Question about Bosch Axxis+ WFR 2460 Front Load Washer
Leaking drain pump
I need to replace the drain pump on a Bosch WFR2460. Can I do the job with access from back panel? I have the panel off and have located one screw in the front of the machine that holds the pump in position.
    Champion:
  • 274 Answers
Yes its very semple takes about 20min.
Posted on Jul 05, 2010
How to replace a washer drain pump on a MAVT634Aww Maytag washer.Thanks
It's a fairly simple job. Unplug machine. Lean back on back legs so you can access bottom / underneath machine. Remove belt. Place machine back on all 4 feet. Remove access Panel on back of machine in order to access Pump which is in bottom floor of machine. Remove 2 hoses from pump. There will be water that escapes so have several thick towels to soak up water. Pump is held on by 3 self tapping screws. Remove those, and pump will lift right out. Place new Pump in, reinstall screws and hoses. Reinstall back Panel then reinstall belt. You may want to leave back Panel off until you inspect for hose leaks. Don't forget to plug machine back in.
Sep 06, 2017 | Maytag Washing Machines
Bosch E13 error on washer - shows e-13 and door will not open.
Hello & Welcome to FixYa
E13 error in your Bosch WFMC washer is a drain error and is displayed when the drain time exceeds & the washer is unable to drain so the door won't open sometimes when this error is displayed. You will have to clean the drain trap in the bottom right hand corner. You can stick a straighten paper clip in the access panel located inside the front bottom panel through the whole and then turn the access panel counter clockwise to unscrew the plastic drain cap behind it. After everything is cleaned and the error returns then replacing the drain pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jul 30, 2011 | Bosch Nexxt 300 Series WFMC2201UC
Hi I have a Bosch dishwasher . The red tap symbol is showing . The little filter pump is spinning but not pumping . It continues to run when door is opened . Can you help please
sounds like you have a water leak. The machine is fitted with a leak detection device that runs the drain pump constantly as a safety mechanism. If you want to look your self you will need to pull the machine out and tilt it back and if possible remove the bottom panel, should be 4 screws, this gives you access to the components. If it doesn't come off then you will need to remove either 1 or both of the side panel, its just a number of screws holding them. Then see if you can see where the leak is coming from, you may need to order a new part. Hope this helps.
Mar 07, 2011 | Bosch 24 in. SHV55M03GB Built-In...
Mar 07, 2011 | Bosch Dishwashers
Noisy spinning and water leak
The noisy spinning on this model washer is usually the drain pump bearing going bad which could also be a possible cause of the leak. Unplug the washer, Tilt your washer back and rest it against the wall. Remove the belt and manually turn the drain pump pulley, if it is hard to turn either way or is grinding or noisy it will need to be replaced. The leak is a little harder to find. Remove the front bottom and top panels, run the washer, stay back with a flashlight and look where the leak is. If the drain pump is bad it is likely leaking. Next check the center, bottom of the tub for leaks, if the leak is her it is likely the cause of both problems. The tub seal is leaking and has ruined the tub bearing. The tub seals and bearing would need to be replaced. Very involved job, and I would suggest you call a servicer with the expensive tools and knowledge to do the job. There is also a bearing on the bottom of the transmission which could be noisy but would not cause a leak. Hope it is only your drain pump.
Please rate this post. Thank You
Jan 22, 2010 | Maytag SAV571EEWW Washer
Bosch wfr2460
The 03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the block is in your plumbing, and not in the machine. Assuming that your filter is clean.
Pl rate me ‘very helpful’ for the free help!
Dec 01, 2009 | Bosch Axxis+ WFR 2460 Front Load Washer
My Bosch 100 series won't drain or spin. How do I
If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
9. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 11, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch wfr2460 part number question
Try repairclinic.com  We were able to find parts for our Bosch WFK2401 washing machine and our Asko dishwasher...they list the part descriptions and show pictures.  It might take a few minutes to sift thru the things but i bet you can find your part.  FYI, shipping has been great...just a day or two to arrive after ordering.
Jan 11, 2009 | Bosch Axxis+ WFR 2460 Front Load Washer
Bosch wfr2460
after ensuring the sump hose and transfer hoses are clear clean out the pressure system to ensure the water wash level is not more than usual, secondly check whether the waste hose is not back filling from a sink u bend and also check the sink u bend for blockages (usually fat).
if all ok start to check the wiring connections from pump to pcb board, if these are ok then there may be a fault on the board. (pumping problems are usually easily solved with the above proceedure, the pcbs are rarely at fault for bosch but you may be the unlucky one !). tony
Aug 22, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Bosch WFR2460 Leaks
are you sure it only happens in the spin cycle? and is the leak comming from the bottom front of the washer? most front laoders will leak due to a tear in the belows. that is the rubber boot that seals the washer tub to the front panel. if there was a hole or a tear in the bellows it should have a leak inthe wash cycle also. but there are also other possibilitys too.but its strange to only leak in a spin cycle due to the washer is extracting the water and not adding it. so check and see if it leaks in the wash cycle to and get back to me and we can go from there. looking through my training manual i dont see what could cause a leak in just the spin cycle
Aug 04, 2007 | Bosch Axxis+ WFR 2460 Front Load Washer
Bosch Axxis+ WFR 2460 Front Load Washer Logo
100 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
