Question about Toshiba DKT-2010 Corded Phone
I have a ttoshiba model FD - 9859 telephone purchased 8/5/01. I cannot6 get a dial tone. I ppurchaSED A NEW BATTERY FOR IT AND CONNECTED ACCORDING TO INSTRUCTIONS AND WAITED FOR IT TO CHARGE. tHE CHARGE LIGHT COMES ON, BUT IT FLICKERS AND AFTER WAITING FOR 12 HOURS, i STILL DO NOT GET A DIAL TONE. hELP
  • fayla1907 Jul 05, 2010
    "How long do I need to leave the phone off and what do you mean by "hard free"?
    President:
  • 1,561 Answers
Go to the NID (normally gray or white box on the side of your house) with a corded phone and plug directly in here.. if there is no dial tone here then you need to call the local phone provider to come make the repairs free of charge... if there is dial tone here, then the trouble is inside...
when the line is called if the phone rings busy, or goes straight to voice mail then you are looking for a short, or defective phone... if the phone keeps ringing then you are looking for a broken wire.
Take care.
Posted on Jul 05, 2010
    Genius:
  • 1,417 Answers
this simple please follow this steps.
what you are to do is to put off the phone for some time then disconnect the hard free on the phone then connect it back properly after some time make sure that the battery is well charge and well position with this the problem is solve ,but if it fail then you will have to contact your service provider for connection from their office it could be from the service provider sensor.
thank you and thanks for using fixya.
All 4 hand units say "line in use" How do exit tis situation? hand units model KX-TGA410, baseunit KX-TGA131
A "Line in Use" message generally means that there is no dial tone detected. Assuming that all of the handsets are in Standby and any other phones are connected to that line are also on their hooks, then you need to determine why the base isn't getting a dial tone. This can be an inside or outside wiring problem.
I like to use an old wired telephone for testing since power isn't required to use the phone. You also need another RJ-11 telephone wire. Try connecting a new RJ-11 wire between the KX-TGA131 base and the phone jack. If there is a dial tone with the new cable, you had a bad cable. If not, try the alternate phone. If the test phone has a dial tone, then the KX-TGA131 has failed or has a power problem. If the phone is under warranty, contact Panasonic.
If neither phone has a dial tone, take your test phone to another jack connected to the same phone line (number), if available. If you have a dial tone here, then the problem is in the first jack or the wiring to the jack. You can try to repair the jack yourself. Remove the cover plate and look at the jack. If any wires are loose, reconnect them to their appropriate location. See http://www.lanshack.com/wire_phone_jack.aspx for the usual patterns. There are two types of telephone jacks, keystone and screw terminals. For the keystone type, you need a punch-down tool (available at many hardware stores in the electrical section) to put the wires back in place. Do not strip the individual conductors before using the punch down tool. For screw terminals, strip the wire before securing it under the screw.
If you do not have another jack or there is no dial tone at the second jack, find the incoming telephone service box. Open the box and check the wiring. If you find an RJ-11 jack, plug in your test phone and listen for a dial tone. If there is a dial tone, you have a wiring problem. Check the jacks as above. You may want to have someone else check the wiring in the walls if there are no broken/loose wires in the jacks. Your telephone company will usually offer the service for a fee.
If you can't test the phone line at the service box or there is no dial tone at the service box, contact your telephone company. They will test the service box and should repair outside issues for free. (Some providers are trying to avoid copper repairs.)
If you have DSL, you may need to check the line filter. This filter can disrupt the dial tone when it fails. If the filter is in the interior, you are responsible for the replacement. In my service area, the DSL filter was in the service box so my telephone company repaired it.
I hope this helps.
(I've had no line issues several times. Sometimes, it was the result of a contractor cutting through underground lines. With copper wire, rodents sometimes damaged those underground wires. Once it was simply an issue of a contractor who'd left one wire loose after upgrading the service.)
Aug 26, 2017 | Lands Phones
No dial tone cant make calls
No dial tone and inability to receive ring signals are symptoms of connection problems. The installation instructions should indicate how your telephone system should be connected to the network.
Dec 30, 2013 | Lands Phones
How do I manually enter phone numbers into the "speed dial" directory of my Toshiba FD-9859 cordless telephone?
Welcome to Fixya
To program a speed dial on your phone, enter programming mode (press #9876 on your phone). The phone will display "USER PROGRAMMING MODE." Press the Spdial button, enter a speed dial number (100-119), 9 plus the phone number you wish to dialed (1-213-555-1212 for example), then press the Spdial button one more time to lock it in. To use a programmed speed dial, just press the Spdial button plus the number.
Thank you for using Fixya!
Apr 06, 2011 | Cell Phones
Lost dial tone and phone service
Your phone line might be connected to Telephone 1 not 2. That could be the reason why you are not getting a dial tone.
Nov 22, 2009 | Arris Touchstone 450a (CM450) Modem
Modem tells me there is no dial tone
Connect the modem to a telephone-jack.
Make sure that the telephone-wire has *FOUR* strands, not just *TWO* strands.
Or, unplug the FAX, and plug a telephone into that telephone-jack, and listen for a dial-tone.
Do you have electronic voice-mail from your telephone company?
If so, does it "beep" a few times when you pickup the handset?
Such "beeps" can confuse any modem that expects *instantly*
to "hear" a dial-tone.
Nov 01, 2009 | Zoom ADSL USB Modem
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
Just bought phone no dial tone i move the setting to pulse
First thing to try is another phone in the wall jack if it doesn't work either you need to call your phone company. If the other phone works, make sure that the telephone is getting power from the AC electrical outlet. Try swapping the telephone cord with another cord. and lastly, unplug the battery from teh handset and plug it back in untill you feel it click into place. Sometimes the new battery connections are pretty tight and may not really be connected even though it looks like it is plugged all the way in.
Mar 23, 2009 | Uniden 5.8GHz Dual Cordless Phone
User manual for toshiba fd 9859
Try going here http://tacp.toshiba.com
enter your model # and it will take you to a "knowledge center" It's the how to page for your phone
Jan 25, 2008 | Toshiba FD 9859 Cordless Phone
Sakar Telephone Problem
This Telephone doesnt have a capability to work with shared connections where u use more than one phone in one connection.......... And this phone cannot be charged it works in either battery or Adapter...... Good Luck......
Dec 10, 2007 | Sakar Talking Caller-ID Speaker Phone
Toshiba DKT-2010 Corded Phone Logo
42 people viewed this question
Top Toshiba Lands Phones Experts
Oloyede Monsuru
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
