When I plug in my computer to the PC port on the Vimax 42" plasma TV the screen turns off every 10-15 seconds then comes back on again. This continues to happen even when i press the menu button. I have tries different display settings and resolutions from my pc, but can't figure it out.
  • 4,889 Answers
What exactly do you mean by computer port? VGA? DVI?
Posted on Jul 05, 2010
  • 6 more comments
  • fred_v Jul 05, 2010
    Sorry, VGA port
  • eagle338
    eagle338 Jul 05, 2010
    There. Thats the source of the problem. I have seen quite a lot of people experience this problem. Try the DVI port(You are gonna need a DVI cable. Its the PC equivalent of HDMI.
    There is no DVI port. There is VGA, HDMI, Component, Coax, RCA and S-Video. I have another Plasma TV that works great on the VGA port from my computer.
  • eagle338
    The DVI port is on the computer and the cable goes from there to the HDMI port on the tv. If its a laptop then it should have the HDMI output itself.I would also suggest that you try chaning the refresh rate on the PC that may not be matching with that of your tv. It is possible that the computer's refresh rate is set to a lower rate which may be the cause of the problem. Also make sure that there are no electrical wires crossing it as electrical interference may also be the cause. D
    No DVI on computer, just VGA. Tried all refresh rates, only get picture at 60hz, all others say out of range. Perfect picture, it just keeps going on and off. Why would there be a VGA port if it is not usable?
  • eagle338
    I did not say its not usable. Its just that some people tend to have problems when plugged in via VGA. Did you check for electrical interference. AKA any wires crossing the cable? Does the same cable work on another plasma? That will help us find out if its a problem with the VGA cable. Otherwise I will see if I can find you a firmware update. DO you have a USB port on your tv so that you can update it yourself?
    Cable works on another computer and plasma tv. No usb.
  • eagle338
    In that case you may have to place a service call requesting them to update the firmware. Better yet you can get a VGA to HDMI adapter that i is most likely to solve your problem. Costs about 35 bucks.
    http://www.amazon.com/VGA-HDMI-Converter...
Norcent Technologies PM-4201 42 in. EDTV-Ready Plasma Television that turns itself off within one second. Then the remotes don't work and I have to unplug the tv. Is the tv shot?
That might be a factory fault don't hesitate but to take it to the retailer if still under guarantee. Or phone the manufacture for a quick respond.
May 03, 2017 | Norcent Technologies PM-4201 42 in....
Vimax tv displays no sync on screen
Check its input connections. Check it for external RF input.
Feb 17, 2013 | Televison & Video
How do I get LG Plasma TV 42PQ30 to work with a dell laptop in connection use of a VGA/SVGA video cable. Thw hook up should act as a plug and play if my understanding is correct. I am using the RGB IN(PC)...
well, if the cable and adapters are friendly (meaning, you are able to plug the right video connection from LT to TV), sometimes you need to tell you LT that you have a second screen to output video. To do that, there should be a display icon in your bottom-right taskbar. Double click, and you should be able to see the options to either clone, pan, or primary your second display screen. :D
Mar 21, 2010 | LG 42PQ30 42 in. Plasma TV
Just a Black screen
needs a Y-Sustain board, about a 300 dollar part, unless you have a warinty, also try turning the tv on, after you get a green light, unplug the tv, after 15 seconds plug it back in, sometimes will make tv come back on
Jan 09, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
caypianan@yahoo.com
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
Daewoo DSP4210GM 42 in. EDTV Ready Plasma TV
what way did you set the tv in the transport vehicle. something has been knocked loose inside or the videomask has been damaged?
May 14, 2008 | Daewoo DSP4210GM 42 in. Plasma Television
My Maxent turns off when it comes back on it has dark colors.
goto maxentuse.com, open user manual and look under troubleshooter.
May 01, 2008 | Maxent MX-42EPM20 42 in. Plasma EDTV
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
