Question about Tyan Toledo i3010W (S5197G2NR TOLEDO I3010W) Motherboard
Sys Init Error - Halt - But I want it to skip All Errors
We have quite a few Tyan's at my web hosting job. A few of them boot up with System Init Error - Do you want to Continue or Edit Setup.
I want it to continue automatically. I have set Halt On Error to No Errors but it still halts on this error, where all you have to do is his continue on the box and it boots normally.
  • darian69 Apr 19, 2008
    map9966, I appreciate the reply here - This is actually a web server running Linux. I'd also rather not re-format the box but I can bring it down to go into BIOS or run updates. Any other ideas?
    President:
  • 2,351 Answers
Darian69, windows did not setup correctly. Double check all data cables & power cable connections. (Tight fits).
(This is not an uncommon error). Please download the manufactures drive utility software for a bootable floppy disk or bootable cdrom disk. Test/check & setup the drive, (formatt). Than install windows. Once installed, turn on windows firwall & install nic driver software. Run windows update. Check for hardware updates & install. This should fix the system halt.
Please let me know if this stopped the error message.
Mike
Posted on Apr 19, 2008
  • Mike Peluso
    Mike Peluso Apr 19, 2008
    No sorry, this is a common issue with win98.
    Suggest you repost & make sure you mention the system runs
    Linux. The more info you post the better are your chances a tech can help.
    Have a good day!
    Mike
What is the blue screen errors? Why will they come? What should we do if we get those errors? What will happen if the error will come?
Hello, I understand you are concerned with blue screen errors. To keep it simple, Blue screen errors appear majority due to corrupt drivers crashing, or services suddenly stop running. This is generally due to a virus, but can be as simple as a corrupt driver.
I understand that things can go wrong and issues can occur that are out of your control. As long as you keep your computer information updated as much as possible you shouldn't run into any issues.
Now if you are running into an issue now with a bluescreen, a few proactive things you can do, is boot into safe mode and run some security scans as well update the PC with networking.
Knowledge is power
Jon Justiniano
Customer Service rep with:
Web Hosting Dedicated Server Hosting Domains AIT com
Nov 05, 2014 | ErrorExpert Computers & Internet
Sony vaio vgn fw340j windows vista system halt error 0x00000124 and 0x000009c
If you are asking what it is look here:http://www.pcauthorities.com/pc-errors/how-to-repair-blue-screen-errors/comment-page-11/
Nov 07, 2012 | Sony VAIO VGN-FW340J/B 16.4 Notebook PC
Acer laptop gets hanged every time it is opened. on dignosis it shows code 0211= key board error.pl advise
Try this:
  • open BIOS
  • Look for HALT settings
  • Change settings of HALT ON ALL ERRORS to HALT ON ALL ERRORS EXCEPT KEYBOARD
  • Wait for windows to boot then try your keyboard again
Oct 19, 2010 | Acer Computers & Internet
How do I run a Fujitsu PC headless?
while booting press F2 to enter to bios setup.
in the main tab go to Boot Features.
the first point in Boot Features is POET Errors will be "Halt On All Errors" then you have to change it to "No halt On Any Errors"
May 13, 2010 | Fujitsu Siemens ESPRIMO P2500 PC Desktop
Chassis Intruded, Fatal Error...System Halted
you need to go into the bios of your pc.....usually pressing the delete key when you see the first logo screen after booting up....look for a section that relates to errors and what the bios is supposed to do when it encounters an error.
i.e if you see a line in the bios that says "halt on all errors" disable it and when you next boot up the bios will not stall.
Mar 20, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
I have an ei system 103a desktop i have had to sytem restore now when i turn pc on it tells me to press f1 to start windows i have tried going into the bios and boot from hardisk but still have the problem...
The 'Press F1 to continue" message is a result of an error caused as the BIOS does its hardware checks during the boot process.
The BIOS boot process (bootstrap) preceeds the loading of the operating system.
The most amusing example of this occurs if you unplug a ps2 keyboard,
1, it generates the error
2, pressing F1 does no good because the keyboard is not plugged in.
3, if its ps2, you will need to do a hardware reset after plugging the keyboard in again.
The bios can be set to 'halt on'
'no errors' which will stop the error message appearing.
'keyboard errors' see above
'all errors' any hardware failure detected by the bios will halt the boot process and give the above message.
Mar 11, 2009 | Computers & Internet
Erratic behavior - system halts with blue screen with error codes
sounds like serious memory errors. download and boot to "memtest86" to terst your ram for errors, but it may also be the memory controller.
you can try also to swap slots between the memory sticks and see if it works better with the sticks swapped.
Oct 15, 2008 | EliteGroup KN1 SLI Extreme Motherboard
MotherBoard Problem
Is this a new system? Does your system still boot? Do those things work when your system boots? Is your BIOS set to halt on system errors?
Apr 10, 2008 | Intel D101GGC Motherboard
Logitech drivers causes system error using XP. LVckap.sys
View this site for possible solutions http://forums.logitech.com/logitech/board/message?board.id=quickcam_software&message.id=518
Jan 19, 2007 | Logitech QuickCam Orbit Personal Web...
Tyan Toledo i3010W (S5197G2NR TOLEDO I3010W) Motherboard Logo
633 people viewed this question
Top Tyan Computers & Internet Experts
Jerry Umali
Larry Chandler
General Systems...
Are you a Tyan Computer and Internet Expert? Answer questions, earn points and help others
