Question about Kenmore 91112 / 91114 / 91117 Electric Kitchen Range
Oven will not heat; no response to oven controls. Burners ok
    Champion:
  • 274 Answers
It sounds like the heat element is out and needs to be replaced
Posted on Jul 05, 2010
The burners and pilot light work but the oven will not light. We need to figure out which part to replace. It is a unit converted for propane and has no electric parts.
Ovens generally have a couple of safety devices fitted meaning no gas gets to the oven unless there is sufficient gas pressure. There is also a valve controlled by a thermocouple. The valve prevents gas passing. There is a bypass operated by either a button or pressing in the oven control knob which allows gas to flow to the pilot light (and sometimes the burners). When the pilot light is lighted and has been burning for about half a minute with the flame correctly set to heat the thermocouple bulb the valve will switch on the gas supply and the knob or button can be released. The burners will initially be at maximum until the oven thermostat reduces the flow to maintain the temperature at a preset level.
If gas isn't reaching the oven and the pipework, oven control and thermostat is ok then the safety thermocouple is either defective or wrongly fitted.
Apr 24, 2016 | Kitchen Ranges
How to bypass thermal fuse block to see if oven will heat up
Hello Andy;
My name is Peter. I am a retired field service appliance technician.
I am sorry for the above response. Some advisors on this site are not knowledgeable in the field and answer questions regardless of professionalism and rudeness just to build up points on this site.
Anyway, I am here to help you.
First you have no thermal fuse and you power is 220 and 240V.
There are only three components that control your oven:
1.0 The heating element - Inspect the heating element (Metal bar) inside your oven. Is there a crack in the element. Inspect the two connectors of the heating element against the back wall for corrosion. When you turn the oven on do you see sparking? Then you have a bad heating element.
2.) Ok, the heating element is good.
3.0) Turn on your broiler. Does it glow bright red? Then your thermocouple is good.
4.) Then your problem is in your oven control board. Sears will cost about $256.00.
I just purchase a remanufactured oven control board over the internet for my customer for $30.00. Easy repair.
Send me your model number. Either on the top of your oven door or on the face of your oven after you open the door.
May 08, 2015 | Whirlpool RBS305PDS Electric Single Oven
My spectra stove's oven is not working, the burners work, the broil works, but my oven will not heat up
Hi.
The JBP78 is electric, since you are talking about a gas oven I think the model is incorrect.
Talking about a gas ovens:
If the oven is not heating up and both broiling and baking burners are working and coming up then check the temperature probe sensor and the control board.
If one of the two burners is not firing check the ignitor, the burner and coil, the burner and flame sensor. The most common problems come from defective ignitor.
Regards.
Ginko
Sep 09, 2011 | GE Spectra JBP78 Electric Kitchen Range
This an old range with side by side ovens which work perfectly. the 4 burners slide out, all 4 elements will heat, but do not get to a high heat, is there a control which affects all of the elements ...
Hi and welcome to FixYa, I am Kelly.
This sounds like your missing 1/2 of your input power. Go to the main CB panel and cycle the Range CB to OFF by pressing it hard to off and then back on. Test your burners again.
Still have the problem? Start looking in the area of the house to oven power connection / terminal block in the back of the oven for signs of HOT / burned terminals.
Still have the problem... Last check is to check wiring in the main controls area.
Without your model number this a VERY generic response but when all burners present the same symptom it is usually input power or control related.
If you respond with a model number I wil see what I can find that may help you troubleshoot your Oven.
Thank for choosing FixYa,
Kelly
Mar 23, 2011 | Microwave Ovens
Kenmore electric stove oven does not work at all top burners ,lights and control pad all functioning
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Dec 11, 2010 | Ovens
GE Profile Stove baking option not working
Possibly the bake igniter, the temperature sensor or the electronic oven clock/control. Does broil mode heat properly or does it run cool also? If broil heats to the proper temperature then the temperature sensor is probably ok. That leaves the ignitor or the controller which takes some more troubleshooting. If it is the controller, we repair them at www.fixyourboard.com.
Aug 31, 2009 | GE JGRP17 Gas Single Oven
Ge range model # js968 has power but cooktop & oven don't work
Check for proper power (control panel is 120V, burners and heat element are 240V) You may have lost connection in one of hot wires causing the burners/elements not to work yet the control panel still will
clarkco
Feb 25, 2009 | Ovens
Sf195lehz5 free standing gas oven,
Check both gas valve solonoids for 216 ohms [blue broiler wire to the orange common and red oven wire to orange common] both must be ok.
Check oven temp sensor for 1080 ohms.
If above are ok then the problem is either the spark module or the control board.
Since the gas valve was not opening and there was not ignitor sound I replaced the spark module for about $90. You have a 50-50 chance of being right.
My range is relitively new and I'm haveing an oven light problem which I traced to the control board so I may replaced this board to for about $200.
HS
Oct 05, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Oven not heating KitchenAid KERC506HWH3
Need to check and see if you are getting 220 volts to the element or if the element is showing resistance with an ohm meter. Any resistance means it is ok. If you are not getting voltage to the elements and resistance is ok then the control board is bad. Note: Always check outlet for proper voltage first! Never know when a breaker has gone bad. Should have 220 volts from line 1 to line 2 and 110 volts from line 1 or line 2 to ground.
Nov 16, 2007 | Kitchen Ranges
Samsung RGSF5330DT Range dead.
try checking control panel connections they might be dirty if not then board is proberly bad
Aug 29, 2007 | Hotpoint RGB745 Gas Kitchen Range
Kenmore 91112 / 91114 / 91117 Electric Kitchen Range Logo
82 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
