Question about Sony KDF-E42A10 42 in. LCD Television
When the Lamp blows out does the Audio go out as well?
  • Sony Master
  • 8,457 Answers
No,the lamp does not effect the sound.If this happen,after replacing the lamp.Just resetting the tv back to factory setting in ur tv audio setting,go down to resetting,should come back.Not than,the Tuner board have problems.
Posted on Jul 05, 2010
  • FixYaDWS Oct 02, 2010
    I had my lamp go out (15000 hours) so I turned off the set. When I turned it on the next time, then I heard the "pop" and the audio went out. I vacuumed the inside of the set, replaced the bulb and now everything is back to normal. Be sure to reset the bulb count, or you may have trouble in the future.
On RCA HDTV wh74xy1 lamp blows out every three months
fan has a lot of dust on it.get a can of air take lamp housing and hold fan fins and blow off dist also there is a nothe fan on dlp chip.in front. take of lower back cover easry to do.good luck
Nov 17, 2013 | RCA D52W20 52" Rear Projection HDTV-Ready...
I sheint the lamp, but now is like the lamp .is
Hi,so you put a brand new lamp in and still didn't work ? Did you take it out and looked burned? If it did blow up again or didn't light up at all it could be a problem with something else.The most common failure is the ballast which is the board that powers the lamp.When that board gets to weak or provides a higher voltage it could make the lamp blow.ALso make sure everything is properly closed,(door cover) and reset the lamp hrs.
May 03, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Blows main 3-15al fuse after 240v brown, out all secondry fuses ok can find no shorts in primary or rectifyer stage
Use a series 100 watt lamp in the hot side of the power to allow testing wothout popping the fuse... the lamp will limit the current.
If there was a utility power "incident", report that to your power company as a possible damage claim before doing anything.
Jan 06, 2010 | Denon AVR-2805 Receiver
The fuse has burned out in my projector benq MP610. So I opened the projector to replace it : same result. I verified, the lamp is also burned out. Do you think the burned out lamp can make the fuse to...
before a lamp blows it draws more current than it usually uses, but since it uses dc, it couldn't blow the ac fuse. but if the regulators on the ballast or power supply were bad, it would blow the lamp and draw ac power, possibly blowing the fuse.
Dec 02, 2009 | BenQ MP610 Multimedia Projector
My eiki LC-xnb4m will power on but shuts off after about 60 seconds. It doesn't shut off completely.it just drops the input signal (audio and video) and the fan kicks on heavy for a few minutes. Then...
may be overheating. blow out the projector with canned air. the dust keeps in the heat that the projector is trying to expell. also check the lamp for bulges and dark spots. if you have any of those, replace the lamp. if the lamp is new, check the colorwheel for a high-pitched whir. if you don't hear it, replace the colorwheel. otherwise, replace the ballast.
Jul 01, 2009 | Eiki LC-XE10 Projector Multimedia...
Replace lamp led light
Have you reset the lamp timer?
Was the lamp module sitted properly?
Remove the back panel and vacuum all the dust.
Also use compressed air to blow out the dust from the inside.
Do not blow into the fan on the right as that will get the dust inside the lamp housing.
Nov 22, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Dead lamp
The sensor is located on or near the lamp compartment on the back side. If your lamp keeps blowing it may be the lamp cooling fan not working. However are you sure the lamp is blowing? Press menu and device on the front control panel both in together for 5 seconds and see if the led blinks a two digit code, then let me know the code. Please respond to this same post.
Jul 08, 2008 | Mitsubishi WD-57732 Projection Television
95 P/U Parking Lamp Blows Fuse
Finally fixed it. Had an open wire from professional electrical alteration made to meet vehicle code in England--closed the wire. No more problem.
Jun 07, 2008 | 1995 Nissan Pickup
Sony DLP KDF-E60A20
Has anyone experianced a problem with sony DLP mod# KDF-E60A2 blowing lamp every 30 days? we replaced balast and lamp, still blows every 30 days or less.
Nov 26, 2007 | TruTech PLV16260 Television
Weird Rapid Metallic Popping Sound
I think i have the same problem, but i can get audio still. did the poping plinking sound come from the inside back panel of your TV? it sounded almost like a arc wielding noise?
Sep 29, 2007 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony KDF-E42A10 42 in. LCD Television Logo
294 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
