Question about Fagor LFA-65 Stainless Steel Built-in Dishwasher
New part installed, now a new problem
Fagor LFA-65SS
Initially had an overheating problem, 6 beeps on the alert. Was told I needed a new heater. Got the part and installed it, now the machine runs as soon as it is plugged in, and an alert sounds for an overflow. There is no overflow occurring, could I have connected the heater incorrectly? All of the connectors are location specific except for one push on connector, and though there are two locations to connect, both appear to be on the same connection.
Ideas, suggestions, repair manuals? Help
Randy
    President:
  • 1,891 Answers
If washer was over heating the element was working . there also should be a thermostate to control it . I would think that the themo would be bad and should have been replaced with element . . ck old element for short and do replace tempt control . / if this does not correct problem . then look at the main prosser control as being the problem . and do re ck all wireing . . and look for over heated wires that may hace melted to frame of other wires .. hope this helps mm
Posted on Jul 05, 2010
DOOR FELL OPEN AND WON'T CLOSE, FEELS VERY HEAVY
Dishwasher doors are balanced by a set of opposing springs that, over time, can stretch and or become defective.
Get your model number and look on line on an Google search or bing. One can find a number of sources for the needed parts to repair this problem.
Aug 21, 2015 | Fagor LFA-073 IT Dishwasher
Why does my fagor dishwasher stop mid cycle and show f 6 with several beeps
I have already provided answer to a later post on this topic. Heater problem.
Sep 19, 2014 | Fagor LFA-013 Stainless Steel Built-in...
Fagor LF 65IT beeps 4 times a few minutes after switching on and all lights flashing on display
This is a flood warning. You must have water in the bottom of your machine which has raised the float and activated the flood switch. Open the lower front panel on your machine and for where the leak is coming from.
Apr 03, 2012 | Fagor LFA-65 IT Dishwasher
Hi, my new FAGOR 2LF-013S has no problem fortunately, but i have questions. is it possible i connect the water hose to hot water mains ;if ok; does it lead to power consumption reduction, or any other...
some fagors have a built in water heater (not all) your manual should say so , even so I allways connect my machines to hot supply as yes it's less expensive to use domestic heater for water , the heater inside (if equipped) machine just boosts the temp for cleaner dishes
Sep 11, 2011 | Fagor LFA-013 Stainless Steel Built-in...
My door will not shut and there is no tension on
make sure the strike is adjusted correctly.. it may have gotten bent out of place.. the strike is the little metal tab that comes off of the top of the center of the tub and goes into the door when you close the door.
Aug 29, 2009 | Fagor LFA-65 IT Dishwasher
FAGOR DISHWASHER LFU073IT WITH F9 COMING UP ON DISPLAY
Problem with the distributor motor. It is a small white plastic part which receives water from the heater, and alternatively distributes water to upper or lower difussors. If the motor locks, or the internal sensor doesn't sense the position well, it will show F9. Motor can be repaired in most cases, and at last, it can be swaped
Nov 28, 2008 | Fagor LFA-073 IT Dishwasher
Fagor dish washer VFU-05S
What do I do to overcome the fault 'F3' accompanied by beeping ?
Jul 15, 2008 | Fagor LFA-019 SS Stainless Steel...
Beeps eight times
Correct - lack of water pressure at the dishwasher, not the same as whether there is pressure from the line going to the dishwasher. There may be a clog or a valve that is closed.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Nov 21, 2007 | Fagor LFA-65 IT Dishwasher
7 BEEPS!!!!!!!!!!!
Please contact the Fagor America Service Center toll free: 1-877-743-2467. A customer service representatives will discuss the problem with you. If on-site service is required, they will coordinate that for you.
Jun 15, 2007 | Fagor LFA-65 IT Dishwasher
Fagor LFA-65 Stainless Steel Built-in Dishwasher Logo
55 people viewed this question
Top Fagor Dishwashers Experts
dannydoesita
ray gallant
Are you a Fagor Dishwasher Expert? Answer questions, earn points and help others
