Question about Hotpoint Washing Machines
Hotpoint WMD 940 Washing Machine error code F-05
Hotpoint WMD 940 Washing Machine has the error code F-05 displaying, what does this mean?
SOURCE: My Hotpoint Aqualtis washing machine
My Aqualtis just stopped mid program with F-05 on the display. This is apparently a failure to drain properly. I was luckily able to hold the power button to cancel the current program drain the water out (very slowly) and empty the machine.
THIS IS HOW I RESOLVED MY PROBLEM.
Disconnect the machine from the mains. Turn off the water supply to the machine. Disconnect the cold water pipe from the machine at the top corner.(Watch out for some water) Remove the drain hose from where you have it going to.  Pull the machine out and lay it gently down on the left side panel (use a towel to protect the side and absorb any water). Then, from the now exposed underside there is a black rubber pipe connected to the pump (black) coming from the main drum. Use some pliers to pinch the steel spring that clamps the hose in place and remove. Then using your fingers (there is nothing sharp in there) see if you can find any blockage.
I REMOVED: A pound coin, a dairylea slice wrapper and a piece of kinder bueno packet.
Carefully replace the black hose making sure it is fully on. Replace the drain hose, reconnect the water pipe and turn the water back on. (check to see it's dry with no leaks). Plug it in, turn on and that for me was it. Job Done.
Posted on Feb 01, 2009
SOURCE: error code F-05 water not leaving washing machine
F05 flashes due to electric oven control failure. The solution is to replace the electronic oven control (also called EOC or clock).
Posted on Dec 12, 2008
57 varieties
  • 1653 Answers
SOURCE: Hotpoint WF840 W machine still full of water error code F 05.
Do the following.
  1. Switch off the machine and disconnect the mains power.
  2. Remove the access panel on the lower right front of the machine.
3. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray. It may take a few minutes to empty but it will save a small flood.
4. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
5. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
6. Reconnect the power and switch the machine on.
If the problem persists then do the following.
7. Switch off the machine and disconnect the mains power.
8. Check the electrical connections at the pump and make sure it is operational.
9. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
10. Makes sure the pump appears clear and that the impeller looks in good condition.
11. Reconnect the hoses and then reconnect power and switch the machine on.
12. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Posted on Oct 23, 2009
  • 197 Answers
SOURCE: Hi I have a hotpoint washing machine model wt761
You have a blockage not allowing the drum to empty.
Check for blockages via the pump filter and the hoses
F05 means blocked pressure switch
If it still won't work come back to me
Posted on Oct 25, 2009
  • 53 Answers
SOURCE: error code F-05 for hotpoint aquarious washing
your pump/filter/outlet hose is blocked. clean it all out with the power off.
Posted on Oct 30, 2009
My washing machine hotpoint ultima wmd 940 is dead no power ,but the fuse in the plug is ok.
the mains lead normally goes to a connector block at the top of the machine then onto a mains filter both of these can fail ie burnt out connections ect check these out first remember to un-plug machine first
Nov 10, 2014 | Hotpoint Washing Machines
Hotpoint ultima wmd 940 program counts down but machine not working
Good afternoon
Your washing machine has more difficult problems than I have met before.
The only thing I can advice you is to get an electrical expert from
a shop that specializes in your type of machine.
Whille you are waiting you could browse on the internet and look at MANUALSONLINE.COM
kolbrun
Feb 26, 2012 | Washing Machines
Hi i have an ultima wmd 940 hotpoint washing machine !! i have a split in the plastic piece which supplies water from the inlet to the tray!! what is this piece called and were could i get a picture of the...
a few sites yu can get on and actually type your model number and see the part you need are as follows:::
www.repairclinic.com
www.apdepot.com
www.sears.com
you should be able to type your model number on these sites and locate your part.
Jan 03, 2011 | Hotpoint Washing Machines
Wmd 940 wont fill,, water pressure ok,hose ok,f01
Solanoid. does it fill on any other programe. try hot wash, then rinse
Feb 01, 2010 | Hotpoint Washing Machines
My Hotpoint Ultima WMD 960 displays "F04" on the display panel before the programme ends. Have cleaned the filter and it worked OK in spin mode and finished normally but now have put in a washing load, it...
Error code F04 means pressure switch jammed on empty.
Do the following.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside the hose.
Remove the hose on to the pump, and check for blockage or obstruction here as well.
Please rate my solution.
Thankyou.
Jan 25, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hi I have a hotpoint washing machine model wt761 and it has stopped working, it will not drain. The display is showing an error code F-05. Can you help me please.
Oct 25, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WF860 Washing Machine displaying error F-65
there is no F65, perhaps it's F05 which means it will not empty water (not oumping out). Should av gone to specsavers !
Apr 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
F-05
F05 machine means "Pressure switch jammed"
Try first cutting power to the machine for two minutes, if that reset the code, then the problem was temporary.
If not :
Check if the machine drained, or if water is not being drained.
If drain system works .take off the the lid , locate the switch, it must have a small hose attached.
Remove the rubber hose attached to it, and unlock it by blowing into the hose.
If the water does not drain, this will also cause the pressure switch error.
In this case check the drain hose , and the drain pump.
Finally, ta faulty timer control board can cause the error, you test the control PCB if lid switch and drain system are OK.
Apr 01, 2009 | Washing Machines
Washing Machines Logo
802 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
