Question about NetGear WNDR3300 - RangeMax Dual Band Wireless-N Router
Internet signal not passing through to desktop or wirelessly.
When computer is wired directly to modom all is well. When router is wired to modom and then hard wired back to computer no internet signal goes to computer or other wireless receivers.
  • 342 Answers
This can be fixed by resetting the modem,the ip address,other setups.
Posted on Jul 05, 2010
Wireless modom
It won't connect if it has a poor signal.
You need to resolve the phone signal problem first.
May 12, 2012 | NetGear Computers & Internet
My laptop works using my Belkin router, but my desktop will not connect to the internet
hello
your notebook has WiFi, which is radio frequency internet, it transmits and receives radio signals (frequencies) . Your desktop, most likely, does not support WiFi on its own , so you need to use RG45 cable , ethernet cable to be connected from your desktop to the router.
So in other words thsi is what happens with your notebook and the router.
  1. your notebook has built in wireless adapter which translates data into a radio signal and transmits it using an antenna.
  2. A wireless router receives the signal and decodes it. The router sends the information to the Internet using a physical, wired Ethernet connection, to your modem (supplied by your Internet Service Provider)
The process also works in reverse, with the router receiving information from the Internet, translating it into a radio signal and sending it to the computer's wireless adapter.
The radios used for WiFi communication are very similar to the radios used for walkie-talkies, cell phones and other devices.
you need to connect your desktop to the router via RG45 ethernet cable.
was this helpful ?
Nov 15, 2010 | Computers & Internet
Dsl wont pass thru router wired or wireless I have reset the router several times, the computer shows connected ,signal strenght excellent, but will not connect to the internet wired or wireless as long as...
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 28, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Can Not Get Wireless Signal from Cable Modom
Cable modems are generally not wireless. Go to Best Buy or equivalent store and buy a Wireless G Modem, connect it to your cable modem and follow the easy directions and set up the wireless.
Jan 27, 2010 | Acer Aspire 5735 Notebook
Router did work. At&t DSL modom had a
are you able to go online when you connect the computer directly to the modem without the router. ?
Or you have the user name and password for the ISP.
Click Here for more info about how to set up router
Oct 30, 2009 | D-Link (DI-784) Wireless Router
Very slow
Since your laptop is wireless, G speed is only a maximum of 54 Mbps. N speed is usally 300Mbps.
Now your desktop, if its connected directly to your router with an ethernet cable, its speed can be 10/100/1000 depending on the routers network ports.
You could try to update the firmware of your router from the manufacturer's website.
Mar 17, 2009 | Computers & Internet
I've had my Icebox for 2 1/2 years. Can't log on to internet.
I do not fully understand your problem I think you are trying to connect a wireless connection from a router to computer if that is the case you need to do this with a USB lead to establish your settings and once the connection is established then you can shift the computer
Jan 24, 2009 | IceBox (HL1214) PC Desktop
Loose connection
  1. Update the Firmware on your router.
  2. When you lose internet, look on your modem and make sure that no lights have gone out. (i.e. Cable) If this one goes out, it is your provider.
Jun 03, 2008 | Linksys Wireless-G WRT54G Router
Wireless
Hi there!
I want to help you out. I have some questions to ask you first:
1. What brand and model are your wireless router and laptop?
2. Does the laptop have a built-in wireless card or you installed one?
3. If it's has its built-in wireless card, check the wireless switch of the laptop. ICheck if it is on or off (some laptops sometimes has an on/off switch)
4. Check if the wireless light on your router is on (it's sometimes refered to "WLAN")
5. How many wired & wireless computers do you have and their operating system?
Your physical connections are correct. BTW, can you also specify what port from the modem is going to the router? Some routers have 1 port named "Internet or WAN" and 4 ports for "Ethernet." Check if the modem is connected to the "Internet or WAN" port.
May 04, 2008 | Computers & Internet
NetGear WNDR3300 - RangeMax Dual Band Wireless-N Router Logo
174 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
