Question about D-Link DAP1360 IEEE 80211n (draft) Wireless Access Point DAP1360 (DAP1360E) Pre80211n
Cant konfigure router, when i type 192.168.0.50 or
Cant configure router, when i type 192.168.0.50 or dlinkap i doesent work
dlink dap-1360....second router that doesent work. Never buy it..!
  • stisaias
    stisaias Sep 16, 2012
    i agree with that pal. this is ******** equipment
  • Anonymous Mar 19, 2014
    lost the seqruty key
    Problem Solver:
  • 12 Answers
Reset using the button on the back the do an ipconfig - so if you ip is 192.168.1.1 try that to get in to the router
Posted on Jul 10, 2010
Why i can not go to sit for configure DAP-1360
Go to this link http://support.dlink.com/ProductInfo.aspx?m=DAP-1360 and download the user manual for your DAP-1360. Configure it in the WISP mode following the manuals instructions.
May 19, 2014 | D-Link DAP1360 IEEE 80211n (draft)...
Dap 1360
1- first distance between Dap-1360 from the router wifi Nilox should be max the signal length around 50 meter,
2- try to update the Dap-1360 software from the internet then test the network cable again and the electric cable..
hope it help ...
Mar 19, 2014 | Computers & Internet
Bought the D-Link DAP-1360 and my problem is that my laptop does not have a port to take the ethernet cable. How do I set it up nw as a range extender?
You don't need to connect via ethernet. In your laptop set the IP address to 192.168.0.2. subnet 255.255.255.0
This will probably temporarily disconnect you from your internet but you can reset the IP address back later. It might be a good idea to write your current settings down for later.
Open your browser and enter dlinkap or 192.168.0.50
You will connect to the Dlink AP
follow the directions in the user guide found at the link below.
http://global.dlink.com.sg/site_support/DAP-1360/Manual/DAP-1360_Manual_v1.00.pdf
Feb 11, 2014 | D-Link DAP1360 IEEE 80211n (draft)...
Cannot access either dlinkap or 192.168.0.50 via web browser in order to set DAP-1360
Connect your computer to the router.
Assuming Windows 7, click the "Start" button.
Into the search-box, type 'CMD' and press ENTER.
Type 'IPCONFIG /ALL'.
Look for the IP-address of the "gateway" (or "DHCP-server").
Type that IP-address into your web-browser.
Nov 24, 2013 | D-Link DAP-1522 Xtreme N Duo Wireless...
How to configure Dlink DAP-1360 wireless N Range
Is this the router that is currently connected to your network, and also the router that is providing you with internet right now? what would you like to setup?
Dec 18, 2012 | D-Link DAP-1360 Wireless N Range Extender
Can't configure the network with ethernet cable
Hey, you're almost there. The connection between the no-wireless PC over ethernet to the DAP-1360 Repeater is fine. The reason it can't connect to your LAN or the internet, however, is that the repeater isn't actually repeating your Ofir network, it is instead creating it's own, completely isolated wireless network (Ofir_EXT).
The D-Link setup and documentation is confusing, and doesn't have proper instructions for the repeater setup.
Rerun the setup wizard, setup as a repeater, then select manual configuration method.
Now, enter the wireless network name of your the network you want to extend (in this case, Ofir). Then enter the same security and password etc. for Ofir in the following fields, just like you were connecting to Ofir from a smartphone or laptop.
Once that is finished, you should be up and running. If things worked, you should NOT see any new wireless network. There should be Ofir and just Ofir. Wireless repeaters work invisibly, you'll still connect to the same network like you always did, but now it will have much improved range thanks to the DAP-1360. The computer entherneted to it should be networked on the wireless LAN and have internet access after this as well.
Good luck, I hope my instructions were clear. Wifi networking is easy, it's understanding all the manufacturers less-than-intuitive software that makes it hard.
Oct 16, 2012 | D-LINK SYSTEMS DAP-1360 Wireless N Range...
Router can't detect DAP 1360 when installed about 90 meters away. UTP connectors tested okay.
have you tried turning on and off the router and AP? it would scan again...it looks like you just need to recheck connections and powers...
Oct 09, 2012 | D-Link DAP-1360 Wireless N Range Extender
I just got a dap-1360 and i cant set it up when i type dlinkap or 192.168.0.50 in my URL it keeps sayin webpage cannot be found
just make sure that you belong with in the same IP range.
default DAP-1360 IP is 192.168.0.50
username : admin password :
change your PC IP address to 192.168.0.xxx (e.g. 192.168.0.2)
from there you may choose wizard or manual configuration.
you may change your DAP-1360 IP add according to your network settings in the office and you must change you PC IP address with in the same range.
Mar 24, 2011 | D-Link DAP1360 IEEE 80211n (draft)...
Dlink dap 1522
I think I was having a similar problem with my DAP-1522 ... FW Version 1.10 being used as an access point. I recently discovered that I was not able to connect to the configuration pages using a web browser by typing in it's IP address (192.168.0.50). When I originally set this up device up on my network, it worked just fine, but at some point in time, it stopped working. My solution to this problem was to set the switch on the back of the 1522 from Auto to AP, then re-boot the DAP-1522 by removing power, waiting 10 seconds, then plugging power back in. Once the AP re-booted, I was then able to access the configuration login page by typing 192.168.0.50 into my browser. My DAP-1522 access point is connected via port 1 to my D-link router, a DGL-4100, via a DGS-2208, 8 port gigabit switch. Hope this helps!
Aug 16, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
Open Questions:
My WIFI networks starts in my flat (5th floor) with a ALICE router; I've added a TP-LINK range extender, which brings the WIFI signal (by means of a directive antenna) down to the garage gate. The - In my house, distance from main router (ALICE) to first TP-LINK TL-WA730RE extender: 6 m with one wall in the route; - TP-LINK TL-WA730RE extender connected to a directive antenna (on my balcony at 5th floor) which aims to the garage gate (ground level) with no obstacles (air-air) - Signal power measured with a mobile app (MERAKI WIFI STUMBLER) in front of the directive antenna: 65 dB - Signal power measured at the garage gate (ground level): 24 dB - DAP-1360 extender positioned in the garage, 30 cm just behind the gate - DAP-1360 antennas placed at one meter distance one from the other - DAP-1360 right antenna placed on the external garage wall, in front of the directive antenna and one meter from the DAP-1360 extender - DAP-1360 left antenna placed close to the DAP-1360, 30 cm behind the garage gate -WEBCAM DCS-942L placed at 4 meters distance from the DAP-1360, with no obstacles (air-air) WIFI CONNECTION WORKS FOR SECONDS: from a PC I connect to a D-Link WEB SITE and I manage the WEB CAM remotely (need it 'cause of thieves problems in the garage). But after less than 3 minutes the connection drops. Apparently the DAP-1360 doesn't connect anymore to the network...Trust me, I'm goin' crazy and I'm fed up of spending nights in trying all the different configurations...PLEASE HELP!!!! Thanks to everybody
Mar 01, 2017 | D-Link DAP1360 IEEE 80211n (draft)...
See all D-Link DAP1360 IEEE 80211n (draft) Wireless Access Questions
D-Link DAP1360 IEEE 80211n (draft) Wireless Access Point  DAP1360 (DAP1360E) Pre80211n Logo
3,569 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
