Question about Dell 3100cn Laser Printer
I am trying to replace the dell 3100cn laser printer cyan toner cartridge, but even though the printer has positioned the cartridge and I have lifted the lower right tab on the cartridge, the toner will not pull out. I have tried various levels of lifting the right tab and pulled everyway I can think of but nothing I have tried works. I have replaced the black toner cartridge befor with no problem, although I could still be doing something wrong.
  • 1,511 Answers
Hello Joe and Welcome to FixYa!
Actually this process is a bit structured and it will not be appropriate to describe it in words here.
So I'm giving you the Vendor's Support Link which will guide you through the step by step process with pictorial representations where needed, I hope you will get through the problem and will get spot the missing requirement.
Even though, if you are having problems do tell me, We are here to help.
This is the link, Click here
IF your problem was solved, your token of appreciation in the form of rating will be esteemed.
Concerned, WAQAR
Posted on Jul 05, 2010
  • joe_nordman Jul 05, 2010
    I cannot accomplish the step " ... and gently dislodge the cartridge for removal". There are two levels
    when lifting the lower tab and I have tried both to no avail. The cartridge does not dislodge and I cannot remove it.
  • Waqar Hassan
    Waqar Hassan Jul 06, 2010
    Hmm, seems something is wrong it should come out from both sides on pulling it gently.
    There isn't any trick regarding this step, but I'll do suggest opening both doors and remove drum cartridge, then close front door only (the one you open to replace a toner) and rotate carousel using your hand until it reaches a position where the toner cartridge you want to remove is accessible trough the upper slot: unlock cartridge and remove.
    It seems that the plastic latch is creating this issue, If the printer is still in warranty you should contact Dell and get the left/right plastic latch replaced to get it work, in case.
    Again be professional and patient in doing so, but I hope this will be easy for you as you have changed the black one by yourself already.
    Concerned, WAQAR.
I'm getting the following error: Dell 3100cn Laser Printer error 004 332 problems
Try restarting your printer, if this does not help make sure that the toner cartridges are set in properly and locked in place.
Mar 28, 2011 | Dell 3100cn Laser Printer
004321 restart printer error
This type of error code implies that you need to restart the printer again. However, do check to see if toner cartridges are seated in the proper position. Also ensure that they have been locked in. This is an error commonly associated with the Dell 3100cn laser printer.
Nov 30, 2010 | Dell 3100cn Laser Printer
Dell 3100n keeps saying "Change Black Toner" even
Before installing a new toner, put a disposable towel over the ink toner exit, and shake your toner lightly back and forth and up and down. Make sure your toner cartridge is in the open position before replacing it in your printer.
If you are using a refillable ink cartridge, make sure you are resetting the cartridge using the method described by the refillable manufacturer.
If this does not answer your question please request more information before voting on my answer. I will try to find more information about your toner cartridge that will help you futher.
Nov 16, 2010 | Dell 3100cn Laser Printer
Dell 3100cn laser printer poor print quality
It sounds like you've got contamination on the drum cartridge or on one of the toner cartridges.
I'm actually going to be installing black toner in my 3100cn in about 8 hours, so I'll inspect and clean each of the carts, and write up the process for you tonight.
Jan 27, 2010 | Dell Office Equipment & Supplies
Far right side of the text or picture missing on Dell 3100cn.
Refer to the following table
Cause
Solution
How common*
Contamination in the laser path
1. Clean the laser path. (Remove the laser/scanner assembly and clean the lens.) 2. Replace the laser/scanner assembly
8
Defective fuser.
Replace the fuser assembly
Lack of toner or faulty toner cartridge.
Redistribute the toner in the toner cartridge. If the problem continues, replace the toner cartridge.
7
Sep 30, 2009 | Dell 3100cn Laser Printer
Dell 3100cn printer leaves a blank strip
The following table should help
Contamination in the laser path - 1. Clean the laser path. (Remove the laser/scanner assembly and clean the lens.) 2. Replace the laser/scanner assembly
Defective fuser - Replace the fuser assembly.
Lack of toner or faulty toner cartridge - Redistribute the toner in the toner cartridge. If the problem continues, replace the toner cartridge.
Dirty Corona Wire - Clean the Corona Wire.
Defective Drum - Mostly applies to B&W printers. Clean the drum or replace the drum.
Sep 20, 2009 | Dell 3100cn Laser Printer
LDell 3100cn awer printer won't recognize new toner
Have you removed the plastic protection strip from the bottom of the toner?
Nov 14, 2008 | Dell 3100cn Laser Printer
How do you change the magenta, yellow and black toners on the dell 3100cn
The toner carousel must rotate, so that you get the slot for the other toners in front of you.
Follow detailed instructions on the user manual, click here to get the manual :
Owner’s Manual
Nov 07, 2008 | Dell 3100cn Laser Printer
My Dell 3100cn will not print unless I press Init NVRAM and restart printer every time I want to print. This is annoying. Can you help? Thanks! Greg
this implies that you need to restart the printer again. However, do check to see if toner cartridges are seated in the proper position. Also ensure that they have been locked in. This is an error commonly associated with the Dell 3100cn laser printer.
rate my answer
Aug 22, 2008 | Dell 3100cn Laser Printer
Can I print in Cyan (blue) or magenta?
Depending on which software you are using for documents, you should be able to select output color from within the program; i.e., in Word, you can change the default template to whatever color you wish that is offered on the pallet.
Aug 07, 2008 | Dell 3100cn Laser Printer
Dell 3100cn Laser Printer Logo
80 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
