Question about Ruud UBHC Air Conditioner
When i tunn on my AC unit at the thermostat it blows the 3 amp fuse in the air handler when it call for cool when i switch the t stat to off and just turn fan on the fuse does not blow and blower runs
  • 29 Answers
Sounds like the compressor is or a electrical component directly linked with the cooling operation/ outdoor unit running.
Possible short to earth....
cheers
Posted on Jul 05, 2010
My(38ycc030340)carrier heat Pump ac unit blows 5 amp fuse on board in handler in attic when switch stat to heat.
Miss wired or shorted low voltage wiring. Have you changed stat? Animal chewed wires at foundation wall or in attic?
Oct 10, 2016 | Carrier Heating & Cooling
What cause 3 amp fuse to keep blowing when power in turn on goodman air handler
The 3 amp fuse is in the red low voltage (24 volt) thermostat wire
and only gets power when the thermostat is set to turn on heat or a/c It should be connected to the red wire from the thermostat
Nov 13, 2014 | Goodman Manufacturing Goodman ARUF48D14...
Have a Lenox HP13 outside, and CB26 Air Handler. Just changed out the Thermostat to a Honeywell RTH7500 programable. Atached the Red to R, Orange to O/B, Yellow to Y, Green to G, Blue to C, and White to...
Hi, sounds like this is a Lennox heat pump. On the stat wiring it looks as though you wired it correctly except on the reversing valve terminals o/b, the orange wire should be on the o terminal only as the reversing valve is energized through in the cooling mode and will default to heat if the compressor fails. Make sure you have no control wires at the new stat that may have touched and blew the 3 to 5 amp fuse in you air handler. You can go to the air handler and see if the circuit board has this auto type fuse and a control board I believe it will as it may have blown. Just sounds like this is a control voltage problem as this is all you have been working with is the change out of the stat. Keep in mind that this new stat also has a built in time delay that will keep the unit off for several minutes.Check this fuse though. If you have excess to a voltage tester, you could check for 24 volts at the stat by setting it on its lowest ac volt setting and check across R to G or Common and it needs to read 24 or more volts. If not, its either a control volt 3/5 amp fuse or a faulty transformer. You say you had the breakers off, so if you happened to stripped the wires at the sub-base and the R or hot has touched the C terminal it could have taken out the transformer or just a fuse. This is where you need to look first is the control board or control module. Please keep me posted so I can get you up and running. Make sure you have the stat programmed correct also. Please let me know.
Shastalaker7
A/C, Heating Contractor
Aug 28, 2010 | Heating & Cooling
Change out problem
AIR HANDLERS DO NOT ENERGIZE REVERSING VALVE , THE THERMOSTAT DOES THE JOB THROUGH THE O  OR B TERM TO THE OUTSIDE UNIT. IF YOU HOOK UP TO O TERM AND HEAT COMES ON WHEN YOU SET AC ON THEN SWITCH TO B TERM ON STAT. YOU SHOULD HAVE O TERM ON CONDENSER OUTSIDE AND YOU USE ORANGE WIRE IF YOU HAVE ONE. IF NOT USE UNUSED WIRE IN 6 WIRE STAT HARNESS.
Apr 21, 2010 | Heating & Cooling
3amp fuse is blowing.
Disconnect the yellow wire from the thermostat and tape off the end. Turn the power back on. If the fuse blows, it is not in your wire nor the compressor contactor. If the fuse does not blow, turn off the power, reconnect the wire, and replace the fuse. Then, disconnect the wire from the compressor contactor and tape it off. Turn the power back on. If the fuse blows, it will eliminate the compressor contactor coil and will likely be a "short" in the wire itself. The yellow wire goes from your T-stat to your air handler and from your air handler, it goes to the oudoor unit's compressor contactor.
Apr 07, 2010 | Weather King 10PJA2501AH Air Conditioner
Trane XT300 thermostat reads HOLD-AC. Unit will
by simply turning power off to furnace or air handler may not work but there might be a reset button in the t-stat. remove the faceplate off of the t-stat it might be in their.
Aug 16, 2009 | Heating & Cooling
Fuse blowing on tappan air handler
most of the time its out by the ac unit . you have a shorting thermostat wire .. the outside unit has a large wire thats 240v and a small one that 24v thats the one you want to look at . look for bare wires , look where it goes into the wall , thats the common place . "critters" love to chew thermostat wire . so take a look . .....please rate this answer , i need votes . thanks
Jan 24, 2009 | Heating & Cooling
3 amp fuse blows on a carrier 58mcb furnace board
Hi!!! Does your ac unit work fine?If not check your low voltage problem..You have a low voltage problem check the wire going out to your condensor make sure that they are not touching..Good luck..Check low voltage wires..short in progress..
Jan 04, 2009 | Carrier 52CQ-312-4 Comfort Series Heat...
Analog thermo.stat control kit
Have you tried removing the RH wire connected to the thermostat and try it ? This might rule out furnace as short in system. If it does the same, put RH- (heat) back on and try removing RC-(cool) , if it doesn't pop the fuse, you may have isolated the problem.?
Jul 30, 2008 | Dometic Rooftop RV Air Conditioner
Ruud UBHC Air Conditioner Logo
163 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
