Question about Haier 3.5 cu. ft. Chest Freezer HNCM035E
I noticed a crimp in one of the copper tubes
I just bought a new freezer and before i pay someone to take it up several flights of stairs i want to know if a bend in one of the copper tubes leading from the compressor is a problem. It doesnt appear to be completely closed off but is a rather suverse sharp bend.
    Champion:
  • 274 Answers
See if the repairman can come out and replace,it may not cool properly
Posted on Jul 05, 2010
Testimonial: "i got an almost instant response"
Need to disconnect water line at back of frig to move it temporarily while floor is replaced. Connected with compression fitting and ferrule.
You may be forced to cut the copper pipe and buy a new compression fitting and ferrule and add it to the cut off end of the copper tubing when you decide to re-hookup the refrigerator.
Remember to cut the pipe , if you choose to do so, with a tubing cutter so as not to "smash" the cut end.
This problem can happen any time dissimilar metals are joined, they can "freeze" together.
God bless your efforts.
Apr 07, 2016 | Freezers
Why will it not come on?
The rust shouldn't make any difference.
When you plug it in, does the interior light turn on? If not, suspect the wall outlet - test it for power by plugging in something else. If the interior light turns on, listen very closely to the freezer. It should hum. If it doesn't, toy with the freezer control inside - it may just be turned off. Turn it to about midpoint and listen very closely to it again. If still no hum, wait a short while, then feel carefully on the outside of the cabinet - it may be running through a defrost cycle. The outside of the cabinet may get warm while that's happening, especially around the door gaskets. Wait a while (half an hour, an hour, for the defrost cycle to finish - the freezer should run then.
If it never hums, then the compressor isn't running, so adding freon won't make any difference. Instead, suspect the defrost timer - that's a little electronic circuit board inside.
If it HUMS but never gets COLD, then you potentially have a freon leakage problem. It's difficult at best, though, to refill a refrigerator or freezer - they don't usually have refill taps.
Oh, yes. If the internal light never comes on but you've proven that the wall outlet has power, it's entirely possible that the plug is bad and needs to be redone.
Jul 29, 2014 | Kenmore 12.1 cu. ft. Upright Freezer 2826
Why is my freezer not freezing
I had this happen to my freezer and I had to install a fan in the freezer by a repair man and then it worked like brand new.
Jul 18, 2012 | Bush BAF55143W Freezer
Turn freezer on and started to cool and to see it still works was sitting for 3 years and it did and i turn it off and clean it and turn it back on and it dose not cool but pump get hot now what you thimk...
The reed valve in the compressor has failed, or the dryer unit is bloked. if you can access the rear of the freezer, with power off, tap the compressor gently with a solid object (hammer), then start the unit, also, if you see the copper tubes near the compressor, you will notice one of the tubes feeds into a copper barrel object about 3-4 inches long, it will have a fine copper tube comming out at the other end about 3mm thick, with the unit on, tap this object with the back of a bread and butter knife a few times with about the same force as to open a nut ( A good tap). Should do the trick if the unit is repairable.
Hope that helps, dont forget to vote and get back to me for further solutions if this fails..Russ
Mar 27, 2011 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Side of freezer seems warm
Hi!!
Don't worry about the line, it is supposed to be the way it is. If you are talking about the condenser coil, located on the back bottom part of the unit, with a small fan in front of it, yes, it is supposed to be hot.
The condenser job is to disipate the heat absorbed by the evaporator (the coil inside the freezer). Make sure the condenser is clean and condenser fan is working, also, make sure there is air circulating thru the back of the unit to help cooling the condenser.
The noises you hear, are probably the defrost coil melting the ice on the evaporator, this function is on a timer and happens 3 or 4 times a day.
Good Luck!!
Aug 03, 2010 | Woods 247 cu. ft. Upright Freezer FU25
My Maytag side by side with water dispenser and ice maker doesn't work. We bought a house - never lived in - and the fridge and freezer work fine. We replaced the water filter and find that no water comes...
The sadle valve is located on the copper pipe where the tube attaches to your water pipe in the house. Shut the water off at the saddle valve. Remove the hose from the rear of the frig on the water inlet valve and put it into a pail. Tunr the water on at the saddle valve and see how fast the water comes out. Some times if the saddle valve is installed on the bottom of the copper pipe they will get corrosive and restrict water flow. Open and close the valve several times to make sure it is clear and reinstall the hose to the rear of the frig. Turn the water back on to see if it works.
Dec 29, 2009 | Freezers
Maytag Freezer mqu1556aew 2004-07.Ice buiding up on the bottom of freezer.
if self defrosting model check frozen drain in freezer
Aug 09, 2009 | Freezers
Can a fridigidare fc5n chest freezer be recharged
If the unit's Compressor is not starting you need to bypass everything and test the compressor directly to see if it will run. best done buy a qualified Appliance tech unless your from and electrical background? also when the motor/compressor is tested they can see if the freezer starts to freeze down. Because of the cost of changing the Compressor and the fact that a lot of the gas leaks in these units can not be repaired due to the leak being inside the freezer walls a new Freezer is still the best option. Also when a Fridge or freezer is left to sit for 5 years the Compressor is likely to have seized and rust may ave formed inside units copper pipes. Cheers
I'd recommend a new Fisher and Paykel Chest freezer with a extended warranty. cheers
Mar 27, 2009 | Freezers
ICE BUILDUP ON BOTTOM OF FREEZER, DRAIN HOLE FROZEN
There is normally a small filiament of metal which is attached to the defrost element and conducts heat down the drainpipe preventing ice build up. You can pour some boiling water onto this area and even wriggle a piece of plastic tubing down the drain pipe to dislodge any blockage. For future prevention, you can attach a piece of copper wire around the defrost element (in the absence of the original filiament) and extend it down the drainpiple
Mar 05, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Leaking oil from crimped copper line
first off there's probably no refrigerant in the unit. the amount of oil is probably minuscule to what the system has.
Dec 20, 2008 | Kenmore 5 cu. ft. / 142 liter Upright...
Haier 3.5 cu. ft. Chest Freezer HNCM035E Logo
100 people viewed this question
Top Haier Freezers Experts
Victor Nwachukwu
Victor Nwachukwu
christian nielsen
jdthefixer
Are you a Haier Freezer Expert? Answer questions, earn points and help others
