Question about Maytag Washing Machines
Maytag fabric-matic washer is very noisy in the spin cycle- high pitch squeak- sounds like it needs some lubrication. Any guidance?
5 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: My Maytag PAV2300AWW Performa is noisy on spin cycle
If you are talking about a loud sqeaking noise, this is usually attributed to a worn snubber ring and/or brake assembly. You cannot lubricate the snubber to get rid of the noise. In fact, you may damage the washer if you do. A small amount of corn starch can be sprinkled under the bottom tub support where the snubber ring is to get rid of most noise related problems (this will be the bottom round plate where it meets the casing of the machine). However, if the snubber is worn too much, or if the brake assembly is worn they must be replaced. I would recommend replacing the following parts:
Brake Stator: 1057484 Price: $7.45
Brake Rotor and Lining: 1032674 Price: $16.70
Snubber: 1055142 Price: $4.35
Brake Removal Kit: 997909 Price: $99.40*
*Brake removal tool is required in order to remove the brake assembly and/or to replace the snubber. There is a 200lbs spring located under the Brake Stator that must be compressed PRIOR to removal or you could cause injury to yourself.
You can find all your parts and information at repairclinic.com. I am not affiliated with the website. I am merely recommending them because I have used their service before. Plus, they use the same repair parts as your major appliance repair companies, but at a lower cost.
The parts required to make the repairs aren't very expensive, but the tool required to do it IS. Also, if you've never worked on this type of washer before, this is not a job that I would recommended to the average do-it-yourselfer. Maytag is real good abpout providing the necessary instructions with their parts, but this is a bit involved.
Post back with comments and let me know if this helps you.
Posted on Jan 29, 2008
SOURCE: Squeak upon spinning
I fixed my issue. Mine was a very small finish nail that had been sucked into the water pump. When I took the pump off the motor, the nail fell out. I made sure the pump was still turning ok and not damaged, then reassembled it all and it's worked fine...and quite...ever since. Mel
Posted on Feb 27, 2008
JULIANFIX
  • 975 Answers
SOURCE: high pitch squeak when on spin cycle
looks like you need to replace the main DRIVE BELT , first open the panel to access inside the washer , give it a test wash and look at the bottom where the belt is , check if belt is tight , if you still hear the squeak try lubricate spray to the pulleys and avoid spaying the MAIN BELT . hope this info works
Posted on Apr 18, 2008
SOURCE: Washing machine squeak
Same squeak on spin -LW8203 shortly before that she ran an off balance load and now wonders why it squeaks..
Posted on Jan 13, 2009
Maytag fabric matic washer started walking across floor on spin cycle?
Usually an unbalanced load, but check if rubber feet are worn through.
Jan 03, 2015 | Maytag Washing Machines
GE Washer Model WJRR4170E4WW squeaks while agitating
There are four suspension rods that the tub hangs on. When the washer is agitating the tub will rock back and forth and the rods will move back and froth as well. To fix this noise, lift up in each rod and put some lubricant in the cup that the rods fit into at the top of the washer.
Note that it is best if you use a lithium-based lubricant rather than silicone based lubricant.
For more on do-it-yourself appliance repair help visit http://www.appliance-repair-it.com/index.html
Sep 11, 2009 | GE WBSR3140DW Top Load Washer
The washing machine makes a high-pitched squeking
No, not if the noise is only when rinsing, if it makes the noise when spinning generally then possibly but if only noisy when rinsing sounds like a filter blockage on the waste pipe. clean out the filter behind the flap on the bottom of the front panel
Aug 21, 2009 | Maytag Bravos MTW6600T Top Load Washer
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
May 16, 2009 | Maytag Atlantis MAV8000
MAYTAG top loader makes high pitched squeal when agitating/spinni
This is a classic symptom of pulley/motor shafts/bearings in need of lubrication. It's not the agitator. You'll need to take the back off (with power unplugged) to access.
May 12, 2009 | Maytag PAV2300 Top Load Washer
My top louder washer is noisy when spinning , I want to know why
You can remove the cap but I wll be truthfull if your getting a loud roaring sound or screeching sound in the spin cycle it is the bearing call a tripple lip seal you need special tools to remove the seal
Mar 28, 2009 | Maytag Washing Machines
Maytag atlantis mav6000
sounds like the carbon brushes need replacing in the motor, they can cause a screeching sound as they wear down.
Oct 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Epic Washer high spin shaking, AND high-pitched sound coming out of washer
When someone reports severe vibration during spin on a brand new washer, the first question always has to be whether the transit brackets have been left in.
Washers are designed so that the drum and motor float on a collection of springs and shock absorbers. To prevent damage to these during shipping, a set of brackets is used to bolt the floating assembly to the case. If these aren't removed before first use (the manual will say how to do it) havoc ensues.
The irritating whine is a new one on me.
A.
Jul 04, 2008 | Maytag EPIC MFW9700S Front Load Washer
High pitch squeak when on spin cycle
Apr 18, 2008 | Crosley CW5000 Front Load Washer
Washing Machines Logo
91 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
