Question about Boating
Need wiring diadram for cdi box on 95 kawasaki 650 ts jet ski it has two black one white one purple wire and is made by mitsubishi. one of the black wires was diconnected. bought it used from a freind and he wastold that it needed a new ststor coil but i think it tests o.k.as far as a resistance test goes it is within spec. i bought a repair manual but it was generic to several models and didn,t have completei nfo and some of the numbers are missing but it is a mitsubishi symbal on it.
    Sergeant:
  • 202 Answers
Sometimes a bad stator can test good on a ohms meter, but under a load (motor running and in the water) it cant supply enough spark to run properly. It will barley idle when the ski is in the water. The stator is behind the flywheel, the coils are located in the electrical box. Coils on kawasakis hardly ever go bad. You most likely need a new stator.
Posted on May 31, 2017
  • 15 Answers
SOURCE: installation manual clarion m455a
Here is the product page:
http://www.clarion.com/us/en/products/2006/marine/source_units/M455A/us-en-product-pf_1151544055054.html
And here is the manual:
http://www.clarion.com/us/en/MungoBlobs/797/154/M455A_ENG.PDF
In page 33 you'll find the wiring chart.
Posted on Dec 29, 2008
  • 10 Answers
SOURCE: 83 xs 650 wiring diagram ?
engine stop switch and the coil on the 2&3 side of the engine
Posted on May 07, 2009
  • 9 Answers
SOURCE: Is the third wire positive or negative going into the battery on a Kawasaki 1100zx jet ski?
Most lithium ion battery packs I have come across, that typically have three terminals, have a terminal to allow the charger to do one of two things. This terminal will give the charger circuit a temperature reading, or, it will give it a reference to allow for both cells to have a balanced charge. On the battery I used for one of my projects there was a board that measured the voltage across 3 different cells to prevent over charging, over current, and undervoltage conditions. Without
Posted on May 17, 2009
finish line
  • 207 Answers
SOURCE: not getting any spark to the plugs
for no spark the cdi is a better bet and there is no test for it but process of elimination buy cheapest part first you can use a test light to see if your getting power from your startor to the cdi and coils if the cdi has power when you turn it over its 90% its the cdi
Posted on Jun 27, 2009
SOURCE: kawasaki 750sts jet ski won't start - electrical
Have you replaced the starter relay.
Posted on Jul 08, 2009
Where is the starter located on kawaski ts 1990 jetski?
Starter button is always right side of handlebar by the twist throttle.
here is the manual
1990 Kawasaki Jet Ski TS Owner Manual
videos
kawasaki ts 1990 jetski Google Search
Jun 11, 2018 | Cars & Trucks
Want to make my own CDI for Kawasaki KLR 650 A model(2004),,so I plz need the diagram for CDI unit(the actual internal wiring schematics)
I really don't think you will find an internal cdi wiring diagrams.they use capacitors to discharge at specific times using specific values.
Mar 06, 2015 | kawasaki Motorcycles
Jet ski troubleshooting
damaged impellor or housing , grabbing air !
Dec 19, 2013 | WSM 1995-1997 Kawasaki 750 Zxi Cdi...
I have a kawasaki mojave 250 with low spark i think it could be the cdi box but i am not shure
its not likely the cdi if you have any spark. check the cable, coil and spark plug cap (over looked a lot!) for the correct resistances.
Apr 07, 2013 | kawasaki 2004 KFX 250 Mojave
I need to know what wire to hook the coil up to the CDI box on a 1992 KX500. Its orange and doesn't correspont to any other wires.
the manual I have is from a couple of years earlier
it shows three wires in to the CDI from the stator
a red black that also goes to the stator but is joined to a black\white connected to the stop switch
and a single black that goes straight to the coil.
a 1992 may not have the original coil, or it may have had a black sheath over the orange when new
If that doesnt help, you may need to repost the question
Jun 15, 2010 | 2002 kawasaki KX 500
Jet ski bogs out under load.
I had a similar experience with that model. It turned out to be a mouse nest in the water box. However , in this case i think you just have some moisture corrosion on the rubber tipped needle in the carburetor. Clean that part of the carb and do not alter the tiny spring in any way. If that does not work open the electronics box, if it is wet , dry it out , and seal it back up. Those are the three things I know of that will cause your problem. Start with the carb.
Apr 06, 2010 | Encore Software Kawasaki Jet Ski...
Wiring in a sony CDX-L600X in a 95' F150
red is B+
black is ground
dark blue with white stripe is remote for amp
blue is power antenna
yellow is ignition
white and white with black stripe is front left
gray and gray with black stripe is front right
green and green with black stripe is back left
purple and purple with black stripe is back right
this is for the deck
Mar 21, 2010 | Sony CDX-L600X CD Player
1995 kawasaki jet ski guages wont work is there a fuse somewhere that i am not finding?
There is/are fuses in the electronics box. Most ski's have just one main fuse for the whole machine. I suggest unplugging all the wire connections and plugging them back in, you probably just have a problem with continuity. If the gauges are all bad , you might find a good used set on EBAY. Just remember the gauges are pretty and cool but not really necessary as long as you fill your oil tank before riding and drive with the fuel petcock in the ON position.
Mar 14, 2010 | Encore Software Kawasaki Jet Ski...
I have a 1991 Kawasaki JS 550sx, No spark
that box will not work on the newer bike they are different . you need to not mismatch stuff on the bike you will coast you more money taking cheap rout need right part hope this helps
Aug 06, 2009 | Encore Software Kawasaki Jet Ski...
Boating Logo
91 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
