Question about LG L192WS-BN Monitor
L192WS does this moniter have a fuse? - LG L192WS-BN Monitor
  • 4,737 Answers
Yes, but not visible from the outside, it's fitted on the Circuit Board. And remember, it's soldered on the connectors.
Good luck.
Thanks for using FixYa.
Posted on Jul 05, 2010
My hp moniter stopped working like a fuse blew. i was wondering if it has an internal fuse and how to get to it. It's an HP vs19b moniter. thanks for any help
Thank you for choosing FixYa. I recommend try going to any computer local center and have them check your monitor because there could be other parts have been affected by that problem, there could be other hardware that cause the problem why the fuse failed.
Hope it helps.
AnEspera
Apr 22, 2011 | HP Computers & Internet
How to open LG L192WS lcd computer monitor
Remove all the screws and the base, use thin flat blade to separate the case starting at the bottom edge and work your way around. The case are hel together by plastic finger hooks type, they go in easy but hard to remove.
Service manual: http://elektrotanya.com/?q=showresult&megnev=LG&megnev2=L192W&kategoria=monitor&kat2=all
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 30, 2011 | LG L192WS LCD Monitor
I can't find a service manual... anywhere!
I found this, hope it helps.
http://elektrotanya.com/?q=showresult&megnev=LG%20&megnev2=L192WS-BN&kategoria=&kat2=all
Jan 19, 2011 | LG L192WS-BN Monitor
How to open LG Flatron L192WS model? I can't locate the screws
Here are the sevice manuals: http://elektrotanya.com/?q=showresult&megnev=LG&megnev2=L192WS&kategoria=&kat2=all
Remove the base and any screws on the rear panel, I usually start at the bottom edge and work your way around using thin blade screw driver and be real careful with the cable attached to the front bezel.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Please post back what you find.
Sep 11, 2010 | LG L192WS LCD Monitor
Black strip left hand side of moniter screen not being filled
The monitor should have some kind of menu, accessible through the buttons on the side or bottom. In there you can move te display area to the left. If you then get a bar to the right, you should change the monitor resolution to the highest it can display.
If the bar on the left persists, you should check wether the PC-monitor cable is properly insterted. If so, try another cable. If that doesn't help either, try another monitor.
I hope this helps,
Yannick.
Oct 05, 2009 | LG L192WS LCD Monitor
Acer netbook Aspire One doesnt support extarnal LG Monitor L192WS.How can I get the monitor to work properly?
First have you turned the port on for the monitor ? if not it usually is a function key like F2 ect. If this is done the right click on a free space on your desk top > then properties > settings tab ....and make sure you have two display checked in the drop box.
May 30, 2009 | LG Flatron L1750S 17" LCD Monitor
Where can I find driver for my LG Flatron L192WS?
Go there:
http://www.lge.com/us/support/product/support-product-profile.jsp?customerModelCode=L192WS-BN&initialTab=warranty
or
http://tinyurl.com/dyrzc4
Apr 06, 2009 | LG Flatron L1750S 17" LCD Monitor
FLATRON L192WS LG
hold de book buton 5 or 6 sek
Aug 10, 2008 | LG Flatron L1750S 17" LCD Monitor
LG L192WS-BN Monitor Logo
121 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
