Question about Hoover HDV7FM Electric Dryer
The filter light keeps on coming on even it i clear the filter. the dryer will not start but the orange light comes on. What do I do?
Dryer check filter light comes on
take out and make sure you have puched it as far as it will go by takeing it out and putting it back should **** the sencer switch with is at the back of the filter not on the filter its self its in the dryer at the back where the filter puchs at it keep takeing it in and out ok if that dont work try cleaning at the back of the filter in the dryer where the filter go's ok should do it it only takes a little bit of fluff to stop it from working ok
Nov 03, 2012 | Dryers
CHECK FILTER LIGHT COMES ON UNTIL I START DRYER
The CHECK FILTER light will appear between every cycle, simply as a reminder to clear the lint filter before starting a new load. If the unit runs properly, then this is no cause for concern. If it will not start, then the unit may require service.
Oct 28, 2012 | LG DLE5977 Electric Dryer
Filter light keeps coming on but filter in end of door frame clean
Do you use dryer sheets? If you do, they leave a residue on the filter screen that will block air flow.
To check if that is the problem - Take the filter screen to a sink and run water over it. If the water runs through like it isn't even there then that is NOT the problem! But if pools even a little take a soft bristled brush and clean it until water passes through freely.
Aug 12, 2011 | Whirlpool LDR3822HQ Electric Portable...
Keeps saying filters blocked
hi street. remove the filter and then pull the dryer out from the wall and remove the vent pipe leading out doors. check the entire path clear to out doors removing any lint or other obstructions you come across. use a flash light to see to the parts that are dark. joe
Jul 08, 2011 | Dryers
Filter light is on. I pull filter - its clean. I put filter back in - filter light goes out. I start dryer. It runs for about 5 seconds and stops
Did anyone come up with a solution to the problem, we are having the same problem, except our dryer keeps running, the filter light goes out, and when the dryer is turn back on the filter light is back on, the filter is clean.
Oct 22, 2010 | Kenmore Elite HE4 Electric Dryer
Check filter light remains power light blinking
Hi friend,,,
welcome to fixya
try to unplug it for 30 minutes this should reset the control board. and clear any errors it has. and may start working again. let me know how it goes OR
try this to get it in diagnostic test mode have the dryer in standby mode then press and hold more time and less time and then press the power button to get out of this mode you will have to unplug the unit for at least 1 minute
if your satisfied with my solution PLEASE RATE IT
thank u...
Apr 09, 2010 | Dryers
The red light keeps comming on for the check filter even though i have cleaned it regularly since i boght the machine
Check the dryers exhaust ductwork. If it is obstructed, the light will come on. The light is a warning that air is being restricted on exhaust.
Dec 23, 2009 | Dryers
Bosch Axxis Starts and stops
The lint light keeps coming on and shuts the dryer off so clothes are not dry. I checked the filter and it is clear. Now the bottom of filter is cracked (plastic part) so I need to replace. But why does the lint light come on now after 5 years of use? It never came on before even when the lint filter was full?
Apr 20, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Front loading dryer
The check filter light is just a reminder light and cannot be reset.  Nothing to worry about.  Just keep the filter clean before each use.
Nov 21, 2007 | LG DLG2524 Gas Dryer
Hoover HDV7FM Electric Dryer Logo
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
