Question about Foxconn K7S741GXMG-6L Motherboard
Motherboard is not powering on and generates heat from the power supply
  • 977 Answers
Sounds like a faulty power supply... Time to replace it! :)
Also, read this tip of mine to find out more possible causes to your probem.
Regards,
Pelu.
Posted on Jul 05, 2010
I think it is the power supply. It is a Besttec ATX-200-12Z Rev D mounted in a Compaq 6450NX desktop PC running Windows XP Professional Computer will (intermittenly) start up, and shut down on it's...
While it could be the motherboard it does seem more likely that it is the power supply.
Here are two options to test your theory:
1. If you have another known good power supply or can borrow one, hook it up to the motherboard and see what happens.
2: Or, if you have a known good motherboard or can borrow one (does not have to be the same as yours of course) hook your power supply to it and see what happens.
Jun 20, 2011 | Bestec (ATX-250-12E) 250-Watt Power Supply
What will happen if my desktop computer has many dust?
Dust is an excellent "insulator".
So, your computer will be unable to radiate the heat generated by the CPU and the motherboard and disk-drive and power-supply, and so your computer will run "hotter".
The higher temperature will cause the parts to wear out more quickly, and thus cost you money to replace the failed parts.
Jun 12, 2010 | Biostar MCP6P-M2 Motherboard - v6.0,...
I bought an xps 210 2 years ago. The power supply is dead
It is possible that you picked up a faulty power supply, slim, but possible. Chances are pretty good that you have one of your components drawing too much current on your power supply. The largest power drain comes from your processor and the graphics accelerator cards, however it could be a faulted motherboard or hard drive. You can replace your power supply with a larger capacity unit from a known good manufacturer. If you increase the wattage capability and look with the side off to see if any component is generating a lot more heat than usual. A larger capacity power supply should be able to handle the unusual current draw.
Apr 18, 2010 | Dell XPS 210 PC Desktop
Computer unable to proceed to open Windows during startup due to abrupt power shut-off. The memory, CMOS battery and power supply unit has no problem when tested to a separate computer. There definitely...
Depending on the nature of the "abrupt power shut-off" you mention above, your motherboard ma have suffered a power surge. Not necessarily enough to completely fry the board but perhaps just enough to scramble or destroy some of the chipset on the motherboard. The only way that gaming on your system could cause such a problem is if your system has an inadequately cooling system and you are hard core gaming for extended periods of time generating excessive heat from your graphics adapter.
Sounds like you might need a new motherboard.
Mar 19, 2010 | ASUS P4S533-MX Motherboard
Need a fan for the extreme Power Plus 600w
What a wastage of power ?
I suggest not to fan more but to reduce heat generation.
Better check, why excess heat generated? Surely low power devices overdrived. Just modify it. Like low voltage schottky rectifier. insted of using 20A per channel, they use 3A per channel. Your PCB of SMPS has the hole to cater the proper rectifiers. Just Search the datasheet, replace the overheat component with higher capacity and you solve the problem.
Sometime, poor screwing of heatsink to transistor/devices may generate excess heat too.If you can replace the fan, you must do the other work I recomend. GOOD LUCK.
Jan 29, 2010 | Cooler Master Extreme Power 600 Watt...
Won't charge
This is a common problem for laptops. The power adapter on the motherboard is damaged or loose from the motherboard. This may be able to be repaired by a tech. Be advised though, that you may end up having to replace the motherboard as there may be additional damage to the charging circuit on the motherboard. I would also recommend replacing the power supply if you have this repaired as the power supply plug can also become damaged from the heat that is generated by the bad connection.
Jan 08, 2010 | Toshiba Satellite M35X-S349 Notebook
My Presario F500 doesnt power on.. whats could be the problem.. I can see the green power led on.
do it only if u r a professional..
assuming that the system bios hs not been flashed or updated in a wrong way..if so u gotta replace the m/b..
1st see if the ram(s) is loose/faulty..open n resit it..
check for ac main supply and fuse..next check all the outputs of smps viz. 0v (black~ground); +12v (yellow); +5v (red, green~ps-on, violet~pg & grey~sb); -12v (blue); -5v(white); +3.3v(orange)..if faulty try repairing or replacing the power supply with a standby n see..
if all above are ok..check the cmos/system battery..(above +3v)..
check the cpu fan rotating and the cpu generating heat..try replacing the cpu with a standby (if no heat is generated)..
there may b a chance for m/b's crystal clock generator to b faulty..try repairing or replacing the m/b with a standby..
hope it'll b enough to solve ur problem..
seek professional assistance of ur system admin/vendor....
Oct 31, 2009 | HP Compaq Presario F500 F700 and G6000...
No power in my board
1st check for ac main supply and fuse..next check all the outputs of smps viz. 0v (black~ground); +12v (yellow); +5v (red, green~ps-on, violet~pg & grey~sb); -12v (blue); -5v(white); +3.3v(orange)..if faulty try repairing or replacing the power supply with a standby n see..
Oct 29, 2009 | Intel Motherboard
The natural s supplied generators that we use for
Fix another regulator before gen set gas supply
Sep 13, 2009 | Electrical Supplies
Problem motherboard no power
Motherboard was generated by power supply to running it.. If there is no power when you click the power on, it may caused by the power supply unit problem
Sep 21, 2008 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
Foxconn K7S741GXMG-6L Motherboard Logo
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
