Question about Dryers
Kenmore model 69801 won't start. Voltage at outlet verified good. Need to know schematic to troubleshoot. Experienced electronics technician working. I am not commercial. this is just my drier. Tim Emch.
  • 145 Answers
Not a complete model number but most kenmores have a white thermal limit on the blower housing that shuts it down in case of overheat. They can wear out over time. If thats not it schematic should be under control panel.
Posted on Apr 18, 2008
  • eli gregg sr Oct 04, 2012
    thanks ill check it out
Why won't my Kenmore 800 series washer fill with water?
Wow, that's a lot of parts and still no water. First thing to check is to see if it will drain and spin. If it does, then we can eliminate lid/door switch and power problem. If it does not, have you checked the outlet? Just asking, I know very experienced tech. that get burned with it. If outlet is good, verify water pressure out of fill hoses. Again, this is a basic check that a tech. can forget. If all this checks, it could be the pressure switch. A bad pressure switch would let unit spin but not let any water in. Maybe lid/door switch also. You replaced the most obvious parts so were down to dealing with something odd. One last note, wiring. Check all the wires and make sure one is not loose. Good Luck!
Nov 23, 2015 | Kenmore Washing Machines
TV power goes off after 2 minutes 45 seconds
There is a contact loose verify with qualified technician for physical setup being tested.
May 20, 2008 | Audiovox AVT1498 TV
All works on my Kenmore Advantage dryer model 69801 but the drum will not rotate except by hand. Help
Most likely the belt is stretched or broken and will have to be replaced.
Dec 13, 2014 | Kenmore Dryers
Ge front load error codes t01
make this test: God bless you
- 45 -
Service Test Mode
The dryer control has a service test mode that can be utilized by the service technician in order to test
critical components and to access error codes. This test mode will help the service technician to quickly
identify failed or improperly operating dryer components.
Test Mode Description
t01 Model ID Verifi
es (or sets on new board) the proper model id.
t02 Error Codes Lists up to 10 control-detected problems.
t03 Software ID
Displays the software version number and the non-
volatile memory version number.
t04 Program Non-volatile Memory Test Control computes and compares the 16-bit CRC of
the non-volatile memory with the pre-computed
version stored in the non-volatile memory.
t05 User Interface Control turns on all LEDs and the 7-segment display.
t06 Keys Continuity Verifi
es that all displays and buttons work.
t07 Outlet Thermistor Displays outlet thermistor temperature.
t08 Inlet Thermistor Displays inlet thermistor temperature.
t09 Moisture Sensor Displays voltage read from the moisture sensor.
t10 Exhaust Detection Verifi
es status of the exhaust system.
To enter the test mode: To exit the test mode:
Disconnect the power for 30 seconds.
Reconnect power and within 30 seconds of
reconnecting power:
Press signal button.
Press delay start button.
Press delay start button. (Displays t01)
1.
2.
a.
b.
c.
d.
Press the power button during the test selection
mode.
Note:
A dryer left in the test mode will exit the test
mode after a period of 30 minutes
Oct 01, 2013 | GE Dryers
Kenmore heavy duty solid state dryer, mdl 1108609420 (???) Starts and all functions work as long as the Start Lever is held up. As soon as you let go of it, the dryer stops. Unable to locate...
repairs should be performed by a authorized repair person.if there is not enough voltage to the relay start switch from the electronic control replace the control. if there is enough voltage to the relay start switch replace the switch.
Jun 04, 2017 | Dryers
Won't heat
There could be a number of different reasons for your drier not to be heating. You could start off with making sure your getting 240v to your drier. Then you could check the lint trap outside your house to make sure its not clogged. If all is good you will now have to take apart the drier and with a ohm meter check several parts. Heating element, burnt wire, limit switches, and a few others depending on the model. If your familiar with troubleshooting you can find a schematic on your drier and go from there. If not I would recommend you having a technician to come and check it.
Oct 26, 2012 | Kenmore Dryers
Power Button will not turn on.
Verify proper line voltage is present at the outlet. This will require the use of a voltage meter. If not properly trained, I would consult an electrician to verify the voltage.
Part of the troubleshooting proceedure requires the technician to verify that the applience is receiving the required supply power.
This has to be verified at the outlet to eliminate the possibility of a bad breaker or bad connection inside the breaker panel or outlet box.
Hope this helps in finding the solution to your problem..
Thanks and good luck..
Jul 26, 2010 | Whirlpool LEW0050P Electric Dryer
Double oven... top works great, bottom has power but will not heat. No codes showing. Have had ohm meter on it and all is functional to elements. GE Profile model # JKP56BOA1BB, older model... maybe 1999.
Do you have 220 volts to the element. If you do then you have a bad element. If you don't then it is usually your erc (electronic range control) or your oven sensor. You need to test your oven sensor for the proper ohms, (should be on your wiring schematic), replace the sensor if you don't have the right ohms rating. You can also compare the upper oven sensor rating with the lower oven sensor rating. If your sensor is good then you need to check if your erc is sending 220 volts down to the lower oven element. Again you need to look at your wiring schematic(usually found in a sleeve behind the oven control panel), to determine which terminals to test. As always you need to be sure that you know what you are doing when you are working with live voltage. If you don't know how to work on live electical products you need to call a technician. It can be very dangerous. Good Luck, Appliance Specialists
Dec 14, 2009 | Ovens
Sears Kenmore Elite Refrigerator model no longer functions. Front panel blinks and all buttons are non-functioning. I already replaced the Control Electronics board, but no effect.
need model number even though it says kenmore we need to know the model will tell us the maufacturer but start by checking voltage at the outlet to see if you have proper ground
Oct 17, 2008 | Refrigerators
Milwaukee job site radio
The transformer needs to be replaced. 120VAC to 15VAC. Take a look on amazon for it, here: Amazon com 15VAC transformers. Wish you best of luck.
Brust
Dec 02, 2007 | GE Superadio III AM/FM
Dryers Logo
196 people viewed this question
Top Dryers Experts
