Question about Dishwashers
The water does not come out inside the dishwasher and the water is on to the dishwasher
    Champion:
  • 274 Answers
The selenoid that lets water in is out and needs to be replaced
Posted on Jul 05, 2010
E1 error on Baumatic BAD6003
If you are getting E1 error then the dishwasher is suggesting that water is getting in but not enough. But if you are getting no water into the dishwasher then the water inlet valve inside it is faulty. Have you checked if there is water inside the dishwasher when you get E1 error. Another thing to find out is the water pressure specification of dishwasher and whether it is consistent with the mains pressure in the house. Usually there should be a plate on dishwasher door which would give water pressure required.
Apr 20, 2014 | Baumatic Dishwashers
Does not clean like it did soap dispences goes through the cycles does not seem to have the pressure
Hello there"
Please go thru this list that i have provided for you and check each item ok
It doesn't get the dishes clean dot_lineone.gif 1. No water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there, we recommend Dishwasher Magic®.
Jan 12, 2010 | Bosch SHU3306UC Built-in Dishwasher
After cycle is complete my dishwasher doesn't fully drain water.
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
Concerning the Film(slimy looking substance).
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there, Try Dishwasher Magic.
Aug 20, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher sprayer arms not working
you are not getting enough water inside of dishwasher.you can pour 1gal of water inside. to see if arm work better should be 3 or 4 inches of water in side of dishwasher. water valve maybe bad or dirty screen inside of valve.ck to see if enough water is in bottom of dishwasher.ck to see if flote switch in left front corner of dish washer is moving up and down.
Aug 12, 2009 | Kenmore Dishwashers
Kitchen Aid dishwasher is not cleaning like it use to
Check the following to address this issue further.
1. No water
2. Not enough water
5. Not enough soap
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there.
Jun 21, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Just a little water seems to be coming into the dishwasher and the dishes are not getting clean even on the Potscrubber cycle
Check the following to address this issue.
1. No water
2. Not enough water
5. Not enough soap
Jun 06, 2009 | GE Dishwashers
Kenmore Elite dishwasher not cleaning well and leaving dark stains on the dishwasher walls. water pumps in to correct level and pumps out. First cup of soap the water is just warm. Second up its hot and...
1. No water
2. Not enough water
5. Not enough soap
Jun 04, 2009 | Kenmore 24 in. 16049 Built-in Dishwasher
Problem with water cycling
You say the water valve is open, are you referring to the supply water valve, or the water valve inside the dishwasher?
If the supply valve is open, then chances are that the electric water valve inside the dishwasher is bad, or the dishwasher control is bad.
Usually, the water line connects right at the water valve, underneath the dishwasher.
Reply with the make and model number of the DW and I can give further instruction if you or someone you know is good with a multimeter and reading schematics or wiring diagrams.
Jan 15, 2009 | Maytag MDB9600A Jetclean II Built-in...
Problem with Kenmore dishwasher model# 15762000
replace the water inlet valve, something is inside the valve holding it open, dirt small grain of sand, ect.
Apr 10, 2008 | Dishwashers
Dishwasher detergent does not dissolve entirely. Gel is still on side and powerball tabs doe not dissolve. Dishes are not clean. It sounds like it goes through the cycles properly.
1. No waterMake sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
5. Not enough soap
Dec 21, 2007 | GE 24 in. GSD3400G Built-in Dishwasher
Dishwashers Logo
69 people viewed this question
Top Dishwashers Experts
