Question about Ovens
Al i want is someone to help me unlock my whirlpool oven i turned on selfcleaning and by mistake opened the door and the word locked came up on the panel and i can not turn on the ovenplease help l
  • 6,784 Answers
HI. There are only two ways to do this. It all depends on the cause of this issue. The self cleaning function can be unstable if there are wiring issues at the control board or door latch assembly. If there is a failure at the monitoring thermostat/temp sensor, this will cause the relay contacts at the board to weld, thus, severing communication to and from the door locking mechanism. Another cause will be as stated in your post. With that said, kindly shutdown the appropriate circuit breaker for five minutes. This will force your main PCB into reset mode. Once the five minutes has passed, simply, reintroduce power to the affected unit and try to operate the oven. If the door locking mechanisms refuses to unlock after the five minutes hard reset, this will confirm that the main control board has failed. It must be replaced, in that case.
The second way to release the lock will be to disassemble the top section of the unit. this will expose the locking mechanism and its moving parts. I do not suspect that you will need to go to this extreme measure.
Posted on Jul 05, 2010
  • Michael Masters
    Michael Masters Jul 05, 2010
    • NOTE_ You can also unplug the unit at the rear for five minutes. Use this method if you are uncomfortable with accessing your home breaker box. This will induce a main board reset, as well. Be sure to allow the unit to sit for five minutes without power before reintroducing the power again.
After selfcleaning tried to bake put when you push the bake button it says to unlock door, however door is already unlocked and open
During self clean the oven controller locks the door to ensure one does not accidentally open the door and get insured due to high temperature. The door lock mechanism is unlocked once the temperature comes to normal when self clean is complete. In your case the controller is still sensing high temperature but the door lock mechanism has been released. This could mean the controller is detecting incorrect signal. Try to turn the mains power to oven off and back on. If this does not make a difference then you need to check the temperature sensor or worst the controller needs to be checked.
As I do not have the model number of the oven it is hard to give further diagnostic information.
Aug 13, 2014 | Hotpoint Ovens
Maytag Frigidaire Electric selfcleaning oven slide in type 30 inch wide purchase in 2003 --cleaning lady cleaned oven,unable to pull open oven door -door is jamed shut ???
Hello
Let oven completely cool then try.Locks out for safety because of extremely high temperatures involved in self clean mode.
Feedback appreciated
Aug 05, 2011 | Frigidaire FEB24S2AS Single Oven
Selfcleaning problem. I want to unlock to oven door. I followed instructions with no luck. please help thank you
I would love to help you.
Please respond by PRESSING REPLY OR COMMENT
Has the electricity recently gone out in the home?
Bruce
Jan 13, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Oven door won't unlock
kenmore selfcleaning oven door will not unlock code f9 appears in window
Jan 03, 2010 | Ovens
Kitchenaid superba oven stovetop oven door will not open after se
When the oven goes into clean mode the door is automatically locked as a safety feature. I would put it back into clean mode again, let it clean for a while and then hopefully when it cools down the door will open. good luck .
Mar 20, 2009 | Ovens
Lock for selfcleaning oven did not retract all the way
try setting the self clean letting it lock and then hitting the cancel button. usually take a min or to to see if it will retract itsself. the only other option would be to tap it lightly with a hammer so you can use the oven and replace the latch
Dec 07, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Frigidaire electri clean selfcleaning feature
It locks automatically. You can download the manual from Frigidaire here (as I just discovered while trying to figure out how to use the self-cleaning feature :) ): http://www.frigidaire.com/support/manuals.asp?NewSearch=New+Search
You don't need to type in the whole model number. For example, if the model number (found in the upper left when you open the oven door) is RSE37BAW*4, you only need to enter RSE37BA.
Apr 27, 2008 | Frigidaire Ovens
Selfcleaning Jenn-Air electric oven
How do I clean my jenn-air double oven when I lock oven door and turn oven to clean mode set time to start I don't get anything. Also when I lock the oven door the oven lock light does not come on.
Dec 05, 2007 | Jenn-Air JJW8230D Electric Double Oven
Ovens Logo
27 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
