Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
I have an H400 heater (H400IDL2) and I get the CE trouble code, how can you determine which board is bad?
    Problem Solver:
  • 6 Answers
CE is a communication error between the display board and the ignition board. If you've had a lot of rain lately it could just be that moisture inside the unit is causing the error rather than a bad board. Take the cover off and blast the inside with a hairdryer for a few minutes, making sure to get the boards and connecting wires. That sometimes clears the error.
Posted on Jul 15, 2010
  • jeff_keeton Sep 10, 2010
    my CE has been on for a year. what could it be?
I have Hayward H400IDL2 heater I recently had #1 and #2 1.5 amp fuses blow. I replaced them and then the #4 2.5 amp blew so I replaced it. When I press the mode button to spa the heater blower comes
Good Day, missed your post for a few days. #1 & #2 fuses are on the high voltage side. This could mean a problem with incoming voltage or a bad fuse or main circuit board. Call our tech line at 908 355-7996. I have attached a link to the manual. http://www.hayward-pool.com/pdf/manuals/H-seriesLowNOx-H250IDL2-H350IDL2-H400IDL2.pdf
Aug 24, 2014 | Hayward H400idl2 400,000 Btu Low Nox...
The CE code is showing on screen
Communication error
If communication between the ignition board and the display board is not established
within 3 s of power-up an error will be displayed. After communication is
established, if it is lost for 30 s, the error will be displayed. The error code will
be cleared upon a valid data exchange between boards.
May 18, 2012 | Hayward H-series Electronic Gas Pool...
What does error code CE mean?
It means Communication Error. The display board and the Ignition board are not communicating with each other. Look for rodent damage first. If not that it could be either board and the only way to determine which one is by replacing one and see if it fixes the issue. Due to he cost of the boards it usually pays for itself to call a Hayward certified repairman out as he/she will have both boards available to try ond only replace the one you need.
Feb 18, 2012 | Hayward H-series Electronic Gas Pool...
The code CE is showing on my Hayward pool Heater what does that mean and can I fix it
I have just repaired my H400 series pool heater from the 3rd CE error in only 3 years since the pool and heater were installed. In each case the circuit board (F0059-456600) was in some way to blame .... I will explain.
Case 1 : Only months after installation the CE error came up. Rain water had got in around the display module and water-damaged the circuit board. It was replaced under warranty. Since then I keep a big plastic lid covering the display unit when the heater is not in use.
Case 2 : 1 year from new the CE error came back. On investigation it was found that a rat had managed to get inside the heater (there are big gaps around the pipe entries) - it had then partly chewed through the ribbon cable joining the two circuit boards together. Display circuit board was replaced at my cost - and all was well again. I also rat-proofed the heater - eliminating all the big openings with chicken wire.
Case 3 : Fired up the pool heater for the first time this year and CE came up. I pulled the display module and this time found obvious signs of blackening / burning on the display circuit board under the big green resistor (R1). Luckily I had kept the old circuit board from the previous time and was able to make 1 good board from the two I had - back in action now.
So in my experience it has been the display circuit board each time - and it only takes a phillips-head screwdriver and about 10 minutes to get it out.
Jul 27, 2011 | Hayward 250kbtu Ng Pool Heater - Inground
Have a Hayward H400 FDP. CE error, probably year or so. If the boards have to be replaced, why together, versus replace the one that is bad?
The CE error code means Communication Error. This is a loss ov communication between boards. It could be the wiring, it could be no power to one of the boards. There is a possibility that if you have a short circuit in one board that is bad, and you replace the other one, that it could damage the new board too. Do you have your manual? you can download one from www.haywardnet.com
Oct 01, 2010 | Hayward H Series Pool & Spa Heater 400k...
H400 pool heater showing a CE code on the display after heavy rains. What is the likely problem?
This is a communication code, and your having problems between your board and the desplay. The rain could cause this. If you take the top front panel off you can take it indoors and dry with a hair dryer on low or just sit out in a warm place for about a day. If this dosn't help you may need to replace the board or display. Good luck.
Jan 24, 2010 | Hayward H Series Pool & Spa Heater 400k...
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
1,181 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
