Question about Price Pfister 4" Centerset - H43-528 - Chrome
Hard to turn off hot water cold water drips - Price Pfister 4" Centerset - H43-528 - Chrome
  • 487 Answers
Hi, your tap washers need replacing, if not come back to me, regards
Posted on Jul 05, 2010
Why is the hot water pipe dripping after tighening up.
First the is a hot and cold water pipe. To those are connected hot and cold water outlet bib valves to which are connected, respectively, hot and cold water hoses going to (or you could say, coming from) their respective connections to the washer. Correct this if I am wrong but, it appears you might be talking about those hose connections to the water spigots but calling them pipes, not hoses. If that is true, you contecture is correct: it is most typically a worn out hose washer or o-ring and replacing that item should correct any dripping. By sure the part is characterized for hot water.
Oct 28, 2014 | Washing Machines
I Have a cold water dripping in my sink the taps are mixer taps i have fitted a new washer but it still drips also it is tight to turn on and off. also my Hot water tap is hard to turn on it turns quite...
you need to check the seating in the tap for pitting, the new washer will not seal if the seating is pitted. you could fit some TAP REVIVERS which are available from most plumbers merchants.
Sep 08, 2011 | Home
Water drips into the machine washing bowl when the machine is turned off. Is there a valve or washer that needs changig?
You have a bad water valve. There are two valves, one for the hot and one for the cold. You can turn off the supply water one at a time to see if it's the hot or cold. Here is a link to the cold water valve Here is a link to the hot water valve
Happy Holidays!
Dec 11, 2010 | Fisher and Paykel GWL11 Top Load Washer
HELLO THE FAUCET DRIPS AT THE HANDLE AND THE HOT AND COLD SEEM REVERSED
On this valve the hot/cold in reverse is easy enough to fix, but the faucet dripping at the handle is another issue. To reverse the hot and cold, turn off the house water, relieve the pressure by opening a nearby faucet. Once the water stops, remove the handle and faucet cover so you can see the valve. then the four screws that are visible need to be removed. Mark one of the screw holes with a crayon or pencil and then remove by pulling straight out. Once out, inspect the main o-ring right behind where it sits against the valve, (if this is damaged, it might be why the handle area is leaking) then turn the whole assembly clockwise 180 degrees then insert straight back in and insert screws. Tighten screws until snug. Turn water back on before installing cover and handle to check for leaks. If no leaks are found, install cover and handle and check for proper position of hot and cold. If there are leaks, tighten screws in clockwise rotation tightening each screw a quarter turn, then moving to the next one until dripping stops. If dripping is from center of stem, where the handle attaches, you will need to contact Price Pfister to request a replacement. They are very good to work with. Good luck.
Aug 15, 2010 | Price Pfister Universal 0X8-310A Pressure...
Water leaking (dripping) into the drum when machine is off. Drip is coming from where water dispenses into the machine to fill the drum.
Hi just read your posting.The fault with your machine is a faulty water valve.1st turn off the cold tap to the machine and leave for a couple of hrs.If the dripping stops you have a faulty cold valve.If the dripping does not stop then turn off the hot tap and that should stop the leak.Either way to fix this fault a water valve must be replaced.Or you can stop the drip by just turning the taps off after the washing has finished.Hope this helps and please reply for further help if needed.
Jun 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
Cold water drips in instead of fills. Hot water
Inlet screen in the hot water hose is clogged (check at both ends) or the solenoid valve has failed.
Oct 30, 2009 | Kenmore 22422 Top Load Washer
Water keeps dripping after machine is turned off.
turn hot water tap off if it still drips replace cold water inlet valve if it stops replace hot water valve
Aug 14, 2009 | Maytag PAV2300 Top Load Washer
Cannot get cold water to come into the washer
Turn off the water and reverse the hot and cold water connections going into the faucet, then turn the water back on. If only cold water comes out of the unit when on hot temperature then you need to order a water valve solenoid which I suspect is the problem or wash only in cold water. They are replaced by removing the back washer panel a couple of bolts, one connector, and two hose clamps. Remember to restore the hot and cold water connections.
Jul 14, 2009 | Whirlpool Washing Machines
Cold water just drips, hot is fine, good pressure.
turn off water then remove hose. filter is in the fitting on the machine where the hose connects. pull out filter and clean or replace it
Apr 19, 2009 | Maytag Dependable Care LAW9406
Water Leak
take channel locks and tighten the hose connections going to the back of the washer
also tighten the connections going to the hot and cold water bibbs
remember turn to the right (clockwise to tighten
Jan 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Price Pfister 4" Centerset - H43-528 - Chrome  Logo
87 people viewed this question
Top Price Pfister Plumbing Experts
bwbconstruct
Level 1 Expert
john h
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
