Question about Pioneer VSX-33TX Receiver
Power comes on and then Power Off displays on screen. Is there a reset or replaceable fuse? Has it gone into protection? I've looked under the hood and saw no visable problems.
  • rjw333794 Jul 06, 2010
    Thank you for your kind response. Unfortunately, the speakers aren't connected or any other device to the receiver so that's not the issue. I eliminated those variables from the start so I could just check the receiver. Although the receiver turns on and looks normal, it shuts down after a few seconds with the display reading "POWER OFF". It doesn't read protection at any point unless "POWER OFF" indicates it's gone into the protection mode. I'm guessing from your response thats there's no reset available or fuse issue. Any other ideas?
    President:
  • Pioneer Master
  • 1,114 Answers
Try this route first.
The most common problem found on FixYa for Audio Videopower comes on and then Power Off displays on scre - 2_bing.gif Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire2_bing.gif. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers2_bing.gif) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Posted on Jul 06, 2010
  • Frank Fulton
    Frank Fulton Jul 06, 2010
    Sorry to hear that it's not an easy fix! It's gonna need to see the Dr.
    Its gonna need several caps and a few resistors, and possibly a chip. If you can, find a shop that will give you an estimate for less than a 100 charge, and if repaired, estimate fee applies to repair. Your repair will probably run from 150-250 depending on the shop and parts cost. If you don't have a "Home Theater" Surge,ie. Panamaxx, Furman, or APC. Get one! it will save all your electronics! Average price: 260-400 for a decent unit. Sorry for the bad news!
My Horn Isn't Working
It could possibly be the relay itself or the horn. To test connect power straight to the horn, if it goes off then its the relay if not then its the horn.
Jun 28, 2013 | 1997 Chevrolet K1500
I replaced an apparent blown fuse, TV still won't power on.
Most likely your power supply is damaged and will need to be replaced. Sometimes, power supply manufacturers add additional "fusible resistors" to provide additional protection.
Jan 05, 2013 | Magnavox 19MF330BF7 19 in LCD TV
No power of any kind on 2001 GMC JImmy looking for fusible link
check fuses under hood for the main power coming from battery
Aug 26, 2012 | 2001 GMC Jimmy
I've looked at the cover for the fuse box (integrated power module) and i don't see a fuse labled for AC??
There should be a relay or fuse under the hood in the power distribution box
Jun 04, 2012 | 2006 Dodge Ram 2500
Danby portable air conditioner won't turn on - brand new!
Obviously it is problematic machine from the factory so it will suggest a replacement.
Apr 12, 2012 | Danby DPAC12010H Portable Air Conditioner
2002 intrepid 2.7 Im getting no crank from the starter and I dont hear the fuel pump kicking on when the ignition key is turned on, I do get power to the radio and dash, Ive checked fuses and replaced...
Under the hood, there should be a fuse block. Remove the cover and there will be a 20amp(i think) fuse that protects the fuel pump and starter circuit. I've run into this problem many times and every time it ends up being the starter that blows the fuse.
Jun 19, 2011 | 2002 Dodge Intrepid
My aux power points are not working. What is the
there are two auxillary power sockets. The console aux power socket is protected by fuse #4 in the battery junction box. The second aux socket located in the rear is protected by fuse #1 in the battery junction box. Both fuses are 20 amp fuses. The battery junction box is the fuse box located under the hood, usually on the driver side.
Feb 15, 2010 | 2001 Ford Expedition
Display gone, no longer functioning
Green light but no display- most likely main transformer is gone (60%), 35%- blown main fuse, 5%- bad display or power supply. You are lucky if unit is still under warranty. Solution- repair shop.
Dec 31, 2008 | Denon AVR-2807 Receiver
Car just died, electrical system gone
there is no such thing as a main battery fuse.
seems like a wire has come undone under the dash and shorted your car out.
Sep 04, 2008 | 1992 Hyundai Excel
Pioneer VSX-33TX Receiver Logo
211 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
