Twice this week Maytag washer model mfw9700sq1 has filled up on its own, once with door open (water leaking right out of the garage) and once not, water filling up to a third of the door. No help at Maytag customer service. Any ideas what the problem is and how to correct it?
SOURCE: Maytag washer will not work
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. (consult your manual to know where/how filter is cleaned). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Power off the wall, open behind the machine you will find a thin tube coming from the switch area to the exit pump area. Carefully disconnect this pipe from the top & blow into it, it should be free, if not unblock or replace. You can insert another pipe into the top & blow, you will hear a click; it means your presssure switch is okay. Refit carefully. This thin pipe adjusts your water level in the machine.
Dont forget the exit hose behnd your machine is inserted at a particular height, abt 3 feet from ground.
Rate me pl.....if helped.
SOURCE: maytag water fill
Have seen this problem before where the cause is an electrical signal from the board that bypasses even the door lid switch. Instead of pulling the main plug take off the rear panel and just remove the electrical connectors from the valves. If it stops then, then you have a faulty board that need to be replaced. Would really appreciate it if you find out what the problem is and send an Email to [email protected].
SOURCE: Torn bellow on Maytag front load washer
there is a spring style clamp holding it to the front panel simply peel back slightly and "pop" it off, then holding it to the inner tub is a screw style clamp, depending on yr of production, either a 5/32 scrwe or a phillips, holding it in the 2 oclock position, release clamp andreinstall boot, it might take some time to get to fit backaround hte tub but itll bo, you gotta walk it on in spots ( like changing a tireon the bikes as a kid) itlll strectch over the rim and fit, just have to work it
SOURCE: Water leaks when filling
Use a putty knife at the top front corners to release the spring catches. Lift up the top. Examine the plastic thing that delivers the water to the tub, it may be cracked or out of place.
