Question about Nokia 5310 Cellular Phone
How to remove the front cover - Nokia 5310 Cellular Phone
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 107 Answers
Check out this link:
http://www.wonderhowto.com/how-to-remove-lcd-from-nokia-6280-0106973/
Posted on Jul 07, 2010
How do i remove the front panel of the asko t721 to replace a broken belt?
REMOVING THE FRONT PANEL
1. Remove the top cover.
2. Remove the lower cover.
3. Remove the door.
4. Remove the front drum frame.
5. Remove the four screws that secure the front panel to the side panels.
6. Remove the two screw that secure the bottom edge of the front panel.
7. Lift off the front panel.
_____________________________________________________
REMOVING THE TOP COVER
1. Remove the three T20 screws at the rear of the
top cover. (Keep the two star washers.)
2. Tilt the cover and pull it backwards.
REMOVING THE LOWER COVER
1. Remove the two 20 torx screws (A) at the
bottom of the lower cover.
2. Next, grasp the sides and pull it forward and
down.
25764946-gtkp3url2ghtdqenstp5bokb-1-2.jpg REMOVING THE FRONT DRUM FRAME
1. Remove the motor (see page 34).
2. T700/760: Remove the exhaust vent by
twisting it free.
3. Remove the wire bundle from the cable clamps
on the front drum frame.
4. Remove the fan housing cover (see page 33).
5. Using flat-nose pliers, take out the thermistor.
6. Open the front door.
7. Unscrew the four screws that secure the drum
frame to the front panel.
8. Lift out the drum frame.
REMOVING THE DOOR
Note : The front door must remain closed during the entire removal procedure (The door magnet will hold it
in place.)
1. Remove the lower cover (see page 24).
2. Unscrew and remove the three screws that secure
the hinge fixture.
3. Lift down the front door.
Dado
Jun 29, 2015 | Asko Dryers
Tip
Maytag Square-Front (1998) and Sloped-Front (1999) Dryers Front Panel and Top...
Most of the internal components of Maytag Square-Front (1998) and Sloped-Front (1999) Dryers can be accessed with the removal of the front panel and lifting of the top cover. The top cover can only be lifted after the front panel is removed. Make sure that power to the machine is disconnected prior to servicing to avoid the risk of electric shock.
The first step is the removal of the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly. Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top cover is held on each side of the cabinet by hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top cover lip. Open the door then lift the front of the top cover and tilt it toward the rear of the dryer.
The internal components of the dryer can now be accessed. Reinstall the top cover and the front panel in reverse of the removal steps.
This procedure is also applicable to Maytag Neptune Front-Load Washers. The only difference is the dispenser bezel removal.
on Apr 28, 2010 | Maytag Neptune MDE4000 Electric Dryer
Tip
Maytag Neptune Front-Load Washers Front Panel and Top Cover Removal
Most of the internal components of Maytag Neptune Front-Load Washers can be accessed with the removal of the front panel and lifting of the top cover. The top cover can only be lifted after the front panel is removed. Make sure that power to the machine is disconnected prior to servicing to avoid the risk of electric shock.
The first step is the removal of the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly. Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the machine.
Remove the four screws securing the dispenser bezel to the top cover then lift the bezel off. Open the door then lift the front of the top cover and tilt it toward the rear of the machine.
The internal components of the machine can now be accessed. Reinstall the top cover and the front panel in reverse of the removal steps.
This procedure is also applicable to Maytag Square-Front (1998) and Sloped-Front (1999) Dryers (Maytag Neptune Dryers). The only difference is the dispenser bezel removal.
on Apr 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
Need to remove front panel located under the filter cover
Press around the panel edges while pulling back. There are probably plastic clip locks that need to be depressed to unlock. Flex carefully, taking care not to break the plastic cover.
May 13, 2015 | Samsung AW1293L Air Conditioner
Change timing belt
timing belt? on a Jeep? 05 wrangler
what engine is this>?
ah the 2.4L
front cover
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Remove the crankshaft vibration damper.
  3. Remove the generator drive belt tensioner assembly.
  4. Remove the timing belt front cover bolts, and remove the covers.
rear cover
  2. Remove the front covers.
  3. Remove the timing belt.
  4. Hold the camshaft sprocket with Special Tool 6847, or equivalent, while removing the center bolt.
  5. Remove the timing belt idler pulley.
  6. Remove the rear cover fasteners and remove the cover from engine.
Apr 04, 2014 | 2005 Jeep Wrangler
Do you need to remove oil pan to remove timing chain cover on a 2000 Cavalier 2.2?
no, here is the procedure. Please let me know if you have more questions.
REMOVAL & INSTALLATION
2.2L Engine
  1. Remove the serpentine belt and tensioner.
Although not absolutely necessary, removal of the right front inner fender splash shield will facilitate access to the front cover.
  1. Install a suitable engine support fixture.
  2. Remove the engine mount assembly.
  3. Remove the alternator rear brace, then remove the alternator.
  4. Remove the power steering pump, then position it aside with the lines still attached.
  5. Raise and safely support the vehicle.
  6. Remove the front two oil pan bolts.
  7. Remove the crankshaft pulley.
  8. Unfasten the front cover-to-block bolts and then remove the front cover. If the front cover is difficult to remove, use a plastic mallet to carefully loosen the cover.
Aug 27, 2011 | 2000 Chevrolet Cavalier
How do i remove the front cover from my nokia c3
Sir please open the back side cover of your phone and there you will see four small lock of front cover press backward the lock front cover will be removed automatically go do it..'
bye
Aug 19, 2011 | Nokia Cell Phones
I want to replace the oil pumpin a 1996 buick lasbre. need diagram
Removal:
  1. Disconnect the negative battery cable.
  2. Remove the front cover from the engine.
  3. Remove the oil filter adapter, pressure regulator valve and spring.
  4. Remove the oil pump cover-to-front cover screws and the cover. Remove the inner and outer pump gears.
Installation:
  1. Using petroleum jelly, pack the pump and assemble the gears in the housing.
  2. Tighten the oil pump cover-to-front cover screws to 97 inch lbs. (11 Nm).
  3. Install the pressure regulator spring and valve. Install the oil filter adapter.
  4. Install the front cover to the engine.
  5. Connect the negative battery cable.
Mar 15, 2011 | Buick LeSabre Cars & Trucks
How you take off the front bumber
have 96, 95 similar
Section 01-19: Bumpers 1996 Villager Workshop Manual
REMOVAL AND INSTALLATION Bumper and Bumper Cover Front
Removal
  1. Raise and support the vehicle.
  1. Remove the RH and LH front wheel (1007).
  1. Remove the RH and LH front fender splash shield screws. Remove the RH and LH front fender splash shields (16102).
  1. Remove the four front fender brace screws.
  1. Remove the two front fender brace nuts.
  1. Remove the two plastic screws.
  1. Remove the seven clip buttons located under the front bumper cover (17D957).
  1. Remove the RH and LH front turn signal lamps (13369). Refer to Section 17-01 for the removal procedure.
  1. Remove the four front bumper cover brace bolts.
  1. Remove the front bumper cover from the vehicle.
  1. Remove the two front turn signal lamp wire harnesses from the front bumper (17757).
  2. Remove the eight front bumper bolts.
  1. Remove the front bumper from the vehicle.
Mar 02, 2010 | 1995 Mercury Villager
How do i get back inside door cover off
This will be the same for the back even though it is for the front door....you just don't have the master switch...and a tool that looks like a flat tip screwdriver with a slot in it will help to remove the door panel without you breaking off the tabs that secure the panel to the door. You can get it at any auto parts store for about $6.00:
  1. Open the front door glass so that the distance from the top of the front door glass to the upper part of the front beltline molding is 8.3 inch (210mm).
  2. Disconnect the negative battery cable.
  3. Open the inner handle cap using a small screwdriver, then remove the screw.
  4. Remove the inner handle cover.
  5. Disconnect the door lock switch connector.
  6. Remove the inner garnish.
  7. Remove the cover, then remove the screw.
  8. Remove the lens cover, then remove screw.
  9. Disengage the clips from the front door using a fastener remover.
  10. Pull the front door trim upward, then disengage the tabs from the front door.
  11. Disconnect the power door mirror switch connector and the power window main switch connector.
  12. Remove the courtesy light.
  13. Remove the front door trim.
  14. Remove the switch panel from the front door trim
  15. Remove the hole cover.
  16. Remove the screws.
Aug 30, 2009 | 2005 Mazda 6
Nokia 5310 Cellular Phone Logo
32 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
