Question about Dell Inspiron 700M Notebook
I suspect my 700m display had a possible short in the display cable. Half the screen has funky lines on it to the right side. When you move it it changes a little. External monitor display perfect. Should I replace the cabling?
  • 342 Answers
You have look whether the cable is lose contact.some times this will make problems.but your screen showing like a funky lines, this is due to problem of the LCD screen.you have to make it correct by giving it to the service center.
Posted on Jul 05, 2010
What can I do to repair a vertical stripe on my LED TV??
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD screen are similar, irrespective of its brand and screen size.
Jan 25, 2016 | Televison & Video
Any advice on what board I should replace if the left half of the screen is no good, just showing white and black vertical bars? Right half is fine. Is the panel kaput?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 29, 2015 | Panasonic TH-37PH9UK 37" Plasma Display -...
Left half of tv looks normal,Right side has multiple thin colored vertical lines across it. took it appart and suspect it to be one of the ribbon cables coming from from the video output board?
Sounds like T'Con board fault.
Sep 20, 2015 | Televison & Video
I just got the 22"
Hello, try to move your LCD screen on a different position. These symptoms are like due to some existing magnetic field from electronic devices by the side. If it won't work try to test a different screen if possible, it might be the display source or possibly the something in between like the cable.
Mar 29, 2011 | LG Computers & Internet
Half of the screen is black and have some green stripes
Please check in BIOS if the same ecreen is there this might be the issuedisplay panel cable or display panel itself.
Thanks
Dec 24, 2009 | Dell Inspiron 700M Notebook
Hp pavilion motherboard problem
Try to open the display and put out and in again the diplay cable.Maybe its a faulty contact of the display cable.It has happend to me.
Apr 13, 2009 | HP Pavilion dv9000z Notebook
T30 always comes up with record-ready display screen
T30 defaults to an opening display screen based on where you were when you last used the device. When leaving from the record folder and record mode, you will always open with the record-ready screen. If you left your T30 while in the music folder playing a music file, you will be returned to that.
This record-ready display screen has a numeric and bar time line. The numeric values of the line are in hrs:min:seconds. This line is also split: the right half of the line indicates the total amount of available recording time, while the left half indicates your time as you record. If you compare the values of the right and left sides of the numeric bar while you are recording, you will see that the right side is diminishing as the left side increases in numeric value. When you complete your recording and save your track, the right side will now indicate the new total time (the amount your screen first displayed LESS the time value of the track just recorded).
When you are playing a music file, if you watch the time display, you will see the numeric information changing in the same way. The left side indicates how may hrs:min:seconds your track has played while the right side indicates the total time value for that file and will be correspondingly decreasing while you play your music file.
So in the short, you don't need to worry much about your display screen unless you open in the wrong folder or you need more recording time than is available. Then it has a message for you.
Nov 06, 2008 | iRiver T30 MP3 Player
Lenovo 3000 N100 Screen Problem
First, plug a external monitor and toggle the screen to discard configuration or software problems. If the image displays correctly you have a problem either in the LCD screen or its connection cable.
Open the bezel and check for loose or damaged connection cable. Look specially next to the hinge, ON THE LEFT.
In case the problem is not the cable you might have to get a new LCD. You can have replacement parts and instructions here:
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ViewObjectID=56222
Jun 29, 2008 | Lenovo 3000 N100 0689 Notebook
A follow-up on my Dell vertical lines issues
I understand that it seems odd that sometimes they disappear.
I have a vertical line on one of my laptops right now that it takes about 3 seconds before it appears on the screen but once it's there. It's there.
I think it has to "warm up" before it comes back.
I used to do Technical support for a company that produced computers with 5inch wide screens, and everytime something with a line was mentioned, "Fix display cable" was the reason.
Because everytime you pushed the screen up to see the keyboard the line disappeared (because the display cable moved) But I digress.
All I'm certain of is that if you change the display cable this will be fixed.
Mar 15, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell Inspiron 700m screen acting up
try to uninstall and install the the display drivers / graphics card drivers.. it should help you.
Feb 20, 2008 | Dell Inspiron 700M Notebook
Dell Inspiron 700M Notebook Logo
mukhtar21 shaikh
mukhtar21 shaikh
