Question about Toro Electric Trimmer
Refill spool for TORO TC 2010
How to refill spool for TORO TC 2010
3 Suggested Answers
vincob
  • 718 Answers
SOURCE: How do I change the
Go [smalleng.com] they have videos on just what you need. Good Luck....
Posted on Mar 10, 2011
radar001
  • 1051 Answers
SOURCE: refill line on spool of toro electric model 910
Onve you remove the cover the spool should pull straight out. Be careful, there's a spring under the spool that can fly out and get lost. You need that spring to re-assemble.
Posted on Apr 12, 2010
Toro 8 inch cut home duty trimmer how do you remove the spool
You have to hold in the two tabs at top of spool assembly
Aug 30, 2012 | Toro& Electric String Trimmer
Gettin spool off to change string
1.Twist the cap off counterclockwise.
2. Remove the cap and spool.
Note: If the spring falls off, install it before installing the spool.
3. Thoroughly clean the cutting head and cap and inspect them for anydamaged or worn parts.
May 29, 2011 | Toro& Electric String Trimmer
I have an electric 13"
you can try a smaller string size, this should help. Tim
Apr 24, 2011 | Toro& Electric String Trimmer
Refill line on spool of toro electric model 910
Apr 11, 2010 | Toro& Electric String Trimmer
I can't remove the spool to replace the line. How
there is a button on the end of the shaft. it can be tight sometimes so a large pair of channel locks might help. turn the button counter-clockwise, and the pull the spool head off.
Aug 30, 2009 | Toro Garden
It has come apart and I would like to refill the line on my toro heavy duty electric trimmer
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
Jim
Jun 23, 2009 | Toro Garden
I have a Toro 12 inch Toro Electric trimmer and I can't get the spool off to change. Any solution?
I am having the same problem - the spool should just come off by turning it counter-clockwise but is completely stuck. This model does not have any tabs that need to be pushed in to get the spool off. Very frustrating!
Jun 03, 2009 | Toro Electric Trimmer
I have an 11" Toro trimmer and was having trouble deciphering the symbols on the base. The key is having a method to gain some opposing force to unscrew the cap that holds the spool. I have an oil filter wrench called the round wrench. It is a steel bar with an attached length of rubber belt that can tighten around cylindrical objects. I used that to oppose the unlock direction on the trimmer and "voila", no tabs to push no trick with the button, you just need o_1089.jpg_1088.jpg_1087.jpgpposing force.
May 26, 2009 | Toro Electric Trimmer
Toro Electric Trimmer Logo
508 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
