Question about FrancisFrancis! X1 - Stainless Steel Espresso Machine
How do i clean the machine? we bought our second hand and it looks like theres alot of lime scale going on up there!!
    Champion:
  • 274 Answers
Use CLR or vinegar
Posted on Jul 05, 2010
Clean lime scale from Ladylux cafe pullout
get a bottle of CLR and mix a batch then soak the head in it for awhile . Calcium Lime and Rust Remover
Oct 05, 2014 | Grohe Ladylux Cafe Faucet with PullOut...
Whirlpool dishwasher model GU2275XTVQ1 cleans poorly on top only
Check your hose, pump and all water lines for lime scale build up. Sometimes if you dont use some kind of lime away product every few months your machine will/can get lime scale build up from hard water causing it to not properly dispense the water through out your machine. You can also try to run a load with no dishes and no soap but put just lime away in your machine. It might just clear any clogs you might have or starting to get.
Jan 27, 2013 | Whirlpool Gold GU2275XTVy Dishwasher
Hoshizaki km-900mah not going into harvest when float switch opens. New circuit board installed still no harvest. I can set an egg timer and manually operate machine but I can't leave it unattended...
Hoshizaki machines must have a very clean evaporater other wise the ice will bind causing a slow harvest. This may be from lime scale build up. "Lime A Way" is recommended for this proper cleaning. After that is done check to see that the water inlet valve screen is clean and that you have a filter installed.
Last check the thermister attached to the suction line.
http://www.hoshizakiamerica.com/techtips/Pdf/All/tips105.pdf
Aug 01, 2011 | Hoshizaki Freezer Commercial Ice Machines...
What does descale mean?
It means that you need to clean out the lime scale built up in the boiled from the boiling water in the unit. There special scale removing solutions available commercially.
Jan 17, 2011 | Lavazza Espresso Point Capsule Machine
Our dishwasher isn't cleaning very well, and I noticed that there looks like a scaley build-up on the heat element and looks like the holes are plugged on the washing arm. Is there anything that we can...
you can use any kind of calicium lime and scale remover to help clean the dishwasher,there are also several kinds of dishwasher cleaner that can be bought from most any store around. it may take a couple of times for this to work and clean the dishwasher.
Make sure to run it on a empty cycle it run for a few minutes the stop the machine and let it sit and then restart the machine.
Dec 22, 2010 | Moyer Diebel 201LT Dishwasher
We own a SmartLiving Steam Mop, and have really enjoyed it. It suddenly quit steaming. We tried putting vinegar through it in case it was hard water deposits, but no luck. Any siggestions?
yep i have one,,,,,dont use vinegar,,,thats good on chips? no good in steam mops!
go get yourself some kettel cleaner ,,,the stuff for cleaning the lime scale off the inside of your kettel,,,,mix it up in a jug with warm water,,,,and tip that in your steamer,,,dont breath the fumes?
this will clean out any lime scale for you,,,next time fill it with rain water,,,,there is no lime scale in rain water?
Nov 27, 2010 | Hamilton Beach Steam Excel 14770 Iron
My coffee maker does not release all the water. I cleaned the filter and flushed it out by using vinegar like it says. I have to restart the coffee make for all the water to go through. Any answers to...
vinegar???? to clean out lime scale??? thats a rock you know! vinegar wont tuch ot,,,try using kettel cleaner,,,that works fine mix it up in a jug and catch it as it come out the unit so you can tip it back in again run it through a fuw times till it runs clean and fast but remmber to flush it out very well after you have used it,,,this also works on shower heads as well just leave them in a jug full of cleaner till there clear of lime scale
Jun 11, 2010 | Cuisinart DCC-1200 Coffee Maker
I have to flush three time just to get one piece of toilet paper down
the first thing to look at is to see how much water is in the system if its very low it will only give you a short flush take off the top and see how much water it is holding when full up, if its lower that the over flow pipe you could rase it a little by lifting the ball to let more water in, then have a look at the bole itself were the water comes out there are a row of holes if there blocked with lime scale you will need to clean them all out its a messy job i know but this scale will slow down the flow of water and there wont be the forse to clear the bole out, an old drill bit of the right size will easly clean the holes out, dont just try useing lime scale remover and a stiff brush as it wont get right into the holes they need to be clear right through to the water pipe from the header tank ie: about 1.5 inches so only doing the job by hand will do this
it should work ok after that
best of luck,,,with a nasty job
Dec 01, 2009 | Optics
Clogged water dispenser in Bosch dishwasher
Hi, Logmanup (slight bouts with dyslexia, sorry)
By "spinning water dispensers", I assume you mean the spray arms, right? OK... if they are getting clogged with debris it would be nice to know what kind of debris. Pieces of broken glass? Plastic? Lime scale? Iron? And yes, when they get clogged they won't rotate, won't allow pressurized water through and therefore won't clean the dishes.
For the purpose of this solution, I'll assume that there are little white particles clogging up the jets on the spray arms. This indicates hard water and lime scale build up.
Other than completely disassembling the entire motor/pump assy. (you really don't want to go there), the best way to clear this out of the system is to use an over the counter chemical called Dishwasher Magic or something similar. If the lime scale build up is really bad (and it sounds like it is), use a couple of bottles to start with and follow up with a bottle per month thereafter.
As an aside... If I assumed correctly about the lime scale build up, that means that it's also affecting other appliances as well. Mainly, your hot water heater. If you haven't done it before, please read this to perform maintenance on it. And a product something like this for your washing machine.
I hope this was helpful. Let us know if this works or not. If not, please write back and we'll go a little deeper.
Mar 12, 2009 | Bosch Dishwashers
Washes fine doesn't drain.
I had the same problem, solution was simple.I removed the cover and there is a small white wheel on the right lower side, not where the motor is..it was not turning, i just restarted the whell movement by hand then carefully oiled with wd40.
works great again
hope it helps you
Sep 22, 2007 | Danby 22 in. DDW396 Free-standing...
FrancisFrancis! X1 - Stainless Steel Espresso Machine Logo
144 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
Joe Lalumia aka...
Joe Lalumia aka...
Jim Goldsmith
Jim Goldsmith
billconfused
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
