Question about Toshiba Satellite A135-S2276 Notebook
My system is always out of sync - Toshiba Satellite A135-S2276 Notebook
    Guru:
  • 366 Answers
If your windows have pre-installed windows you have to download the iso file and create a recovery disk so you can repair or re-install windows...search for a file called 'sysprep' this file will restore windows.
If you do find this file then its for sure you have preloaded windows and its very important to create a recovery disk so you can re-install windows if your computer crashs
http://blogs.techrepublic.com.com/window...
Posted on Jul 05, 2010
Where is sync?
Pairing a Nokia Lumia 520 to a 2013 Ford Escape
1. To Find "Bluetooth" on the Nokia Lumia 520
  • Slide your finger left on the display.
  • Press Settings.
  • Press Bluetooth.
2. Turn on Bluetooth
  • Press the indicator next to "Status" to turn on Bluetooth.
3. Pair a Bluetooth device with your phone
  • Make sure the vehicle (parked in a driveway) is turned on and engine running. Go tot he Phone Menu, System Settings, Add Bluetooth Device, Push OK, The Sync System will display a 6-digit PIN number. Use the Seek Arrows to change to Special PIN (the system will display 0000), Push OK.
  • Your phone now searches for devices and after a moment, a list of Bluetooth devices within range is displayed.
  • Press the required Bluetooth device (the tab should say Sync).
  • Follow the instructions on the display to pair the Bluetooth device with your phone. Enter the 4-digit PIN
  • The new device is displayed on the list of paired devices.
  • Press OK on the console screen to set as Primary Phone, set 911 Assist and Download Phonebook. Be sure to check your phone screen and check "Always Connect" and Yes to approve the phonebook download. Be sure to check to see is there is also a request to Always Connect for SMS (texting) alerts.
4. Return to the home screen
  • Press the Home key to return to the home screen.
Your phone should now be paired the Sync system. Use the Voice button on the steering wheel to start the process (say "Phone"). Use the Phone icon to answer (a quick push) or hang up (push and hold down for about five seconds).
For more info www.fordtechlane.com Ford Tech Lane Driving you on the fastlane of vehicle technology
Mar 05, 2014 | Nokia Lumia 520 Smartphone - Wireless LAN...
Tip
How do I make my iPod always Sync my Photos
<p>If you have an iPod capable of storing photos, you probably want to keep the images. To ensure that your photos are always sync your iPod, your synchronization settings in iTunes. If you choose to have your iPod to sync automatically or manually, your preferences under "Photos" tab to sync photos from a folder or program. When you set these preferences, iTunes will remember them and sync your iPod the same way you connect to your computer. <br /> <p><br /> <p>1. Connect your iPod to your computer using the data cable that came with it. <br /> <p><br /> <p>2. Open iTunes if it does not open automatically. Click the name of your iPod under "Devices" in the left pane. <br /> <p><br /> <p>3. Click on "Photos" above the central panel of iTunes. <br /> <p><br /> <p>4. Check the box next to "Sync Photos." Select a program or a folder with the photos you want to sync from the drop-down menu. <br /> <p><br /> <p>5. Choose to sync all photos and albums or just selections. If you choose the latter, make your selections by checking the boxes next to the folders to sync. You can also choose to automatically include certain events, or events such as the latest in recent months. <br /> <p><br /> <p>6. Click Apply. Now, when you sync your iPod, it will always sync your photos. <br />
on Aug 05, 2011 | Computers & Internet
Hi, I have a sony STR-DE675.; the audio cuts out between stereo and mono, as if something inside is heating up.I have cleaned all connections and carefully vacumed out any dust from inside the unit.The...
STR is a very sensitive ic module of the audio system and it always has a tendancy to heat up quickly and has some basic precautions to be maintained for operating this. correct speakers should have been connected so on..
if you are technically very confident open up your system try to locate the str ic unit check whether the contacts of the heat sync (aluminium metal chunk screwed with the ic to absorb the heat) has been correctly fixed. (pls note- manufacturers will always have appropriately heat synced it try to use it in a cooler place)
Feb 01, 2011 | Sony STR-DE675 Receiver
U430 will not work with ford sync
I have the same problem. Trouble pairing but finally I got the SYNC to find my U430 and paired but the SYNC never connects with the phone.
Sep 17, 2010 | Samsung Cell Phones
How do I bluetooth pair my i9 phone with my Ford SYNC
On your Ford Sync board, press the phone button. It will start to search for already paired devices. If none is found, press the arrow buttons until you find 'Add Bluetooth Device'. Then, press OK. You'll see it will generante a PIN. Now, make your phone's bluetooth application look for new devices. After a while, the Ford Sync device will appear on the phone screen. Select it, and make the the bluetooth application proceed. When a PIN (or pairing code, or passkey) is requested, enter the PIN generated by the Ford Sync device.
Hope it works for you.
Regards, Carlos
May 20, 2010 | Cell Phones
My farmvivlle always says saving but it stock already i need to refresh always.. always out of sync.
your Internet connection is not stable, This can occur by many reasons .. viruses, malware, firewall or is blocked by anti-virus protection.
try scanning your computer, for example with threatfire .. and do cleanup the windows system e.g ccleaner..
hopefully this help, pls rate.. thanks you.
Mar 14, 2010 | Facebook Social Network
Wii balance board blinks for a second and won't turn on, what is wrong?
You could try holding the red sync button under the battery cover on the balance board and on the front of the Wii system. It doesn't always work though so re syncing isn't a guaranteed fix.
Oct 06, 2009 | Nintendo Wii Fit for Wii
Recover lost calendar events on a Palm z22
Hi suzbt:
JOY's answer, that you try to do a SYSTEM RESTORE on your Computer to get the data back is a really good one, that I did not think of! All manual instructions, and USER instructions on doing a SYNC with the Palm Z22, REPEAT : 1/ Always have a back up of the hard data 2/ Always check all transferred DATA on a SYNC, "Even if it states 'transfer Successful'", 3/ Even, if necessary, write down the data, ...
There are a few software programs to identify FILE problems on the Z22, listed on my web page:
http://kidbots.com/WEBADD/Z22_PALM_PILOT/Z22_PALM_PILOT.html
and ways to recover corrupt data, but these are getting more and more difficult to find and use...
User comments on the SYNC indicate that any SYNC is a risky procedure, and backups and re-checking all data is necessary at all times.
I hope that the information on my web site comes in useful in keeping the Palm Z22 up and running!
good luck
robin dusty graves
Z22 PALM PILOT recover-lost-calendar-events-palm-z22-cdqazwk5fkdpm30unkbxcrm5-2-0.jpg recover-lost-calendar-events-palm-z22-cdqazwk5fkdpm30unkbxcrm5-2-1.jpg recover-lost-calendar-events-palm-z22-cdqazwk5fkdpm30unkbxcrm5-2-3.jpg
Sep 10, 2009 | Palm Z22 Handheld
Won't sync music to player using windows vista
sir there may be a problem with your pc's i/o devices.virus present in the pc may also lead to this problem.use an apt anti irus to your system ant the prolem will be solved.
May 28, 2009 | Creative Labs ZEN Vision:M Digital Media...
Sync problem
What are you trying to sync to on your computer? First thing you always want to check is to right-click on the Hotsync icon in your system tray (the little red and blue circular arrows) and make sure there is a check mark next to "USB"
Aug 26, 2007 | Palm Treo 650 Handheld
Toshiba Satellite A135-S2276 Notebook Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
