Question about Electrolux Refrigerators
I hawe etb-3400 its pcb not working(dead) - Electrolux Refrigerators
  • 677 Answers
First , disconnect the power to the freezer . Remove the thermostat ( piece with the dial ) and put the 2 wires togather . Reconnect power and see if compressor will start . If so , then the thermostat is bad . You would have to order from a parts house .
Take care.
Posted on Jul 05, 2010
59.90 hp printer error
Hi there
This is related to the ETB motor and you need to make sure if its working. Try the following
ETB motor error
1 Clean the ETB unit intermediate
connector, J36. If the connector is
damaged, replace it.
2 Reconnect the connetors J38 for the
ETB motor and J1111 on the DC
controller PCB.
3 Replace the ETB motor.
4 Replace the DC controller PCB.
Regards
Saleem
Aug 29, 2011 | HP LaserJet 5550DN Printer
How do you install a transfer kit to 4700 dtn printer?
Replacing the ETB (transfer Kit)
Replace the ETB when a REPLACE TRANSFER KIT message displays on the control panel.
1. Turn the printer off.
2. Open the top and front cover.
3. Lower the ETB by pulling the green handle at the top of the unit downward.
4. Press the small blue latches located on either side of the bottom of the ETB and lift the unit out
of the printer.
5. Install the new ETB.
6. Close the front and top covers.
Jan 13, 2011 | HP LaserJet 4700 Printer
Hello .\r\nI have a Canon IRC1021I and it gives the code E000194. Can anyone tell me what that means en what i can do to fix this problem. When i turn it of and on again, can make a few copys and after a...
E194 Error in CPR sensor
0000 Description
Cannot detect color displacement detection pattern, detected results fall outside the
acceptable range.
Cause
Dirty color displacement detection sensor, color displacement detection sensor fault,
DC controller PCB assembly fault, toner cartridge fault.
Try to:
- Replace ETB unit
- Terminal assembly fault (check on every contact between the
terminals of each color and the high voltage PCB assembly)
- Replace DC controller PCB assembly
- Replace toner cartridge
I recomend you to call service.
Hope that helped!
Jun 28, 2010 | Canon Office Equipment & Supplies
How to replace the transfer belt Electrostatic Transfer Belt
That depends what kind of printer you're dealing with. In general, you should just open a front cover. Then release the ETB from the rest of the machine. Look for two blue handles to release the ETB. Replace the ETB and make sure the printer detects the new ETB. If the printer don't detects the new ETB, try to restart the printer or reset the ETB-counter in -Configue device--->resets----->reset supplies----->NEW ETB.
Jul 29, 2009 | HP Office Equipment & Supplies
My Electrolux Refrigerator / Freezer 340l Model No: ETB 3400 SA SL No: 71700112. purchased since less than a year is not cooling in the Refrigerator section.Please direct me to ur nearest Service Center in...
http://www.clickindia.com/detail.php?id=1184932 _________________________________________________ Kalinga Sales Refrigerators, Electrolux, Whirlpool Products LCD, Plasma, Air Conditioners Do not offer service, but may direct your call. Phone: 0674-254447, 254448 or 2742260 Have a hard time finding the information also but maybe this will help you, Thank You, Sea Breeze
Jun 10, 2009 | Electrolux Refrigerators
Intermec 3400 label printer - Connected but no printing...
your com setting must be 9600baud 7 data bits even parity
you may need to drop back to win 98
here is the syntax you need to send to the printer STX ESC E5 CAN DATA CR DATA CR ETB ETX PRINT
Oct 29, 2008 | Intermec EasyCoder 3400 Thermal Label...
Printing Bar Code Labels from Intermec 3400
I am using Smartforms with Intermec printer 3400-e and it works in the correct way.
What is the software that you use to build the layout of the label? In my case Loftware.
What is the code to print the Barcodes.
In my case Code 39
Aug 07, 2008 | Intermec EasyCoder 3400 Thermal Label...
Hp color laserjet 4700 etb reset
I have successfully reset the transfer kit life by entering the service mode then resetting the color page count to zero then powering off then on.  Hope this works for you too!
Jun 30, 2008 | Office Equipment & Supplies
MAIL MERGER
you have to send the output as such (STX) ESCe5(CAN)(DATA)(CR)(DATA)(CR)(DATA)(ETB)(ETX)PRINT
DO NOT PUT ANY SPACES BETWEEN DATA
LOOK UP SYNTAX AND PRINTING ASAMPLE LABEL IN MANUAL
HOPE THIS HELPS
Dec 04, 2007 | Intermec EasyCoder 3400 Thermal Label...
Refrigerators Logo
21 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
