Phillips 50 While watching tv the audio shuts off. I can change the channel or cycle the power and it comes back right away. The manual says if it doesn't receive a signal the audio will shut off. I have satellite so i was wondering if maybe some of the signal was missing and the audio shut off. Please help before I throw the remote through the tv.
    Scholar:
  • 72 Answers
There was a problem with the software several months ago. with that issue.
Turn on your TV and enter to following code 123654 on screen you should see a software version something like BJ24u 1.6
U can download current firmware from Philips consumer portal
Posted on May 02, 2008
When i turn the bar off it automaticly comes back on right away
Samsung HW-F450 2.1 Channel 280-Watt Soundbar
www.amazon.com/Samsung-HW-F450-Channel...Sou...
Amazon.com, Inc.5) If you use sound share to connect samsung tv to sound bar, it uses bluetooth. I dont know if ... The subwoofer is wireless though it requires power connection.
Amazon.com: Samsung HW-J550 2.1 Channel 320 Watt ...
www.amazon.com/Samsung-HW...Channel...Soundba...
Amazon.com, Inc.
Rating: 4.5 - ‎104 reviews
Sony HT-CT370 2.1 Channel 300W Sound Bar with Wireless Subwoofer, Bluetooth, ...Samsung HW-J650 4.1 Channel 320 Watt Wireless Audio Soundbar (2015 ... 2.1-channel sound system with 320 watts of total power. .... bar away from the TV, there's not gonna be a lag or cutting off of the signal. .... Right To Your Door.
Samsung HW F450 Sound bar Problems with arc connec ...
? 5:25
https://www.youtube.com/watch?v=e46odUZ71tE
Aug 4, 2013 - Uploaded by DUGLESSM
Samsung HW F450 Sound Bar hdmi hook up. ... How to connectSound Bar to TV, Blu-Ray Player, DVD ...
Question about new Samsung HW-F450 setu
Jan 05, 2016 | Samsung HW-F450 2.1-Channel Soundbar...
Projection TV. DVD works. Cable often seems, "untuned". Static & un-fine-tuned sound of channel with black screen. Then, later, it will come on just fine. Sometimes, will go back to untuned status.
I would suspect your cable box first. I would unplug the power cable from your cable box and wait 60 seconds. Plug it back in and try to watch cable tv. I would also make sure the coaxial cable going from the wall to your cable box is connected properly. I would also make sure the cable going from the cable box to the tv is connected properly. Test your tv and see if it works correctly when you watch cable. If this fixes the issue you are good to go.
  • If this makes no difference use a set of new cables if you have them.
  • If this does not work then call your cable company. They may have to replace your cable box.
May 25, 2015 | Televison & Video
Phillips 40PFL3505D 42 inch tv stuck in channel search mode , continuous cycle
You can try to go back to factory settings.
After that disconnect the power from the TV and wait for about an or two hours. Then put on the power and try to make the installation complete from the start.
Regards GJ
May 25, 2014 | Philips 42PFL5332D 42 in. LCD Television
A yellow line going down the left side of the television
you likely have the "screen size" option set to allow the TV determine the best size (3:4 , 16:9, ...). Set it manually to 16:9 for HD channels or 3:4 for low-def channels.
The line should go away. This is a common problem on Samsung, Sony (Green line right side) and Phillips (yellow line left side).
May 05, 2011 | Philips 50PF7321D 50 in. Plasma HDTV
While watching, TV made a sharp bang sound. Sound still good, channels can be changed, but no screen, no raster
While watching, TV made a sharp bang sound. Sound Problem with the Zenith Z50PX2D 50 in. HDTV Plasma Television While watching, TV made a sharp bang sound. Sound still good, channels can be changed, but no screen, now tv wont come on at all?
Sep 26, 2010 | Zenith Z50PX2D 50 in. Plasma HDTV
I was watching the TV when it suddenly turned off. The audio fom the cable channel was still running on the independent surround audio system and I could change channels on the cable box. The power light...
Your partial resonance power supply IC with IGBT switch is bad. You will have to have tech replace it for about $50.00. The reason why your audio system still runs is because it is not part of your tv.
Sep 04, 2010 | Toshiba Televison & Video
I have a lg plasma,and the problem is it comes on for about 1 second then shuts off. repair shop says its the power supply? what do you think?
If the repair shop says it is powerboard it means they already took a look at the TV and you dont need to worry about it.
If you have any doubt please post the sympton here (detailed) and I can tell you for sure what the TV needs.
I need to know what the led does and how it does.
May 16, 2009 | LG 50PC1DRA 50 in. Plasma Television
Will not turn back on
Take off back cover. The problem power board is to the right of the board where the power plug feeds into the TV. There is a large white fuse right bend the power plug. With a meter it read ok; about 8 inches deeper into the TV on that board was the resister next to two fuses. My 4 amp 125 volt fuse did not read on my meter. After replacing, it worked fine.
Feb 12, 2008 | Pioneer SD-P50A3Q 50" Rear Projection...
Phillips 32 in. tv
bad front panel need to get new one ok sumthing loose or went out
Feb 04, 2008 | Televison & Video
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
