Question about Air Purifiers
Our Venmar HRV air exchanger won't run, what is wrong how can we fix it.
Why hunter air purifier fan does not work hod 30710
It is probably broken in some way. Return it to wherever you bought it and exchange it for another one, or contact the manufacturer for more info.
Aug 19, 2014 | Air Purifiers
Why is my Mitsubishi mr slim is blowing black particles into room?
Area where "fresh" air is being pulled in is dirty, filter needs replacement, heat exchanger is old, a seal is old/torn, or mold is shooting out!
http://www.ehow.com/info_12016541_particles-blow-out-fan-air-conditioner.html
May 27, 2014 | MR SLIM Split-ductless: Mitsubishi...
New furnace, Water In Induction Motor, Yellow Flame
The problem is too much gas as opposed to not enough air. It is still running rich. Did you take into account the elevation of the location your furnace is installed at. The higher above sea level the less air that you have to aid in cumbustion. The condensation is from excess gas being cold and causing water to accumulate. Can you run it like this? Yes but it will cause issues with soot and carbon deposits. It will also cost you more money in the long run.
Dec 23, 2013 | Goodman Manufacturing Goodman GCH950453BX...
My oreck air purifier xl won't turn on
With the Air 8 Models there is a number of issues from the motor to the power supply to the circuit boards. With these old units it is hard to find parts for them. as oreck no longer manufactures them. but if the parts were availible i would estimate around 100 to fix your power issue
Sep 15, 2011 | Oreck XL Professional Air Purifier
My Honeywell Type No. F50A Electronic Air Cleaner arced continuously even though I had cleaned it a few days prior. I shut the unit off and removed the air cleaner cells. Is it safe to run the furnace...
Yes you can run the furnace with out the electronic air cleaner for awhile.... It you are in a very dusty conditions than I would not run it very long a day or two....because you will not have any protection for dirty getting stuck on the evaporator coil or if you have a 90% gas furnace the secondary heat exchanger...and restricting air flow.... You can put in a 1" pleated air filter the same size as the total of the two cells in place of the cells till you can get the electronic working..... Sounds like either something big is caught across the cell plate or they are still wet and have not dryed out completely. Hope this helps.
Mar 02, 2011 | Honeywell (F50F1032) Air Purifier
How to reset hrv filter light
1: Press the clip_image001.jpg button to turn off the screen.
2: Press and hold the down arrow button until an 02 appears in the Roof Temp, when you see the 02 appear remove your finger.
3: Using the clip_image001.jpg button - short continuous pushes until you see 02 on the top (Roof Temp) and 5 underneath (House Temp) NB: The light should go off.
4: Press the clip_image002.jpg and this will save your changes.
Oct 25, 2010 | Air Purifiers
REPLACED FILTER AND THEN UNIT STOPPED WORKING
I was ready to send mu unit out to get repaired at the minimum cost of $ 179.00 and then saw JSEhandyman list a website for the manual. The manual was not only so simple to read an understand it saved me the time and money of having it fixed. It was a simple solution. I was putting new air filter in on the side and wrong way. THANK U SO MUCH
http://www.ecoquestintl.com/support/US50300_Living_Air_Owners_Manual.pd
Jul 22, 2009 | Ecoquest Living Air Classic Air Purifier
I have the Renewaire Energy Recovery ventilator system, Model EV130, installed in my house but do not know how to set it to the proper setting. The runtime numbers go from 10 to 100 and I am not sure what...
The RenewAire system is sized per ASHRAE 62-1999, residential air exchange of .35 air changes per hour, or 8 air changes per day. You can find an operation sheet for the PTL @ www.renewaire.com, downloads, residential, controls, PTL. A chart shows a starting point of ventilation based on the square footage x 8 foot ceiling height with a run time percentage for each model. For 2250 square feet with 8 foot ceilings, the run time for an EV130 is 85%, cycling hourly.
Actual run time will vary by tightness of house, number of occupants, lifestyle (number and frequency of pollutant generating activities). Outside weather conditions should have little effect on run time percentage. I run my system @ 50% year round, when the windows are shut.
The ERV tempers humidity and temperature extremes of the ventilation air year round. It is not a substitute for heating or A/C; it does not dehumidify the house in summer (it does reject some of the incoming summer humidity content, when the net humidity is greater outside than inside). It will lower humidity of the house in winter, or whenever the net humidity outside is lower than inside.
It will ventilate the house in an energy efficient manner all year long. Based on this information, choose a setting and manage the amount of run time to achieve your best IAQ.
Apr 25, 2009 | Air Purifiers
Fresh Air
I've heard from previous message on here that Ecoquest is very good about exchanging products.
Jul 15, 2008 | Ecoquest Fresh Air Air Purifier
Air Purifiers Logo
596 people viewed this question
Top Air Purifiers Experts
Are you an Air Purifier Expert? Answer questions, earn points and help others
