Question about Sony Ericsson K700i Cellular Phone
Joystick not functioning
Problem is that left, right and up is not working for my joystick. already check the joystick and found out that the terminal of up is not broken but remaining left and right soldering is in god condition. need assistance in checking and resoldering of joystick.. pls. help!
  • onlyhelp May 09, 2008
    Only works occasionally and I have to press over and over downward, left, right and up to get anything out of the phone.
Joy stike damage
Posted on May 27, 2008
Rebuilt motor installed in Pronto m50 power chair, now joystick forward, takes chair to right, joystick right takes chair forward, joystick to left, taks chair back, joystick back takes chair left, HELP
u need a programer o reset that joystick to the new motor,so call the dealer have them send out a qualified tech with a programer to check error codes and reprogram
Sep 26, 2013 | Health & Beauty
My Saitek ST90 joystick doesn't work on up/down, right/left, but fire buttons work. I'm using windows 7 home premium 64bit
You may need to update/roll back your driver
  1. go to device manager
  2. select the saitek st90
  3. click update
  4. if no updates are found click roll back
Mar 23, 2011 | Saitek ST90 USB Joystick
Etrex legend joystick problems
could be the hardware switch itself
Oct 05, 2017 | Garmin eTrex Legend GPS Receiver
Joystick problem
Friend, i guess the connection of your joystick going upward is broken or disconnected. the connection terminal needed to be resolder. if still does'nt work, you need to replace the whole joy stick.good luck
Jun 05, 2009 | Nokia E50
Here are the Master Reset codes for your phone.
Master Reset / Codes
Accessing the Service Menu - Move joystick right, press * key, move joystick left twice, press * key, move joystick left, press * key.
Checking Firmware Version - Move joystick right, press * key, move joystick left twice, press * key, move joystick left, press * key, press 1 key twice.
Show IMEI # - press * key, press # key, press 0 key, press 6 key, press # key
Manual brightness adjustment - While in camera mode, press and hold * key and move joystick to lower brightness, press and hold 0 key and move joystick to increase brightness
Quick ScreenSaver - Pressing # and * at the same time
Show screensaver and lock keypad - press * and lock keys
*#0000# - Reset language back to english
Hard Reset -Hold power for 10 seconds
May 28, 2009 | Samsung SGH-D500 Cellular Phone
K700i joystick connection
i used to have this problem before i got my samsung e370 and nokia 5200 but to fix it you have to use a bit of force on the phone by geting somehting thin and lifting cover off with it then you can remove the top joystick and clean underneath and simply place back on and push cover back on pretty simple
anoying joysticks!
Apr 02, 2008 | Sony Ericsson K700i Cellular Phone
Second hand mobile w700i sony ericsson
Go into the service menu and check th total call time there.
To access enter the service menu press the following.
Press: [joystick right] [star] [joystick left] [joystick left] [star] [joystick left]
Feb 25, 2008 | Sony Ericsson W700i Cellular Phone
Cant go left on joystick last solution no good
see buuddy if u have allready triesd with blowing out the dust from joystick part than go for the change of the keypad(joystick). the problem might be with the joystick it might have got broken so change the joystick and than try.
Oct 11, 2007 | Nokia 6600
Right Joystick. . .
I had this same problem with my 360 controller (after modding it, but the solution should be the same..) If you pull up on any 360 joystick it will stick the same way.
The quickest fix would be to take some sandpaper on the inside of where the joystick touches the controller shell, sand it down just enough so the joystick is moving smoothly.
More professional ways would be to cut the little piece of metal that sticks out and goes into the joystick. Just a very small amount, too much will make it hard to press the right thumbstick button.
You could also try some old fashioned grease, just a little bit on the inside, nothing noticeable from the outside.
Also make sure the controller is put back together right, I've taken apart many 360 controllers and sometimes joysticks stick when there's a wire in the wrong place and the shell won't close all the way. (The rumble motors particularly).
Hope this helped!
Sep 16, 2007 | Microsoft Xbox 360 Controller
3230 joystick problem
trow ur cellphone in d river! den cry! dats d best solution!
Dec 14, 2006 | Nokia 3230
Sony Ericsson K700i Cellular Phone Logo
109 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
