(i.e. the screen on the back wall of the dryer when looking into thedrum). Check the lint filter chute for blockage. Check that the heatingelement isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket thermomter can be used for this. It should cycle between 120 degrees and 160 degrees. Check that the drum seals are not worn out.
Feb 21, 2009 | Maytag Neptune MDE7500AY Electric Dryer
Lint is stuck in the back of dryer
Un plug the dryer, disconnect the vent and reach in the hole and pull the lint out. Put a bag on the end or somthing to catch the lint. Turn on the dryer and blow the lint out. This is a pretty good indictor that you vents on the house are clogged. Maybe time to get them cleaned. thanks Dave www.washermd.com
Dec 08, 2008 | Whirlpool GEW9250 Electric Dryer
Electric dryer shutting off
most likely cause is the air duct is blocked with lint, some always gets past the screen and builts up in the exhaoust line. not enough air flow, the air gets hotter than normal and trips the over temperature cutout.
for most dryers
clear the fan, and exhaust ducting all the way to the wall, and the outside vent hood, of lint
Sep 22, 2008 | Whirlpool LER4634J Electric Dryer
Clothing cord stuck in drum
You should be able to get the draw string completely out by trying to open the top of the dryer which may be hinged. The front of the dryer may open by prying at the front between the top and the front.
Depending on your model there should be some means of getting into the dryer to examine what is doing it. Just make sure you SHUT OFF THE POWER OR PULL THE PLUG BEFORE WORKING ON IT. SAFETY FIRST!
Feb 05, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
41 people viewed this question
Top Dryers Experts
