Question about Rosetta Stone Spanish Spain Level I & II Set Personal Edition (esclspe)
Director Player Error #9905: This error comes up when I am using the speaking portion of the program and then the program just stops.
My hp scanjet 2400 stops at warming up then shows unexpected error. please help
Try connecting it on direct wall outlet.Not a surge protector or power strip
Try below solutions
An Unexpected Internal Error Has Occurred' Error Message Displays
Issue When attempting to scan, or, during the scanning process, the error message An unexpected internal error has occurred may display on the computer screen. There are three scenarios where this issue occurs. This document covers each scenario where this error may occur and provides links to the appropriate documentation for resolving each scenario. Solution one If you have multiple versions of HP Image Zone software installed on your computer, click here to download a patch that might resolve this issue . If you do not know if you have multiple versions of HP Image Zone installed, follow the instructions below.
  1. Click Start , point to Settings , and then click Control Panel .
  2. Click Add/Remove Programs .
  3. In the list of programs that displays, look for the following entries:
    • HP Image Zone
    • HP Photo and Imaging Gallery
  4. If there is more than one entry listed, then there are multiple versions of HP Image Zone software installed on the computer.
  5. Click here to download the patch. Follow the on-screen instructions to download and install the patch.
  6. If the issue persists, try the next solution.
Solution two Clicking Scan picture or image in the HP Director software results in an unexpected internal error or causes the computer system to stop responding. Click here to resolve this issue (c00369826). Solution three When accepting a scan from the HP Scanning preview window, the scanner may start to scan and then lock up with the lamp approximately ½ way down the scanner bed. This results in an unexpected internal error or causes the computer system to stop responding. Click here to resolve this issue (c00373192). Solution four When accepting a scan, the scanner completes the final scan and the lamp returns to the home position; however, when the image is being processed or sent to the receiving application (that is, HP Photo and Imaging Gallery), an unexpected internal error occurs. Click here to resolve this issue (c00373192). Solution five Immediately after clicking Scan Picture from the HP Director when using an HP Scanjet 3970 with v2.2 software, an unexpected internal error occurs.
Try also this link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00259434&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=297430
I hope you issue should be fix to lessen your frustrations.You can do it
Regards
Your's Truly,
Christian from HP
Say "Thanks" by clicking the thumb icon in the post that helped you.
Please click "YES" in solution that solves your problem as "was this helpful?"
(Although I am employed by HP, I am speaking for myself and not for HP)
Apr 10, 2011 | Office Equipment & Supplies
Cannoy access HP Director. Error message: -
Uninstall the HP software:
Start
Control Panel
Add/Remove Programs
Select HP
Remove
Restart.
Re-install the software.
Access HP Director.
Sep 11, 2009 | HP PSC 1315 All-In-One InkJet Printer
Error message, program closes as soon as I open a project
It's the "power director", right? If so, check to see how much of a charge the internal battery of the laptop has. If it isn't the battery, then you may have to replace it (or find someone who can help more.)
May 07, 2009 | Computers & Internet
My pc won't install I Spy Junior.
You have given no information on your PC hardware, what OS you use, or if it is 32 or 64 bit.
Here is the link to the Tech Support site:
http://support.scholastic.com/faqs.asp?sid=102838090427012117185062&pid=424&dbg=&seid=1937&pnm=I+Spy+Junior&pos=Windows+XP&tnf=14&top=Error+Messages
Apr 25, 2009 | Scholastic I Spy Junior for Windows
AVG Free install fails
Install AVG8.0, it should fix your problem
Feb 10, 2009 | HP Pavilion dv6000z Notebook
HP Director malfunction
Error:CLR 80004005 For XP only
Fix.
Right click on the programs exe. File (ex. Quick quote Icon) go to properties, click on compatibility. Uncheck “ Run this program in compatibility mode for” Click apply, and then OK.
Mar 20, 2008 | Office Equipment & Supplies
Error message during installation of SBG 900
Please check if your modem and change the config to static IP.
Regards
Sep 03, 2007 | Arris SURFboard SBG900 (49402201900) Modem
Hp psc 1317 unable to use hp director scanning
Uninstall "HP Director" and replace with "HP Solution Center" New Updates (especially IE 7) make this application incompatible. Ed
Aug 06, 2007 | HP PSC 1315 All-In-One InkJet Printer
Rosetta Stone Spanish Spain Level I & II Set Personal Edition (esclspe) Logo
211 people viewed this question
Top Rosetta Stone Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Jax Planet
Jax Planet
IT GURUS OF ATLANTA
IT GURUS OF ATLANTA
Are you a Rosetta Stone Computer and Internet Expert? Answer questions, earn points and help others
