Question about Thermador PD304BS Dual Fuel (Electric and Gas) Kitchen Range
Replace circuit board because there is no surge protection, looking for solution
My LCDTV/DVDCOMBO , MODEL NO /3255HD ,Had a power surge from a 5.5 Kva generator , is there any internal surge protection if so were , if not which curcit board would be damaged .?
most likely the power circuits as there is no internal surge protection
have the set properly diagnosed and go from there
always use a power board with surge protection for all electronic equipment
as the voltage from a genset is reasonably well controlled , even at over rpms the voltage would not go high enough to cause damage for example a 240 volts running at correct rpms will only get to 255 volts uncontrolled rpms as the governor lever is fully open
however a lower voltage (200 volts ) increases amp flow and that is probably what did the damage
Jan 04, 2017 | Electrical Supplies
LG 60LB7100 was hit by a power surge(lightning) now it turns on but won't go passed the opening screen
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Aug 24, 2015 | LG Electronics 60LB7100 60 Inch 1080p
We had a power outage due to fuses blown on the transitor outside on the pole, caused some appliances to blow out, light bulbs blown right out of their sockets, and my laser56 toystove wont turn back on,...
Blown board. Most in home appliances don't have circuit protectors. That's why the made surge strips. But these won't protect against direct electrical strikes.
Feb 28, 2015 | Cars & Trucks
Titan Troubleshooting
Check for small fuse on circuit board:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Water heater circuit boards are NOT protected from surge. And reset button does not protect from surge. Nearby lightning can put out any household appliance, especially since more of these things are electronic instead of mechanical.
Install single-use whole house surge protector and replace it after each surge event instead of replacing appliances.
http://waterheatertimer.org/How-to-wire-Whole-house-surge-protector.html
The quickest solution for tankless is to replace whole thing with more reliable tank-type electric heater for $275 from local box store.
Jun 18, 2013 | Water Heaters
Pro form 580 SI, power incline runs up as soon as it is plugged in and wont go down using console buttons.
possible it could be in incline senser but most likely the console needs replacing. you should always use a power surge protecter on a treadmill. power surges can blow out 1 resister on those circuit boards and there no good.
Sep 12, 2011 | Proform Exercise & Fitness
What does a CE error code on an Electrolux refrigerator (model EW26SS65GS) mean?
My fridge was having the same problem with CE being displayed, light and touch selector not working. With the assistance of one of my sons, we tilted the fridge back slightly and removed the control circuit board. Two of the three 470 u F capacitors were toast. My son drilled out the plastic brads holding the circuit board in the pan, then removed all three of the 470 u F capacitors. He soldered 3 new capacitors in place (0.59 cents each) and used 4 small screws/nuts to secure the board in place. After looking at the capacitors, he said a power surge had caused the damage. We went right out and bought a surge protector for the fridge. My fridge works perfectly now. While protecting tvs and computer from surges, I had never even thought of using a surge protector for the more costly fridge! Hope this helps someone else avoid an shamefully expensive parts replacement.
May 09, 2011 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Hi, I have a Rheem water tankless heater and there was a storm lastnight so suddendly I have no hot water. What can It be?
1) All tankless water heaters require voltage to operate electronic sensors and circuit board.
This is true for gas and electric tankless.
2) Check that circuit breaker is not tripped. Push circuit breaker all the way one direction and then all the way back other direction.
3) There are fuses located inside the tankless unit, so check your manual for location of each fuse.
Manual is filled with useful maintenance and troubleshooting steps.
4) Before calling service technician, open following link for troubleshoot resources including manuals, Rheem on-line chat, and useful links for maintaining tankless water heater.
5) If you had nearby lightning strike, I don't know if your tankless is protected from surge.
I recommend whole-house surge protector for tank and tankless water heater electronics, and household circuits. Surge protection is installed in main breaker box, and is replaced after each surge event. Separate protection needed for co-ax TV satellite, co-ax surge protection can be found on some ordinary power strips.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#surge
Apr 11, 2011 | Rheem Tankless Hot Water Heater...
Because of a power surge, i think i fried my tv, are there any safety procautions inside that might protect the tv, such as fuses, or would it just ruin the tv?
there are fuses and MOV's to protect for surges.
mov is metal oxide varistor, a resistor that shorts out when the voltage rating is exceeded causing the fuse to bluw.
always right after the fuse on the circuit board on the powersupply board
Mar 30, 2011 | Sony KDL32L5000 32 in. LCD HDTV
I HAVE A RBD305PDB DOUBLE WHIRLPOOL OVEN AND IT WON'T ACTIVATE THE BAKE/TEM/TIME FUNCTION AND IT SHOWS EITHER E2 F6 OR F2 E6 IN GREEN....
WHEN MY OVEN KEPT BEEPING AND LATER IT WOULD NOT OPERATE, I CALLED THE LOCAL COMPANY WHO SOLD MT THE OVEN...(KITCHEN CONCEPTS), THEY FORWARDED ME TO THEIR SERVICE COMPANY WHO CAME OUT AND LOOKED AT THE ERROR CODES AND SAID, "THERE IS NOTHING BUT BAD NEWS) THE CIRCUITS IN THE OPERATING CIRCUITS HAVE BEEN BLOWN OUT BY SURGES...IT WILL COST $538 TO REPLACE THEM....HIS STORY WAS THAT IN OUR NEIGHBORHOOD, THERE ARE A MULTITUDE OF SURGES...MY QUESTION IS WHY THE HELL DOES WHIRLPOOL PUT OUT A $1100 OVEN WITH NO PROTECTION FOR SURGES....CHECKING ON THE NET, I SAW MANY BAD FEATUIRES ON MY OVEN....DON'T USE THE OVEN CLEANER AS IT WILL COOK YOUR CIRCUIT BOARDS AND SEVERAL OTHER....WHAT A PIECE OF ****....I AM GOING TO WRITE THE COMPANY AND *****....TO NO AVAIL, THANK YOU FOR YOUR HELP....
Mar 05, 2010 | Whirlpool RBD305PD Electric Double Oven
Keypad/clock went blank
Normally when a power surge lands a direct hit on a non protected circuit board, it will usually fry it completely. you can confirm this by shutting down the power for 5 minutes. if the control doesn't respond after the 5 minutes of no power, this will confirm circuit failure due to the surge and, you will need to replace the board in this case.
May 18, 2009 | Maytag CWE5800A Electric Double Oven
Open Questions:
Thermador PD304BS Dual Fuel (Electric and Gas) Kitchen Range Logo
32 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
