Question about Bosch 24 in. SHU43 Built-in Dishwasher
I am trying to remome the control panel on my Bosch SHU43 and having some difficulty. Can you give me some direction. My problem sounds familiar with your responce to constant running and no cleaning. The control panel does not seem to make contact with any solection when you depress the buttons. This is my reason for accessing this component. Thanks for any assistance Joe.
  • Bosch Master
  • 2,605 Answers
Hello Joseph, welcome to Fixya.
I can provide you with a tech. guide, but you`ll need to post an email address for me to send it to.
With the guide you can practically tear that dishwasher completely apart if you`re even a little mechanically inclined, it`s pretty good.
I`m not sure if I understand the problem you`re having, based on your description though.
Let me know if you either want me to send that guide or need further assistance.
I`ll watch for your reply,
macmarkus :)
Posted on Jul 08, 2010
Mark can you email me a tech guide for the Bosch SHU43C02UC I ordered a stainless steel front cover and weant to replace the white one on mine with it and need advice on how to do it. Thanks Don Netshooper@cox.net
Posted on Jan 10, 2012
  • Don lewis
    Don lewis Jan 10, 2012
    Problem Solver:
  • 17 Answers
First...make sure you visit the Bosch dishwasher recall website as this model is under the recall with a faulty controller which may cause a fire! Check your model under http://microsites.boschappliances.com/safetyrecall/dishwasher/
then call 800.856.9226 to setup a recall repair appointment. We just found out about this recall and was never notified by Bosch even though we registered our unit after we purchased it...talk about poor customer service! Hope this helps!
Posted on Oct 18, 2010
Why will my dishwasher not drain ? Motor runs, fill is good washes good.
sounds like the pump has a blockage in the machine or if there is separate pump to drain as opposed to the one that pressurizes and washes your dishes it may be faulty some machines ( not sure about this one ) have two a high pressure pump for washing and a low pressure one for emptying . Some machines have a system that switches the pump from wash to outlet and this is a usually a relay to an electr'o mechanical tap ( it directs water to jets or out to drain ) all of these systems are controlled by the Programmer and should this go faulty many problems can occur. I suggest you seek help from your local repairman, this type of fault will probably be very familiar to him
Jun 27, 2014 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU43C07 impeller does not freely spin?
You will need to replace the Drain Pump Motor Assembly Bosch Part Number:AP2802385.
Most Bosch dishwashers are relatively straightforward to work on.
However, it you are not familiar with their disassembly and reassembly, you should take clear pictures of every part or wiring connection before you take it off or disconnect it. This will be invaluable when reassembling the dishwasher.
May 01, 2014 | Bosch 24 in. SHU43 Built-in Dishwasher
I have no power to the dishwasher.No lights light up om the control panel.Checked circuit breaker and there is no problem there.Is there a fuse or power reset button.
if you definetely have power into machine its sounds like a pcb fault these can blow out tracking or relays on pcb causing dead machine can be replaced but not cheap.
Aug 16, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
How do I reset an old Bosch dishwasher SHI4302UC ?
Assuming that you can control power to the dishwasher from your kitchen panel switches, hold down the power on switch on the front panel of the dishwasher and recycle power (switch off and on) at the kitchen panel switch.
This will reset the dishwasher.
Sep 26, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
I have a Bosch dishwasher that just runs and runs and runs, it won't complete the cycle. Is there a reset button for now? And then, what?
It sounds like you have a control board issue.  You can try resetting the power to the dishwasher and see if that corrects the problem.  If not you may be looking at a board replacement.
Thanks, Bill
Nov 26, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch shu43
sounds like your impeller/motor is going bad or something is stuck in that area.
Apr 30, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher
1st pull the 6 screws holding on the outer door panel. Then the 4 screws you already did. Look now at the side of the inner door at the top and you will see 1 screw on each side. Remove these and the panel will fall off.
Mar 11, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
My Bosch Dishwasher doesn't run
double check power to your plug socket ( use bedside lamp)
check fuse in plug
check water supply ( run the water supply directly into pot/bucket)
make sure door closes properly (if built in )
if built in remove and then check!
Feb 09, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Dishwasher SHU43C02UC
Unplug from mains for 5-10mins. Are you having any power difficultys? sometimes this can crash the controller.
if none of the above possible that its the controller
Jan 03, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
281 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
