Question about Magellan Maestro 4040 GPS Receiver
Port for car charger broken
It seems the (yellow) port for the car charger broke off and is now loose inside the unit. I can't plug my charger in, there fore the unit will not turn on anymore.
    President:
  • 1,111 Answers
The following advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050 and 6000t
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
due to some dubious "experts" on fixya, im not permitted to help you directly, but please follow the link above to get further help.
let me know if you need more help or info
bill
Posted on Jul 06, 2010
  • Les Garwood Jan 20, 2012
    I know this is an old thread but I like resurrecting tech stuff. I note the power cord has three wires, white, black and red; the power jack is shot on my unit. I would like to hard wire a new cord onto the circuit board but I am not sure of the pin-out for the power jack (which is gone now). I have a long hobby experience with electronics. It would be great if there was a circuit diagram and/or a board layout diagram available.
Hi, JanPre
The same thing happened to me. The yellow port was broken inside. I think that is Magellan's problem.
We should contact Magellan and ask them to do something for us.
Posted on Sep 06, 2010
  • Ben Dover Sep 21, 2010
    Magellan will sell you a new one, unless its under warranty...see my previous answers
Male power port is loose hard to chasrge unit
The port is female with a center pin, the male portion is on the charger.
If you damaged this pin and it is loose you will need to replace the plug on the charger. Since these are very similar to some laptop charging ports, having a broken laptop around with same size charging port would be a bonus, or a friend with one too, but they are relatively cheap, I fix broken ones on laptops several times a year and can find a pair of them shipped for under $10 typically.
Sometimes you need to solder them on, sometimes they connect with a dongle, should be easy enough to take apart and peek inside.
Other wise, if that is beyond your expertise, does the charger have a cigarette lighter, you could likely charge it through that port, or with a trickle charger directly on the battery cables on the unit if need be.
Oct 01, 2015 | 900 Amp Jumpstarter - PKC0AZ/PKC0AZ-0
Can not charge
The socket that the charger plugs into has come loose from the control board. The only thing you can do is open it and resolder or send it in for repairs.
Jan 20, 2014 | Trust Flex Design Tablet
Garmin nuvi 2555lm battery want charge
A common problem with these units are loose/broken connections on the rear USB port. There are 5 pins on this port. If the power pins are loose/broken, the unit will not be able to charge the battery. The unit will not turn on because the battery is dead. Even if you plug in the charger, there battery will not charge.
The unit will not charge the battery if it won't turn on.
While you could have a bad battery, the Nuvi 25xx series is not that old and the date code on the battery is probably from 2010 or later.
If you plug in the charger, the green battery status indicator should go away or you should see a lightning bolt appear over the battery status indicator . If you don't see a change to the battery status indicator when you plug in the charger, then this confirms that the rear USB port is broken and not applying a charge to the battery.
More information can be found here:
http://www.sharc.net/gps_battery_repair.htm
http://www.sharc.net/gps_charger_repair.htm
Mar 25, 2013 | Garmin nuvi GPS
I hi have my psp and it dont want to charge i take the battery out and put it in my cousin's psp and it charges in his and when it's fully charges it works in mine..... so its not the battery, i...
You did a good job in isolating the problem. It does seem that your Power charger port is the culprit. I had the same problem with my unit. What I initially did was I applied slight pressure using my finger pushing the adapter plug in the direction of the start button. Apparently, there was a slight gap between connector inside the PSP charger port and the outside part of the adapter plug. Eventually, I added a small layer of solder to one side of the upper part of the charger plug ( near the top part which is colored yellow ). Dont put too much solder, doing so will cause the adapter plug to not fit inside the port. That fixed the problem for me. !!!As a reminder, please do this if you are experienced in using soldering tools !!!!
If your unit is still under warranty, I suggest you let the Sony Technicians fix it for you.
I hope everything works out. All the best to you.
Jul 20, 2011 | Sony PSP-3000 Black Console
The Yellow Port That's In The Inside Where You Plug The Charger in has Broken And Is Very loose And I can reattach It. When I Plug The Charger In The Battery Wont Charge The Whole Thing Wont Come on...
The DC jack, where you plug the power adapter cable, might be loose or defective, & needs to be either re-soldered or replaced.
In order to do this, the laptop needs to be disassembled & the motherboard taken out. Also, the motherboard needs to be checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Sep 01, 2010 | Acer Aspire 3680 Notebook
Broken mini USB port on TomTom One
It can be done with difficulty. I change them on a regular basis though as i run a repair business.
If you want me to change it I can do it for a small fee.
paul@cosmicstudios.co.uk
Dec 19, 2008 | Tomtom ONE GPS Receiver
Charger
Your USB port must be repaired. In the meantime, hopefully, your computer has another USB port that you can use. Battery is a replaceable lithium ion rechargeable battery. There are battery chargers that you can connect to wall outlets - the type that plug into the computer would probably require that you plug it into the USB port, which you said is broken - so that's a no-go. There are multiple vendors for battery chargers - one possibility is http://www.greenbatteries.com/
-Tha Mp3 Doctor
Jun 02, 2008 | SanDisk Sansa e260 MP3 Player
Magellan Maestro 4040 GPS Receiver Logo
550 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
