Question about Ryobi Garden
How to install replacement line for a Ryobi 18v weedeater
I have a Ryobi P2000 18 volt weedeater. It has run out of line. I bought replacement reels but can't figure out how to install it. I don't have a manual. Please help!
    Problem Solver:
  • 14 Answers
The long bolt coming down at the end shaft like place reel over bolt then turn back and forth slowly while pushing upward and it should lock in and take knob or bolt at end and tighten to the right.
Posted on Jul 07, 2010
When looking at the bottom of the trimmer there are two yellow tabs. These are connected to the cover. Push the two yellow tabs in and pull the cover off. You can now see the spool the line goes on . Pull the spool straight out. Feed the new line through the hole in the base of the trimmer. Run the other end through the ridges inside the spool to lock the line in . Continue to wrap the line around the spool. The proper direction should be printed on the spool...mine was clockwise. Replace the spool in the trimmer. Put the cover back on then cut the line. I left enough so the trimmer would properly cut the length. Add power and turn on trimmer.
Posted on May 19, 2013
The line that I'm looking for came as stock supplied when I bought the trimmer.I can't believe that Bolens doesn't have a scource for replacement line. Help. Gene
Genuine MTD 791 181460B Reel Line Assy McCulloch Ryobi Troy Bilt Bolens OEM
Reel and Line Assembly
Bolens String Trimmer Spool 791 153577B
the spools come with line already installed,they are all for bolens,line is generic,you buy your own line,there are 2 different sizes,and a bunch of types,like round or star,you buy generic line because bolens wont make any money if they sold "BOLENS" line.
Jul 11, 2015 | Garden
How do I get the old line trimmer spool off of my Ryobi 18 volt cordless trimer
When looking at the head, you will see to two gray rectangle pieces. Press them both at the same time between your thumb and forefinger and then pull. It should come unlatched and reveal the line spool on the inside
Jul 25, 2014 | Ryobi Lithium Ion 18 Volt 18v Cordless...
How do I advance the line on my Ryobi 18V trimmer?
full throttle, tap on ground, line should feed automaticaly.
Jul 23, 2014 | Ryobi Lithium Ion 18 Volt 18v Cordless...
Why does ryobi 18V cordless not charge
Please check the LED status of your charger. If both of the charger'sLED flashing, but it can charge a good battery. Than the battery is defective, you may replace a new Ryobi P206 Battery http://www.batteryshops.co.uk/tags_products/ryobi-p206-12-18v-2-speed-drill-driver-battery_6854.html
May 11, 2014 | Ryobi 18v Cordless Drill - P206 18 Volt V
Cross section of ryobi 18v trimmer
the wiring maybe disconnected, either at the switch or down near the head of the trimmer
Sep 09, 2012 | Ryobi Lithium Ion 18 Volt 18v Cordless...
How do you open the bottom to install cutting string model 130R
If you mean on your weedeater, the bump knob unscrews and the reel then comes out. The bumpknob may have a left-hand thead, and watch the direction the line must be wound. There are usually arrows which show which way the line goes.
Jan 22, 2011 | Ryobi Garden
RYOBI weed eater.hard to start. starts then stops
I have a ryobi doule line bought in 1997..Had same problem put new gas cap on and problem solved..could not get air in....
Aug 01, 2009 | Ryobi Garden
What is the replacement fuse for a Ryobi 18v charger?
The fuse in mine said 4 amp. I have also used. You can use a 4 amp or lower to replace the original one that blew.
Good Luck
Mar 07, 2009 | Ryobi Multi-Volt Battery Charger
Replacing a reel head.
Might be a left handed thread. turn to the right is off.
Aug 23, 2008 | Electrical Supplies
Ryobi Trimmer
To install string in the Ryobi you do not have to disassemble anything: Line up the two arrows on the inner and outer reel, remove any excess string, cut two pieces of string about 10 feet, feed line in the side holes, secure line in hole where it comes out the bottom (it only takes about 1/4in. to do so), pull strings tight, then turn the inner reel counter clockwise to wind it. If it sticks a little just pull line a little.
To remove the inner spool in order to remove line that has broken inside, to clean the mechanism, or to perform other maintenance, grasp the outer reel and unscrew the bump knob counter-clockwise. Mine is often very tight and requires pliers to get enough leverage. While you are in there, clean the inner reel and the inside of the outer reel to improve feed performance. The shaft rarely needs cleaning. Do not lubricate. After re-installing the reel, add string (0.080") as described above.
Sep 09, 2007 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
963 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
