Question about Garden
Earthquake edger WE43 runs fine but the cutting blades spins slowly or not fast enough to cut. Is there a clutch adjustment? There is no dirt or grass impeding the blade from turning.
  • 52 Answers
SOURCE: craftsman 42" riding lawn mower blade free spinning but wont cut
It sounds to me that you need a new mower deck drive belt, or your blades need sharpening. If the blade edges are rounded, they won't cut butter... Also, when mower is off, check mower deck drive pulleys to make sure you don't have any that are locked up or are dragging. You can check this by pulling the belt away from pulley and spinning the pulley by hand. MOWER MUST BE OFF before attempting any of these checks. You would be surprised how many people would try this with the mower running.
Hope this helps
Posted on Mar 11, 2009
slohry
  • 87 Answers
SOURCE: how to change an old edger blade
Take a pair of vise grips and clamp the blade to a 2X4 for more leverage. Some old edgers had a left hand thread.
Posted on Apr 09, 2009
  • 86 Answers
SOURCE: Blades do not spin fast enough to cut grass
If you got the right oem belt,ta\han you can look at the end where the cable attachs to spring and you should see a double nut adjustment loosen nuts and adjust to put more tension on the belt when you put lever into gear for blades to turn then retighten them .
Posted on May 11, 2009
  • 10865 Answers
SOURCE: I bought a Sears edger #536 796526. It dies on me.
Hi Tom. You are not doing anything wrong. That being said, your edger has a slightly gummed up carbeurator. I would go to an auto parts store and get a can of a product called seafoam. this is a gasoline additive. Add one ounce per gallon of gas and use this as the fuel for your edger. You will solve your problem in just a few minutes after using this product, I believe. Give it a try and let me know.
Posted on Jun 13, 2009
darjr
  • 378 Answers
SOURCE: My engine runs fine, but
check your fuel pump. Fuel pump problem.
Posted on Jun 14, 2009
Trimmer runs but will not cut?
Is this gas or electric?
Sometimes if the trimmer cord is too long, the engine does not have enough power to spin it fast enough to allow it to cut.
Mar 19, 2015 | Garden
Polan selfpropeled mower the blade is not spinning fast enough and hardly cuts the grass
Blade speed equals engine speed. Check your carburetor and fuel pipe
Make sure you sharpen the blade with - this is more important for a good cut.
Mar 19, 2014 | Garden
What could be causing this?
to much dirt got up in clutch housing and shoes are not making full contact unit needs to be dissembled and cleaned.
Sep 06, 2012 | Garden
Cutting head on 29cc trimmer will not stop rotating at idle,cleaned filter,changed oil, cleaned spark arrester, tried adjusting idle speed, nothing seemed to help
You didn' t list the model number. Have you tried placing the head on the grass? does it stop then? It has a centrifugal clutch, if the idle speed is too fast, it will spin. There could be a broken spring or dirt in the clutch keeping it engaged.
Jul 26, 2010 | Craftsman Garden
The blade on my stihl edger will not turn fast enough to cut into the ground, when i use it it stops turning when it touches the ground
check your belt than your idler pulley and spring. if this is a clutch drive you may wont to check the clutch spring too
Oct 13, 2009 | Garden
Have a ryobi rlt 30 cd and the spool wont spin fast enough
hgffggkgjgjgbTry taping the bottom on a hard surface;HARD!;;;;;;;bjjjjjjkjjjjm4454541joojojojlj That did the trick for me for some reason it doesn't grab and it gets lose were it won't spin fast bearly cutting a blade of grass.
Apr 21, 2009 | Ryobi 15" Electric Factory Reconditioned...
Apr 06, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Craftsman 42" riding lawn mower blade free spinning but wont cut
Hope this helps
Mar 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
