Question about Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV
I have blue dots - Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV
  • 201 Answers
The light engine is bad and needs replacement. you can go on sony.com for tech support and see if your problem is still covered under their extended warranty for your model. If not that repair can run several hundred $ if not more.
Posted on Jul 05, 2010
Is vitamol v10 the same spec as magura blue blood
All the above answers saying to use a DOT or other fluids are wrong.
Never use DOT-3 or DOT-4 based fluid in a system equipped for Magura's Blue Blood or Vitamol V10 mineral oil. Using DOT-3/DOT-4 fluids will likely cause seals to fail in your clutch or brake cylinders.
To answer your question: yes, I believe both Blue Blood and Vitamol V10 products are equivalent SAE10 weight mineral oil.
Jan 05, 2013 | Cars & Trucks
I have blue dots on the screen. I cleaned the glass on the projection bulb and the prizm but still have blue dots.
Your tv is an LCD projection one - in which the image is generated by 3 small LCD screens. The blue dots are pixels from the blue LCD that are dead - always fully open.The only fix is to replace the LCD panel and that is going to cost you around $300.
Nov 06, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Blue dots on screen. what is it and can it be fixed? a new bulb was recently installed.
Yes,it is repairable.Blue dots on screen is sign of LCD failure at optical block assembly. There are three LCD on the optical assembly RED,GREEN and BLUE. Blue LCD failure causes blue dots on screen. Repair should be done by replacing blue LCD. Note! LCD replacement needs Extra care and precise tools such as oscilloscope and color pattern generator , for the color alignment after replacing LCD. But if you can afford, replacing the optical block is better,
Sep 26, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have a SONY LCD TV model KDF 50WE655 w/ Blue Dots on screen :(
The blue dots are cause by a defective optical light engine. This parts is quite expensive.
Read the info from this link for more info.
Jul 02, 2009 | Televison & Video
Blue dots on my lcdtv
Sometimes the voltage can be set to high by the factory. Throughout time, blue dots will appear. You will have to remove the back cover off the tv, find the "voltage Screws (they are labeled) and turn down (left) JUST A Notch. Have seen this done many times.
Pray that the panel isn't blown out or bad projector tubes. They are expensive.
Blue dots and screen flicker are VERY common on the newer LCD and Plasmas
Also, if you have a pixel setting on your TV (not sure if that one has it) Try setting it to
480p.
Jan 17, 2009 | Hitachi 50HDX60 50 in. Plasma Television
AT&T LG PHONE
Check whether your mobile's bluetooth is on, if on thats why u r gettings blue dot on screen
Nov 09, 2007 | LG KG800 Cellular Phone
Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV Logo
138 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
