Question about Boating
How to set the idle on my 1993 evinrude motor. motor will start but doesn''t seem to idle properly. would like to know how to set the idle and hope this will solve my problem
    Champion:
  • 274 Answers
Look for the carbs you well see a small screw ,when its running slowly turn it. This well take time
Posted on Jul 05, 2010
Timing on a 1997 50 hp Evinrude model BE50TLEUC.Carbs has been clean new plugs refuse to idle and struggle to start.
OK.. have the carbs been professionally cleaned and set?
Has the engine been sitting up? - Check the compression.
If the compression is good and the carbs ARE clean and set properly.. check for air leak.. this will make idle rough and hard to start.
Check the choke and make sure its working properly.
May 24, 2017 | HP Boating
Identifying this outboard motor from evinrude, AQABVA71K899
Rob, AQABVA71K899 does not seem to come up as a valid # for referencing engine. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Outboard Engine Serial Number Year Match up
Evinrude Outboard Motor Model Numbers
EVINRUDE OUTBOARD MOTOR MODEL YEAR LOOKUP GUIDE 1913 1979 MASTERTECH MARINE
Jul 11, 2016 | Boating
What is the idle timing for 1993 90hp evinrude
90 hp 1993 evinrude idle speed - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 3, 2008 - 2 posts - ‎2 authors
"How many rpm should the engine idle at,and where and how do you adjust it Thanks" 50 hp evinrude no idle and no top speed need assistance ...
Jul 6, 2013
1993 50 HP 2 cyl Evinrude stalls, runs at idle when ...
May 7, 2012
adjust carburators and idle speed 1993 48hp
Jul 29, 2010
90 hp stalls when going in gear
May 21, 2010
More results from www.marineengine.com
1993 Johnson 90-HP Runs Only At Idle Speed On Spring Start-Up
Johnson 1993 115 xflow Link and Sync - YouTube? 4:55https://www.youtube.com/watch?v=ReeuaVh8uZQNov 25, 2012 - Uploaded by Brian O'DellJohnson 1993 115 xflow Link and Sync. Brian O' ... Also if you can give me some details on how you got the ...DOWNLOAD Evinrude 90HP (90 HP) Repair Manual
Dec 14, 2015 | Boating
Idling Rough
Set air mix 1 7/8th turns,start motor,turn slowly in until motor coughs then out quarter turn.motor that old could be anything,coils,points,condensers,worn stator,crank seals,low compression
Oct 26, 2013 | Boating
1964 5 1/2 hp evinrude kills at high speed
You should have a High Speed carb adjust and a Low Speed carb adjust. If it's running fine while idling, adjust the high speed setting. If you have two nobs, its the lower one. May be set wrong. If you don't have two nobs, remove the carburator and check the jets to make sure they are completely clean or better yet, order yourself a carb rebuild kit to take care of all of this. I just rebuilt my 1971 evinrude 4hp and the carb kit made the world of difference.
Apr 17, 2010 | Light Outboard Motor Boat Bass Fishing...
1978-79 15 HP Evinrude boat motor hi low settings
High revs is 5500-5700. low revs is about 500. the low revs is in gear and idling.Hope this is the info you are after
Jun 05, 2009 | Boating
1999 saturn sl1 rough idling
a pit\ston might not be working properly
May 29, 2009 | 1993 Saturn SL2
Where can I download a free manual for Evinrude 4HP motor.
Adampeake how do you download free from the web link
they wanted $19.99USD
Apr 22, 2009 | Boating
Boating Logo
420 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
