Question about Poulan "Poulan" Push Mower
Lawn mower will start when primed but will only run for few secon
Primed, runs for 3 or 4 seconds then dies
  • 755 Answers
It starts because of excess fuel from priming. It usually then gets it fuel from main jet in carb.
You need to find the main jet and run a fine piece of sturdy wire through it. That will restore fuel flow so your mower can continue running after the priming fuel is gone.
This is a good thing to learn. Main jets tend to clog a lot on mowers these days.
Posted on Jul 06, 2010
  • Terry Ledford
    Terry Ledford Apr 21, 2014
    could you tell me where the main jet is? And you were very helpful, at least now I can tell someone what is wrong!
  • john andrew manchook Apr 21, 2014
    If your Poulan has a bowl type carb the jet is usually the bowl bolt. If you have a vacujet type carb the jet is located on the side of the carb. These jets are just holes of a specfic size as today's stuff isn't adjustable due to emissions limitations.
Will start but will only stay running if you prim it until its warm then runs fine
Lawn Mower Repair pt.1: starts & dies, Tecumseh/Craftsman ...
? 2:10
https://www.youtube.com/watch?v=IVYYYpAviPA
Mar 7, 2011 - Uploaded by Alameda Repair Shop
Spray with starting fluid and the engine runs a bit longer but dies.... I especially like how you use the gas can to hold up the mower, Classic :) ... After I started it up, it would only stay running for a few seconds before dying. .... LAWNMOWER REPAIR: briggsand stratton pulsa prime carb overhaul - Duration: ...
How to fix a gas lawnmower that starts then dies - YouTube
? 7:37
https://www.youtube.com/watch?v=caa0WrpxqyU
May 3, 2011 - Uploaded by SmallEngineRepairGuy
This is a how to video on what to do if your gas mower starts up then dies after a ... I have a different lawnmower and not very mechanical but this got my ... Got the job done and now i can do a thorough cleanout of it when i run it dry of gas. .... How to FixBriggs & Stratton Small Engine that Only Runs Off the ...
Craftsman 5.3hp starts but won't stay running... - DoItYourself ...
Dec 09, 2015 | Briggs & Stratton Briggs Stratton Intek V...
Why wontsmart carb engine start if primed runs for few seconds
dirt or water in the carby jets
priming it just puts a squirt of fuel in the manifold and that is the initial start run
Jun 19, 2015 | Garden
Have a 6hp craftsman mower starts and runs for 30 sec dies have replacer carb with running mower carb replaced plug replaced coil flywheel key fuel tank sounds like it is seizing up slows down for a
you have bad valves seats probably broken loose do to overheating replace short block or by new motor short block cost to much 300.00 new motor 225.00 to 245.00
Sep 07, 2014 | Garden
Lawnmower starts when primed only then stops
All mowers have a low oil cutoff. Fill oil. 30w.
May 29, 2013 | Garden
We have a briggs and stratton mower that has been in storage for 5 years with very few hours on it, it will start but dies shortly after.
needs to have carb cleaned out. most likely the main jet in the carb is plugged. symptoms include only running on choke and dies when choke is turned to run. or if you only have a primer bulb, it will only run for only a few seconds every time it is primed. if you are qualified to work on the carb, dont forget to start with fresh gas and possibly new fuel line and filter. R
Sep 03, 2012 | Poulan Pro 22inch 625 Series Briggs ...
Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower: my engine will only stay running for about 3 secon...
Maybe the engine is running with the fuel from the primer bulb (about few seconds), the carburator is not working and need to be removed checked and cleaned, the most common fail is a jet clogged.
May 17, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
The mower is 3 months old worked fine untill yesterday
the problem is either u have trash in the bowl of the carb or the float in the carb is stuck. either way u need to have someone look at it.
Aug 12, 2009 | Mtd 22" Yard Machine Push Mower
My lawn mower tries to start but then dies shortly thereafter.
Probably. Does it start after you push the primer and then die? If so, yes, it's the carb. For any more info, I'd have to have the model and type #'s off the engine. Dwain
May 17, 2009 | Craftsman Garden
Mower won't run....starts then stops
lawn mower only starts if i prime it. yard machine push mower. m/n 11a-549q229
Mar 01, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Poulan "Poulan" Push Mower Logo
2,247 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
