Question about Nikon COOLPIX L18 Digital Camera
Lens wont come out
Battery said exhausted, changed battery now lens wont come out.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Try the procedures in this tip.
Posted on Jul 27, 2012
SOURCE: Battery Problem
can someone fix the exhausted battery problem?
Posted on Feb 17, 2008
PAPA-RAZI
  • 37 Answers
SOURCE: Lens stuck/lens error
Hello
there are tiny plastic gears inside and may have chipped or a small piece of sand got in causing the lens to jamb. "very fragile"
one solution is to ask a camera repair shop how much a lens mechanism would be to replace. (if cost is more than 1/2 of what you paid dont bother)
another solution is to have someone sell your camera on an auction site for parts, to make some money towards another camera purchase
Posted on Sep 02, 2008
SOURCE: When I try to turn on the camera it says battery
i have the same problem if you fix anything just send me soluciaon pls thx
Posted on Jul 09, 2009
  • 11967 Answers
SOURCE: my batteries went dead with the lens out. when i
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Mar 22, 2010
lock123
  • 6831 Answers
SOURCE: "lens error" whaen I turn camera off and on. started when I changed the battery and lens froze in zoom position
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 30, 2010
Camera wont turn on and lens wont go in
The camera has failed. Best thing to do is just replace it.
May 25, 2012 | Cameras
When i put a dvd in it the screen just jumps.
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load DVD's. The weak lens is the cause of he problem and not battery.
The lens reads the files/data on the disc inserted into the player and once the lens is weak, there is no way it would load discs.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all DVD's with no problem at all.
Good luck.
Apr 22, 2010 | Insignia IS-PDVD10 Portable DVD Player
Dropped camera now lens wont close. It says lens
Remove the batteries and insert new batteries . Sometimes this may work but in your case the lens is stuck inside, or it will have been damaged . Nothing can be done other than taking to service center to get it repaired .
Hope this helps .
Dec 16, 2009 | Canon Cameras
My camera wont turn on.
If the lens is stuck inside the camera and you hear a motor noise - changing batteries will not help. This has happened because the lens barrel is jammed inside the camera. Unfortunately, you will not be able to repair that issue. If the lens is stuck outside the camera, slightly tilted, and you hear a motor noise; you might be able to save camera. First, only use good batteries (stay away from alkaline batteries - waste of money), go with Energizer Lithium or Duracell Power Pix (you will get your moneys worth and have less problems with the camera). Second, very GENTLY, pull the lens barrel up and in the opposite direction of the tilt (to make the lens barrel straight), you will hear a slight click sound - DO NOT PUSH ON THE LENS BARREL!!!. Put in the new batteries and the lens should retract.
Oct 06, 2009 | Polaroid i733LP Digital Camera
Lens wont go back in, camera wont stay on
I have the same problem.This problem comes back so many times on this site, there is no solution anywhere.... Pretty mad for a problem hapening many times.
Jan 09, 2008 | Cameras
I dropped my camera & the lens wont shut & now I cant see any pictures
You might have changed the batteries, but have you fully charged them? That's the recommended resolution from Sony
Jul 28, 2007 | Sony Cyber-Shot DSC-P7 Digital Camera
Lens wont retract
Lens motor is shot - check out Olympus web site for repair options-not cheap
Jul 04, 2007 | Olympus FE-140 Digital Camera
The lens doesnt close and when i turn the camera on it bips three times and the screan shuts off. the lens wont close.
The batteries need to be changed. The digital batteries sold at the stores die out too fast. I had this same problem. In result, I purchased rechargeable battieries.
Nov 19, 2006 | Samsung Digimax S500 Digital Camera
Nikon COOLPIX L18 Digital Camera Logo
24 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
