Question about Motorola Mobility Bluetooth Headset Wireless Headset
Just got the new htc Evo are just wireless bluetooth headsets compatible? The phone doesn't find it when scanning.
Here is a solution from another user, hope it helps:
I had to do some serious massaging to get my EVO to pair with my Prius. It came down to what order I was doing things in (and honestly I dont recall at this point what that was, I did it 3 weeks ago). But suffice to say it wasnt the most straightforward thing. BTW, I also had to restart my phone in the process, because partway through it my phone simply refused to see my car anymore.
Posted on Jul 06, 2010
Just brought a HTC wildfire and I cant find bluetooth to turn it on .
Bell;
Important:
  • For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile.
  • Before you connect your headset, you need to make it discoverable so HTC Wildfire S can find it. You can find out how to do this by referring to your headset manual.
  1. From the Home screen, press howtoimage.aspx?id=106492, and then tap Settings > Wireless & networks.
  2. Tap Bluetooth settings.
  3. If the Bluetooth check box is not selected, select it to turn Bluetooth on.
  4. Make sure that the headset is discoverable.
  5. Tap Scan for devices. HTC Wildfire S will start to scan for Bluetooth devices within range.
  6. When you see the name of your headset displayed in the Bluetooth devices section, tap the name. HTC Wildfire S then automatically tries to pair with the headset.
  7. If automatic pairing fails, enter the passcode supplied with your headset.
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to HTC Wildfire S, the Bluetooth connected icon howtoimage.aspx?id=106796 is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
Mar 28, 2012 | HTC Wildfire Cell Phone
How to install the headset to my EVO 4g
To pair the Plantronics BackBeat 903 with an EVO 4G:
On the 903 headset:
With the headset powered off, press and hold the "Power/Pairing" button until the LED indicator flashes blue and red. This will put the 903 headset into pairing mode.
Use the iPod Touch menu to search for the headset and select 9xxBackBeat.
(If prompted, enter 0000 for the PIN code/passkey. Some devices also require you to accept the connection. Headset is paired when LED flashes blue.)
On the EVO 4G:
Turn the Bluetooth on from the Home screen, tap Menu, Settings, Wireless & Networks, Bluetooth.
Pair the EVO 4G by going to the Home screen, press Menu, Settings, Wireless & Networks, Bluetooth Settings, Scan for Devices. Follow the on screen prompts to pair the devices.
Good luck from Headsets Direct - 800-914-7996.
Aug 13, 2011 | Plantronics Backbeat 903 Bluetooth...
Want to know the steps on pairing the samsang woo 200 hands free bluetooth to my htc inspiree
First, Switch off your bluetooth hands free.
Now, press and hold the multifunction button for approx. 8 seconds till blue light appears.
Now, in your inspire, go to settings, "Wireless and network", Bluetooth. Turn on bluetooth and click scan device. It will show your bluetooth headset. Click on its name. It will ask for pairing code. Enter "0000".
You are done
Jun 07, 2011 | Cell Phones
How to pair motorola h700 to my htc hero
on the phone :
go to settings
then wireless
turn bluetooth on
go to bluetooth settings
click scan devices
on headset press and hold power button when its off untill the light stays on
on the phone you should see your bluetooth headset
click it
if you dont press scan devices again
the pin/pair code is 0000 or 1234 usually
you should be good to go
May 05, 2011 | HTC Cell Phones
How do I pair my jawbone icon with HTC evo phone
From your main/home screen :
1. Press your "Menu" button. ( located near the bottom of your phone to the left of your home button )
2. Press the "Settings" button.
3. Press the "Wireless and Networks" button.
4. Check the Bluetooth box to turn on bluetooth.
5. Press the Bluetooth Settings button.
6. Put your Jawbone Icon into discoverable mode. Follow this link for instructions if you cant find your manual.
http://www.headsets.com/headsets/resources/jawbone-pairing-guide.html
7. Click "Scan for Devices" on your EVO.
8. When your Jawbone Icon appears in the Devices list click on it and pair the devices. At this point it will ask you to accept pairing. Once you do that you should be good to use your headset.
Feb 28, 2011 | HTC EVO 4G Smartphone
How to connect the blue tooth head set to this phone
go to settings, wireless and networks, bluetooth.
make sure bluetooth is on.
turn on your headset, to sync the new headset, normally you have to turn on the device and continue to hold the power button until the headset goes into bluetooth sync mode.
normally around 10-15 seconds of holding the power button.
THen tell HTC to scan for devices. Your headset should appear. if it asks you to type in a code, it is generally 0000 or 1111
Feb 12, 2011 | HTC F3188 Smartphone
Trying to pair my HTC EVO to plantronics explorer 233 Bluetooth headset
Had the same problem and called Plantronics. They reminded me about putting the earpiece in "Discovery Mode" by holding down the button when turning it on until it flashes blue/red. Then have the EVO scan for bluetooth devices. It found mine right away.
Jul 01, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Want to hook uo bluetooth
First switch on bluetooth (settings---bluetooth).
Start > Settings > Communications and Add new Bluetooth headset. htc will search bluetooth headsets and find it. it will ask you to enter bluetooth passcode, usually it is 0000. then finished and you have paired Bluetooth headset with HTC
Mar 26, 2010 | HTC Cell Phones
Motorola Mobility Bluetooth Headset Wireless Headset Logo
189 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
