Question about Bernina Artista 170
My needle does not go up and down.
I was using an alphabet stitch, heard some clicking and the needle stopped moving. The handwheel stil turns smoothly, and I took off the front part of the case so I could inside, and the handwheel was moving a rod up and down, but not the needle.
  • 980 Answers
You need to check the needle bar first of all to see if you can move it up and down by hand, if you can then the screw on the needle bar may have come loose, or the very worst situation could be a broken takeup lever
Posted on Jul 05, 2010
Testimonial: "Thanks for the feedback. I think it was the screw. I tried tightening it with an allen wrench and it started working again, though I did not feel any significant tightening motion occurring."
Kenmore sewing machine motor running belts moving but needle not going up and down
Is there a clutch that allows you to move the fabric through without the needle stitching (usually a knob in the centre of the wheel. That could be loose or worn.
Jul 18, 2017 | Kenmore Sewing Machines
I have acquired jones cb sewing machine.works fine except occasionally when stopped in middle of a seam wont restart but hums.will restart after turning handwheel.
Sounds like it is seizing due to old dried oil. May need a thorough cleaning and oiling. If this is the case, it would be good to avoid further use until it is repaired as continued use could damage the motor.
Wheel on right side that controls the needle up and down is very tight...
My jones sewing machine wont stitch straight just zig zag tried moving...
Feb 01, 2017 | Sewing Machines
How do i get the needle to stop moving when winding the bobbin?
Most machines will have a smaller wheel inside the handwheel that you turn towards the front of the machine, while holding the larger outer handwheel. If the needle still moves after doing this you'll need to work oil through the handwheel bushing.
Dec 04, 2016 | Sewing Machines
The needle acts like it is hitting something but there are no threads.
Test: Put needle on straight stitch. Put needle all the way to the left and turn the hand wheel forward.
Now move the needle to the right and do this again.
Did the hand wheel move all the way for one of the two sides the needle was placed?
If your answer is yes then you need to get the machine timed.
Also, make sure that your brake used for winding the bobbins is tight. If it is tight then loosen the small screw (usually on front of hand wheel). Move the brake forward a little more to tighten and then tighten the small screw again. Look at my picture.
Jun 26, 2015 | Sewing Machines
I have a lumina overlocker. It stopped working mid stitch with the needles just touching the fabric so I couldn't pull my work out. The handwheel turns and the motor is going, but the needles are not...
Sounds like a jam. Cut the threads before the eyes of the needle, and if you can get in to cut the looper threads just before they leave the loopers, that should help. Loosen the needle screws and try to rock the handwheel so you can get the fabric off. Clean the machine, install new needles, rethread, and you should be good to go.
May 19, 2014 | Sewing Machines
Bernina Record 730 hand wheel stuck
OK OBRIGADO VOU LIMPAR A MAQUINA PODE SER POEIRA PORQUE FICOU ALGUNS MESES SEM FUNCIONAR.
aGRADECIA SE ELA FUNCIONASSE TENHO MUITOS TRABALHOS POR FAZER SOMENTE O ERROR C14A3 ESTA A BARRAR-ME E NAO ACEITA MAIS NADA A FUNCIONAR
Feb 06, 2014 | Bernina Sewing Machines
My thread broke and now my needle wont go up or down what can i do?
If the needle wont go up and down at all when you turn the handwheel, it's most likely due to fluff and general muck has got into the basting stitch mechanism - this is a frequent failure on Artista models that have the basting stitch option. Try gently pushing the needle bar up at the same time as turning the handwheel ... with any luck the basting solenoid clutch will re-engage with the hole in the needle bar. If this works, it's only a temporary fix and tells you that your machine is overdue for a service !!!! Getting the gunge out of the basting mechanism needs to be done by a Bernina service agent. Trouble is, some embroidery patterns use the basting mechanism to raise the needle-bar out of the way whilst the hoop moves to a distant point on the embroidery, so if you 'fix it' using the above method, it may well fail again when you try to do another embroidery. Sorry !
Nov 15, 2011 | Bernina Artista 180
Older 830 will not zig zag stitch. leavers and gears move fine. The needle moves back and forth - left and right but it doesn't pick up thread from the bobbin on the left side so it does a strait stitch...
Firstly, make sure you have fitted a new needle and that you have cleaned/oiled the hook race. Unfortunately, if you are finding that the machine will pick-up the thread and stitch OK when the needle is one side of the stitch-plate, but not when its on the other, it suggests that the timing/synchronisation is out and will need to be professionally adjusted. You can check the timing by adjusting the needle to its right-most position, remove the bobbin case, rotate the handwheel until the needle has gone down through the stitch-plate and is just about to come up again. Stop there. Tip the machine slightly back and release the black plastic hook/shuttle retainer by pressing the metal lever on the top-left side of the bobbin door, so that the hook/shuttle retainer pops open. Drop the hook/shuttle retainer, but leave the hook in place ... be careful that it doesn't drop out and slowly rotate the handwheel until the pointed part of the hook/shuttle rotates clockwise to the place where its point is directly behind the needle. Look carefully and you should see that the point of the hook/shuttle is just above the top of the thread hole in the needle. If it's much lower or higher, the timing is out and will need to be adjusted.
Feb 06, 2011 | Bernina Activa 130
How do i thread my needle with the singer handy stitch?
  1. Loosen needle screw & insert needle with shank's flat side facing front of machine. Push needle in all the way, then tighten screw to hold needle in place.
  2. Install a fully wound bobbin by loosening bobbin nut & placing bobbin on top. Re-attach bobbin nut & tighten. If standard thread spool will be used, then attach spool pin to bobbin shaft & place thread spool onto shaft. Attach white spool cap on end of thread spool, then tighten. Bobbin/spool should unwind facing forward toward needle.
  3. Bring end of thread through thread guides & over tension control. Pass end of thread through needle eye, from back to front, & pull it out about two inches.
  4. A spring pushes pressor foot onto fabric that is being sewn, so lift pressor foot & place fabric underneath.
  5. Turn large handwheel on side of machine (handwheel can be turned in either direction) to raise needle arm to its highest position.
  6. Holding the Handy Stitch in place with your right hand, press on power switch & begin sewing. Guide fabric (being sewn) with your left hand.
  7. To end this sewing session, turn off power. Turn handwheel to raise needle to its highest position. Carefully pull out about three inches of thread through needle & snip, then lift pressor foot to remove fabric. Turn fabric over & loop needle threader through last stitch. Place end of thread from underside through eye of needle threader, & pull to loop through. Pull to tighten and snip end of thread.
Nov 11, 2010 | As Seen On TV Handy Stitch Mechanical...
Sewing Machines Logo
770 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
